Old Jun 18, 2012, 03:18 AM
leoski is offline
Find More Posts by leoski
Joined Jun 2012
Originally Posted by FyreSG View Post
As long as I don't command suddenly direction changes, there would not be flybar strikes. Even during high rates, banked turns if executed smoothly and gently, the flybar should not strike the canopy.
Try bending the flybar upwards. Apply a little heat using a hair dryer to make the bend permanent. It helps.
Perform mechanical trim (permanent, persistent) so that you need not trim it every time you power up the TX.
im using 9x and only trimmed once not every time, seems good enough, don't know if mechanical trim would be any better as doesn't drift in any one direction but just slowly moves around a bit.. as for flybar strikes they are fairly rare and usually only when diving from steep climb and sharp turn (but so much fun), might try the heated bending of flybar, but afraid to cause more stabillity issues. still crashing often when try to really get some speed in tight place, and always astounded by no breakages.
leoski is offline Find More Posts by leoski
Old Jun 18, 2012, 04:30 AM
FyreSG is offline
Find More Posts by FyreSG
Vids: YouTube.com/FyreSG
FyreSG's Avatar
Singapore, Singapore
Joined Apr 2012
KKDDMM has quite a cool blog: http://plaza.rakuten.co.jp/ringmaker/ (In Japanese) I saw some really interesting mods there. Really impressive work!
FyreSG is offline Find More Posts by FyreSG
Old Jun 18, 2012, 05:04 AM
KKDDMM is offline
Find More Posts by KKDDMM
I love MOD! & WALKERA & V911!
KKDDMM's Avatar
China, Guangdong, Shenzhen
Joined Jan 2012
Originally Posted by Brosol View Post
KKDDMM: http://www.rcgroups.com/forums/showp...postcount=8824
Maybe KKDDMM will help answer firecabbage V911 Clone BNF features & V911 parts compatibilty questions.
FCMan: http://www.rcgroups.com/forums/showp...postcount=6936
I received it this morning at office.
So please wait a while,I will report the yellow bird after back home.
KKDDMM is offline Find More Posts by KKDDMM
Old Jun 18, 2012, 05:05 AM
KKDDMM is offline
KKDDMM's Avatar
Joined Jan 2012
Thank you!
Old Jun 18, 2012, 07:49 AM
KKDDMM is offline
KKDDMM's Avatar
Joined Jan 2012
I checked the NEW V911.
It can bind with my FS-TH9X-B,and there is no problem at test hover.
So I dont regret.
But......I think this heli is not a product of WL-TOYS.
Swashplate and rudder and maingear is just! just! just as same these of 9C002(Jiuchon)!!!
(But mainblade and linkage and head is different from V911 and 9C002.)
Off course,RX is a new one,
and speed of servo-moving is very quick as V911,
but an angle of movement is smaller than V911.
Obvious advantage is below two parts.
1)swash plate(have 2 pins)
2)skid(it has new batt holder,enclosed type)
New receiver ---> yes(only main motor is used connector)
New rotor head ---> yes(but almost same)
New main gear ---> 9C002
New main motor ---> not checked
New swash ---> 9C002
New swash guide ---> at center
New buckles ---> ???
New tail fins (maybe just cosmetic) ---> 9C002(rudder)
New tail motor ---> not checked
New main bldes ---> yes(but almost same)
New tail boom ---> yes(little shorter than V911)
New bushing ---> ???
New Canopy ---> yes(cop of 260A ?)
New connect links ---> yes(but almost same)
New main shaft (looks like carbon fiber?) ---> yes(carbon)
New balance bar. ---> yes(weight is different)
Old Jun 18, 2012, 08:13 AM
KKDDMM is offline
KKDDMM's Avatar
Joined Jan 2012
added photos, see my pages.
http://www.rcgroups.com/forums/member.php?u=398394
Old Jun 18, 2012, 08:29 AM
FyreSG is offline
FyreSG's Avatar
Joined Apr 2012
Arigato KKDDMM! Nice review!
I have a couple of Jiuchons and I find its main shaft and swashplates better than the ones on V911. I have swapped them over very quickly.
Old Jun 18, 2012, 08:32 AM
FyreSG is offline
FyreSG's Avatar
Joined Apr 2012
Full ailerons and Elevator == Rotation Impeded!
When under high rate, then applied full aileron left and full elevator forward, main shaft rotation is impeded. Check out the video:
WLtoys V911 Problem (0 min 34 sec)
This video showed stock V911 main shaft and swashplate. It also manifests on Jiuchon main shaft and swashplate as well. Head speed will be severely reduced when this happens.
