Old May 09, 2012, 05:57 AM
seefest is offline
Find More Posts by seefest
seefest's Avatar
United States, MA, Bristol
Joined Sep 2009
Originally Posted by Dimension7 View Post
It's my second day of owning a V911 and having a blast with it.
Quick question folks, aside from getting a BNF, what other parts should I anticipate to replace?
I've had mine for two months and crashed it numerous times. No damage other than a broken wire on the tail rotor motor. Just cut the throttle when you know you're going to crash.
seefest is offline Find More Posts by seefest
Old May 09, 2012, 08:02 AM
KKDDMM is offline
Find More Posts by KKDDMM
I love MOD! & WALKERA & V911!
KKDDMM's Avatar
China, Guangdong, Shenzhen
Joined Jan 2012
Uploading movie is very difficult in CHINA......
Originally Posted by derelicte View Post
let me guess - it crashed?
people do fly without flybars - either mechanical or electronic. you need a lot of expo. search for nobars. although I haven't seen a report of someone flying something this small without a flybar.
got any video?
4IN1=REV.04
http://v.youku.com/v_show/id_XMzkzODI3MDc2.html
KKDDMM is offline Find More Posts by KKDDMM
Old May 09, 2012, 08:44 AM
markkona is offline
Find More Posts by markkona
when is the wind stopping??
markkona's Avatar
Malta, Marsaskala
Joined Apr 2011
today I flew the V911 in some 20km/hr winds and with the paddles at the farthest out on the cf flybar I was able to penetrate the wind but it is very unstable indoors with this mod so I tried moving the paddles further in and the stability was much better almost like with sock flybar but in the wind I couldn t penetrate and had to land it about 40-50 ft away from me!!
markkona is offline Find More Posts by markkona
Old May 09, 2012, 08:45 AM
markkona is offline
markkona's Avatar
Malta, Marsaskala
Joined Apr 2011
Originally Posted by KKDDMM View Post
Interesting is it quite stable or do you have to counteract every move with stock tx?
Old May 09, 2012, 09:44 AM
FyreSG is online now
Find More Posts by FyreSG
新加坡的飞儿
FyreSG's Avatar
Singapore, Singapore
Joined Apr 2012
Night flying
Just flew 2 batteries worth of flight at night! Did some figure 8s at a well-light badminton court below my apartment. Even under the spotlight, the black/orange V911 was quite hard to see, especially when it flies to places where the background is the black surrounding. Maybe I should spray the skids white and swap on white rotor blades fromy my Jiuchon...
Got the hang of smooth banked turns. Flybar hardly strikes the canopy now.
FyreSG is online now Find More Posts by FyreSG
Old May 09, 2012, 09:47 AM
新加坡的飞儿
FyreSG's Avatar
Joined Apr 2012
Wow, FBL FP V911!
What do you mean by 4IN1=REV.04?
Saw the video, wow! Can anyone explain how it is possible to fly without the flybar? How to stablize the heli without the flybar?
Old May 09, 2012, 10:06 AM
Proud Infidel is offline
Find More Posts by Proud Infidel
9958 gave me the toilet bowl
Proud Infidel's Avatar
United States, IL, Rockford
Joined Jan 2012
Wait for something to break.
In my many crashes, only my canopy got badly cracked and my landing gear busted, which I fixed. If one V911 gets grounded, you have a second one.
Proud Infidel is offline Find More Posts by Proud Infidel
Old May 09, 2012, 10:39 AM
SG Mason Knives is offline
Find More Posts by SG Mason Knives
Canada, ON, Iroquois
Joined Mar 2012
Originally Posted by andur View Post
Why do people think wd40 is not a lubricant?
I wouldn't dare to say wd40 is not a lubricant since it is made up of oil. I've lubed all my motors with it I think and it does make them spin easier. Just a tiny dab right into the shaft hole.
http://en.wikipedia.org/wiki/Wd40 "Function:The long-term active ingredient is a non-volatile, viscous oil which remains on the surface, providing lubrication and protection from moisture."
http://www.wd40.com/ Lubrication...
WD40 is mainly a penetrating oil, meant for breaking up corrosion and displacing water. it's main ingredient is mineral spirits (51% Stoddard solvent i.e., mineral spirits: primarily hexane, somewhat similar to kerosene). What ever Mineral oil they add to it is not up to the task in high load or high speed applications. There is a lot of technology that goes into lubricants, and they tune them for specific jobs.
