Old Jun 17, 2012, 02:59 PM
RicksterRC is offline
Find More Posts by RicksterRC
Joined Sep 2007
Originally Posted by Bvc View Post
I can help the servo move down with my finger, let go with my finger and the TX will hold it down and let it back up, but the TX alone won't move it down. What does that indicate?
Chek the three solder points where tabs go through the RX board at the top of the servo.
If you decided to resolder them, try to use very little heat.
They connect in ternally to plastic parts that melt easily.
You can buy replacement servos (banggood qty five).
I did that, but by the time I got it fied and all, I wish I had just bought a new BNF instead.
RicksterRC is offline Find More Posts by RicksterRC
Old Jun 17, 2012, 03:25 PM
Wasp09 is offline
Find More Posts by Wasp09
Canada, ON, Ottawa
Joined Jun 2009
Look inside the servo to check if anything stuck on the gears. if you find a broken gear, see if it can be reused by turning it around.
Just 3 screws to remove. It is easy.
I found a piece of debris from the casing inside mine. Clean it up. It has been working fine since.
Wasp09 is offline Find More Posts by Wasp09
Old Jun 17, 2012, 04:17 PM
Bvc is offline
Bvc
Find More Posts by Bvc
Bvc
United States, TX, Houston
Joined May 2012
Originally Posted by Brosol View Post
Thanks but cheaper to get a BNF.
Thanks. Very little heat. Ooops! LOL
Live and learn. Probably why it doesn't do anything now. I'll get a BNF.
Thanks, that's the first thing I tried (having seen your earlier post) and everything was ok.
Bvc is offline Find More Posts by Bvc
Old Jun 17, 2012, 08:00 PM
FyreSG is offline
Find More Posts by FyreSG
Vids: YouTube.com/FyreSG
FyreSG's Avatar
Singapore, Singapore
Joined Apr 2012
Originally Posted by Pancari View Post
Looks similar to this that is already on sale: http://www.banggood.com/Wholesale-No...e-p-45017.html
FyreSG is offline Find More Posts by FyreSG
Old Jun 17, 2012, 08:16 PM
heligeek is offline
Find More Posts by heligeek
CB100, 4#6, V911, V939, V912
Modesto, CA
Joined Jan 2006
Just received my V911 and love it. Flys great and so stable. Quick question about dual rates on the stock transmitter. Does the top left button turn it on and off? How do I know what the setting is? There does not seem to be an indicator on the display.
heligeek is offline Find More Posts by heligeek
Old Jun 17, 2012, 08:25 PM
FyreSG is offline
FyreSG's Avatar
Joined Apr 2012
The question on dual rates has been coming up on several occasions. James, you might wanna include this in the first post.
To determine high or low rates, simply move the stick for aileron and elevator. If it shows all 4 bars, you are at high rate. When the TX powers up, it is always at low rate.
Old Jun 17, 2012, 09:39 PM
Mag718 is offline
Find More Posts by Mag718
"Lurker"
Mag718's Avatar
Alabama
Joined May 2007
Well after all the cleaning, laundry and preparations for a fathers day dinner with my wife and i's parents I had enough time to fly 4 batteries worth outside. The wind of the past few days had died down to light and variable (have a home weather station in backyard. I can tell you this much: V911 flies way better than original mSR. Way better! it's a tad larger so it is easier to see and i had fun chasing the dog around the backyard. The cats didn't seem to mind.
I do have trouble flying circuits to the left compared to the right though. This could be lack of flying time on my part though.
I'm really going to enjoy this little heli and can't wait for the TH9x to show up along with 2 spare BNFs.
Mag718 is offline Find More Posts by Mag718
Old Jun 17, 2012, 10:51 PM
erdnuckel2 is offline
Find More Posts by erdnuckel2
erdnuckel2's Avatar
Joined Mar 2009
spot landing challenge - E2 entry 1
if any of you guys repeats that spot landing challenge vid and is able to show an improvement7new personal record or similar ... PLEASE share!!!
here is my (first ... as I dont intend this to stay the best I was capable of) entry to video challenge #2: "BullsEye" ... spot landing with the V911
http://www.rcgroups.com/forums/showp...&postcount=192
Old Jun 17, 2012, 11:09 PM
Pancari is offline
Find More Posts by Pancari
What Do You Drive?
