Old Apr 26, 2012, 04:39 PM
RicksterRC is offline
Find More Posts by RicksterRC
Joined Sep 2007
Originally Posted by derelicte View Post
no, you just need to flip the blades. the gyro works fine.
http://www.helifreak.com/showthread.php?t=183527
I'll concede that the gyro works fine, but flipping the blades won't do it, unless you reverse the motor (and then you need to reverse the tail).
The referenced forum discusses that reversing the motor is bad for it, so they put blades from a different heli that has reversed rotation.
If you're thinking, he's crazy, if I hold my V911 upside down, it blows "up", so flipping the blades would reverse the thrust.
But it hasn't. The thrust is still "down" relative to the heli.
It seems to have flipped to you, not because of the blades, but because flipping the motor makes it rotate the other way relative to your frame of reference.
Someone made a nice graphic a while back.
Here's a blade /
We're going to flip it over.
45 degrees |
90 degrees \
135 degrees |
180 degrees /
Props are designed to be oriented a certain way for efficiency.
Putting the tail rotor on your V911 backwards will still work, it just might be less efficient.
RicksterRC is offline Find More Posts by RicksterRC
Old Apr 26, 2012, 05:14 PM
Wasp09 is offline
Find More Posts by Wasp09
Canada, ON, Ottawa
Joined Jun 2009
Originally Posted by Killer Bee View Post
Or you could say it as... More pinion gear teeth equates to high head speed which means the motor runs at a lower rpm to maintain altitute. This would also mean greater performance/lift at max rpm. I guess my mistake was reading his repsonse as higher Motor rpm vs higher Rotor rpm which is what was actually said... The motor rpm would decrease for the same amount of lift. I think the 9958 is a worthwhile transplant motor for added performance.
When you say higher head speed, you mean higher max head speed. The operating head speed remains the same if the heli stays at the same height not going up or down.
The motor operating rpm would change depending on the gear ratio. That is correct. However the power requirement remains more or less the same to keep the corter hovering at the same height independent of motor rpm.
Motor rpm translates to back emf. A lower rpm means driving the motor at lower voltage but since the torque required would be higher to give the same power that implies higher current. (On a switching ESC, it probably means higher current but narrower pulses.) It depends on the ESC and motor winding which way they would work better.
The max. motor rpm would be limited by the battery voltage assuming the ESC and motor can handle the higher current. If they can we do have an advantage that it may deliver a bit more at pulling out starting with a lower motor rpm.
However do remember we are dealing with an unknown integrated brushed ESC and an unknown brushed motor. Higher current is not necessarily a good thing.
The FFF speed again is related to the max angle the cyclic can make assuming we have to maintain a level flight. In a way we cannot simply achieve a faster FFF speed by increasing the head speed unless we also allow the corter to gain altitude while going forwards.
We can do that but just be careful not getting too high and be blown away.
Wasp09 is offline Find More Posts by Wasp09
Old Apr 26, 2012, 05:22 PM
Wasp09 is offline
Canada, ON, Ottawa
Joined Jun 2009
Originally Posted by RicksterRC View Post
I'll concede that the gyro works fine, but flipping the blades won't do it, unless you reverse the motor (and then you need to reverse the tail)...
Have to reverse the motors. Some brushless ESCs can reverse direction of rotation on the fly.
It is less common for brushed ESC but can be done, the brushed motor driver for a servo is bidirectional. We need a bridge instead of a single transistor.
Old Apr 26, 2012, 05:39 PM
wavy is offline
Find More Posts by wavy
Joined Mar 2012
D.I.Y. Do It Yourself.
This is so easy, it's dumb. Just Swap Top and Bottom Blades and put them on upside down. It works even on a Syma S107!
wavy is offline Find More Posts by wavy
Old Apr 26, 2012, 05:47 PM
wavy is offline
Joined Mar 2012
Inverted flying
Wouldn't it be possible to just use "backward" blades, made for a counter-clockwise rotor?
Old Apr 26, 2012, 06:21 PM
Wasp09 is offline
Canada, ON, Ottawa
Joined Jun 2009
Originally Posted by aidenXudfame View Post
Anyone have any advice?