I love WD40 in the right application, for breaking free a rusted, or stubborn bolt it is hard to beat. Got a sticky drawer? A little WD40 will solve the problem for a little bit. I also use it when I am hand sanding the knives I make, it works much better than soap and water when wet sanding steel to a mirror finish
SG Mason Knives is offline Find More Posts by SG Mason Knives
Old May 09, 2012, 12:49 PM
MassiveOverkill is offline
Find More Posts by MassiveOverkill
MassiveOverkill's Avatar
United States, SD, Custer
Joined Feb 2011
Refresh my memory, what other mods have you done?
MassiveOverkill is offline Find More Posts by MassiveOverkill
Site Sponsor
Latest blog entry: MassiveRC ZMR PDB
Old May 09, 2012, 01:03 PM
Killer Bee is offline
Find More Posts by Killer Bee
Joined Jan 2012
So I broke my flybar and attempted what you have demonstrated... didn't work. I couldn't keep the thing in the air more than 5 seconds.
Killer Bee is offline Find More Posts by Killer Bee
Old May 09, 2012, 01:22 PM
Joined Mar 2012
I only got a glance of the blades, but it looks like there may be some weight added to the ends of them to help with stability.
Old May 09, 2012, 01:31 PM
Wasp09 is offline
Find More Posts by Wasp09
Canada, ON, Ottawa
Joined Jun 2009
It is simply difficult but still possible. Basically the only inertia to provide stabilization would be the rotor blades. Some multi-blade heads have enough mass there, that they don't need flybar nor electronic stabilization.
I have tried flying V911 without flybar weights. That was quite easy when the empty flybar was still there. There were no flybar strikes after the weights were removed.
Wasp09 is offline Find More Posts by Wasp09
Old May 09, 2012, 01:36 PM
thewildweasel is online now
Find More Posts by thewildweasel
Beware the Axis of Weasel.
thewildweasel's Avatar
Plymouth, Devon
Joined May 2007
The good news is, mine's arrived from BG after only 2 weeks so I can play here now instead of just reading: the bad news is, the main motor's shot... It starts intermittently and only gives about 1 minute of flight before being right down by the floor, and has no punch in the minute I do get. I tried lubing the shaft but no joy. Not a real problem, I'm good at soldering from the days I flew actuator controlled planes, and I think I've got a few 8.5mm motors in my spares box somewhere.
Mine's a blue and white one, rev 5 board, old style tail motor holder and what appears to be a 'mkII' tx - the piro rate is slower than on my mcx2 so the 1k resistors and 5k rheostat I bought the other day aren't needed. Also, the crystal is siliconed to the board so it appears that that's been noted by the manufacturer. Overall, I'm very impressed. A few turns on the control rods to the swash and it hovers hands-free. I'm not too fussed about the motor; I've been flying micro rc long enough to know that some are better than others and some are just DOA, and for the cost of a couple of components a few years ago I'm pretty happy overall.
thewildweasel is online now Find More Posts by thewildweasel
Old May 09, 2012, 02:18 PM
stonecutter is offline
Find More Posts by stonecutter
Sir Crashalot
stonecutter's Avatar
Joined Oct 2011
You should change your call sign to "Zen Master". Most people would be pretty PO'ed if they get a motor DOA.
stonecutter is offline Find More Posts by stonecutter
Old May 09, 2012, 02:23 PM
dave1993 is offline
Find More Posts by dave1993
RC beginner
New York
Joined Oct 2008
several reasons:
both my nephews bikes that were "lubed" are now rusted and useless. his sisters bike same model was not and still looks like new. at least a half dozen similar examples.
mineral oil, the only "oil" in it, is not a lubricant. see wikipedia.
"wd" stands for "water displacement". nothing to do with lubrication.
spray it on a paper and check the next day. no oil spot. same for the nuts and bolts ive loosened with it. dry as a bone next day.
its proven to be one of the best ways for me to REMOVE grease and oil.
correction: actually it does work as a lubricant. for about 30 seconds.
dave1993 is offline Find More Posts by dave1993
New Product Jiuchon 9C002, a Solo Pro clone? SoloProFan Micro Helis 103 Feb 29, 2012 03:24 PM
Discussion Interesting Solo Pro? Clone gordonzo Micro Helis 46 Nov 30, 2011 04:15 AM
Question Which 100 sized heli after Solo Pro? Tuc Micro Helis 16 Jun 13, 2011 02:52 PM
Sold $100 !NEW ARF Storm 250 (Trex Clone) With Align Upgrades, Tons of Extras! $100!! RChelisrule Aircraft - Electric - Helis (FS/W) 1 May 31, 2011 01:26 AM