Pancari's Avatar
United States, PA, Folsom
Joined Jan 2012
Since the can was on the floor you fought against massive turbulence..
Perhaps the challenge should be reworked to
Landing on a tuna can that is on the edge of a table
or
landing on a tuna can that is on a can of coffee on the floor or table
to reduce turbulence and then it becomes more about pinpoint accuracy rather than waiting
Pancari is offline Find More Posts by Pancari
Old Jun 18, 2012, 12:20 AM
leoski is offline
Find More Posts by leoski
Joined Jun 2012
Wow well done pancari, truely a difficult task, i will keep trying and hopefully someday will land it... Is your 911 stock? I have made no mods to mine yet and flybar strikes are annoying, what mods do u guys recommend for precision flying?.. When trimmed it flys pretty good but does sway a little bit instead of perfectly still in hover.
leoski is offline Find More Posts by leoski
Old Jun 18, 2012, 12:31 AM
cori80 is offline
Find More Posts by cori80
Joined Jul 2011
Originally Posted by cgpirre View Post
Funny, I just asked Aaron the same thing yesterday. He told me he didn't have any corters left, but he'd ask the factory if they have any left, because more people asked for it
These guys have your "Corter" canopies
http://www.rcroanoke.com/v911-canopy-black-p-235.html
cori80 is offline Find More Posts by cori80
Old Jun 18, 2012, 12:42 AM
FyreSG is offline
FyreSG's Avatar
Joined Apr 2012
As long as I don't command suddenly direction changes, there would not be flybar strikes. Even during high rates, banked turns if executed smoothly and gently, the flybar should not strike the canopy.
Try bending the flybar upwards. Apply a little heat using a hair dryer to make the bend permanent. It helps.
Perform mechanical trim (permanent, persistent) so that you need not trim it every time you power up the TX.
Old Jun 18, 2012, 01:28 AM
Joined Sep 2007
Anyone know anything about the "New" parts firecabbage on aliexpress is listing?
Are any of these new parts backwards compatible but improvements?
Would I be wise to pay the extra for the "New" motor etc?
Wil I need new blades/flybar if I switch rotor head?
New receiver
New rotor head
New main gear
New main motor
New swash
New swash guide
New buckles
New tail fins (maybe just cosmetic)
New tail motor
New main bldes
New tail boom
New bushing
New Canopy
New connect links
New main shaft (looks like carbon fiber?)
New balance bar.
Old Jun 18, 2012, 02:49 AM
stifa is offline
Find More Posts by stifa
Expert in indoor damage
Israel, Jerusalem
Joined May 2012
First real damage
To my V911 (did already damage to the surroundings...)
Tail motor got hit :
It didn't work in this condition , and didn't work after I pushed the back part back to the motor cylinder with nose pliers .
Any point in trying to save it ? (I got my BNF for now , until next crash )
stifa is offline Find More Posts by stifa
Old Jun 18, 2012, 03:03 AM
Brosol is offline
Find More Posts by Brosol
Brosol
Brosol's Avatar
Canada
Joined Dec 2010
New receiver
New rotor head
New main gear
New main motor
New swash
New swash guide
New buckles
New tail motor
New main bldes
New tail boom
New bushing
New Canopy
New connect links
New balance bar.
KKDDMM: http://www.rcgroups.com/forums/showp...postcount=8824
Maybe KKDDMM will help answer firecabbage V911 Clone BNF features & V911 parts compatibilty questions.
FCMan: http://www.rcgroups.com/forums/showp...postcount=6936
Brosol is offline Find More Posts by Brosol
New Product Jiuchon 9C002, a Solo Pro clone? SoloProFan Micro Helis 103 Feb 29, 2012 02:24 PM
Discussion Interesting Solo Pro? Clone gordonzo Micro Helis 46 Nov 30, 2011 03:15 AM
Question Which 100 sized heli after Solo Pro? Tuc Micro Helis 16 Jun 13, 2011 01:52 PM
Sold $100 !NEW ARF Storm 250 (Trex Clone) With Align Upgrades, Tons of Extras! $100!! RChelisrule Aircraft - Electric - Helis (FS/W) 1 May 31, 2011 12:26 AM