Is this "normal"?
Old Jun 18, 2012, 09:10 AM
erdnuckel2 is offline
Find More Posts by erdnuckel2
erdnuckel2's Avatar
Joined Mar 2009
http://www.youtube.com/watch?v=QD0rPUnqTBk
Is this "normal"?
This is NOT supposed to happen (ie either the swash does not allow for enough angle or the servos have too much throw (too generous of WLToys, right ??? .) but it is "normal" if you define normal as occuring on basically all of them (and I have to suppose it does, as all mine "share" this feature ...
Old Jun 18, 2012, 09:50 AM
Dimension7 is offline
Find More Posts by Dimension7
Joined May 2006
Originally Posted by stifa View Post
To my V911 (did already damage to the surroundings...)
Tail motor got hit :
It didn't work in this condition , and didn't work after I pushed the back part back to the motor cylinder with nose pliers .
Any point in trying to save it ? (I got my BNF for now , until next crash )
Make sure the tiny rod is between the two pins at the back of the plastic cover.
But mine over heats after that fix until the motor died.
Dimension7 is offline Find More Posts by Dimension7
FyreSG is offline
FyreSG's Avatar
Joined Apr 2012
Yes I know this should not be happening but it is "normal" as I think all the V911s are like this. Do you think we can remove the ring and the problem will go away? Or will the lack of the ring cause evil vibrations?
Old Jun 18, 2012, 10:23 AM
KKDDMM is offline
KKDDMM's Avatar
Joined Jan 2012
Thanks!
And......I tried barless mod at this NEW(?) V911.
and I succeeded it,it can fry as V911.
This means,NEW(?) V911 is a good heli just like as original V911,I think.
Speed of servos is enough to control.
Rudder stability is enough too.
Old Jun 18, 2012, 10:44 AM
Brosol is offline
Find More Posts by Brosol
Brosol
Brosol's Avatar
Canada
Joined Dec 2010
@KKDDMM: Wow! Thank You for all review work.
FCMan did mention the parts are from the same factory that makes the Jiuchon 9C002 so its not a WLToys product it seems?
Brosol is offline Find More Posts by Brosol
Old Jun 18, 2012, 10:51 AM
Mag718 is offline
Find More Posts by Mag718
"Lurker"
Mag718's Avatar
Alabama
Joined May 2007
Having not previously seeing the flybarless mod, I am guessing it has something to do with the lead weights on the blade tips ??
Mag718 is offline Find More Posts by Mag718
Old Jun 18, 2012, 11:11 AM
RoboHeli is offline
Find More Posts by RoboHeli
Safety : practice & promote!
RoboHeli's Avatar
Joined Dec 2011
I'm a bit concerned about these "new" parts given the fact that the V911 has already gone through at least one revision. I just want to make sure I can still get parts! I get all my stuff from myrcmart, btw.
Can anybody tell me if my timeline is accurate here?
Rev 1 : The "Corter"
Rev 2 : The "Copter"
- Slightly longer tail boom than rev 1
- New tail motor holder and slightly different tail motor than rev 1 (Thanks Hayabusa Heli!)
- Skids have a screw in the rear and spares come with the power leads and battery connectors already attached
Rev 3 : This new thing from FireCabbage
Is there any way to reference the different revisions? I've already had a problem because I bought a Copter (rev 2) from myrcmart and then ordered a spare set of skids but got an older set (rev 1) that didn't have the screw hole. All they have now are the screw-hole ones (rev2). There's also no sign of the firecabbage versions (rev 3) there yet.
Does anybody know if there is any sort of "official" naming scheme for these? Or, do we have to resign ourselves to the fact that these helis are so cheap they're considered "disposable" by some--thus nobody is going to care enough to keep the part catalog accurate for those of us who DON'T consider them disposable?
RoboHeli is offline Find More Posts by RoboHeli
Last edited by RoboHeli; Jun 18, 2012 at 01:31 PM. Reason: added a rev 2 item from Hayabusa Heli
New Product Jiuchon 9C002, a Solo Pro clone? SoloProFan Micro Helis 103 Feb 29, 2012 02:24 PM
Discussion Interesting Solo Pro? Clone gordonzo Micro Helis 46 Nov 30, 2011 03:15 AM
Question Which 100 sized heli after Solo Pro? Tuc Micro Helis 16 Jun 13, 2011 01:52 PM
Sold $100 !NEW ARF Storm 250 (Trex Clone) With Align Upgrades, Tons of Extras! $100!! RChelisrule Aircraft - Electric - Helis (FS/W) 1 May 31, 2011 12:26 AM