You mean taking the blades off?
Takes off the 2 screws at the side, you would be able to pull the two blades apart.
The lever like connectors go in only when it is vertical. The shorter end connects to swash and the longer end connects to the flybar.
The main gear and flybar can be removed after removing the screws.
There are holes on the main shaft for screws, align the screw with the hole when you put main gear back on.
Old Apr 26, 2012, 06:33 PM
Wasp09 is offline
Canada, ON, Ottawa
Joined Jun 2009
That would do it too on a co-axial if you mean swapping the blades mechanically yourself.
When I asked how selfclean and autoclean differed at a kitchen shop, I was told selfclean meant clean it yourself.
Old Apr 26, 2012, 06:38 PM
Killer Bee is offline
Find More Posts by Killer Bee
Joined Jan 2012
I know if you put he tail blade on backwards, it will blow the opposite direction so I see no reason the same can't happen with the main rotor.
Killer Bee is offline Find More Posts by Killer Bee
Old Apr 26, 2012, 06:44 PM
dave1993 is offline
Find More Posts by dave1993
RC beginner
New York
Joined Oct 2008
as mentioned several times putting a prop on backwards, any prop (helii, plane, or hat), does not reverse thrust. it does however reduce efficiency big time unless its designed to reverse like s107 tail.
btw anybody need replacement motor? only $91.83. two sold already so better act quick!
http://www.ebay.com/itm/Main-Motor-F...item1c236ede5e
dave1993 is offline Find More Posts by dave1993
Old Apr 26, 2012, 06:53 PM
Wasp09 is offline
Canada, ON, Ottawa
Joined Jun 2009
Try that again with the main motor disconnected or main blade removed or use a bigger tail blade. Tell us what happens.
Old Apr 26, 2012, 06:57 PM
Del-Dredd is offline
Find More Posts by Del-Dredd
Del-Dredd's Avatar
Near Aberystwyth - Wales
Joined Aug 2004
Must have got his currency convertor wired up backwards.
Del-Dredd is offline Find More Posts by Del-Dredd
Old Apr 26, 2012, 07:26 PM
dave1993 is offline
RC beginner
New York
Joined Oct 2008
ah yes.. i see now that its actually only 56.99 quid. lol!
Old Apr 26, 2012, 07:36 PM
Hayabusa Heli is offline
Find More Posts by Hayabusa Heli
Heli Mania
Hayabusa Heli's Avatar
PNW
Joined Dec 2010
Tail blades designed to blow in both directions (ie, like on the V911, 9958, S107, etc - the heli can yaw in both left and right directions) are shaped differently than the main blades are. Take a close look at the profile difference between the tail prop blades and the main blades.
Edit - V911 and 9958 tail blades are designed to blow in one direction ... doh!
Hayabusa Heli is offline Find More Posts by Hayabusa Heli
Old Apr 26, 2012, 07:39 PM
Daryoon is offline
Find More Posts by Daryoon
Team WarpSquad
Daryoon's Avatar
United States, CA, San Diego
Joined Dec 2010
HH: Only the S107 is designed to blow in either direction. The v911 and 9958 has tail blades that only blow in one direction.
Daryoon is offline Find More Posts by Daryoon
Old Apr 26, 2012, 07:40 PM
dave1993 is offline
RC beginner
New York
Joined Oct 2008
true for s107 but not v911. rotating in your hand at low throttle will show it either runs, runs fast, or just stops. you can also see by the shape that its designed for one direction only.
edit: oops... daryoon beat me to it. great minds think alike.
New Product Jiuchon 9C002, a Solo Pro clone? SoloProFan Micro Helis 103 Feb 29, 2012 03:24 PM
Discussion Interesting Solo Pro? Clone gordonzo Micro Helis 46 Nov 30, 2011 04:15 AM
Question Which 100 sized heli after Solo Pro? Tuc Micro Helis 16 Jun 13, 2011 02:52 PM
Sold $100 !NEW ARF Storm 250 (Trex Clone) With Align Upgrades, Tons of Extras! $100!! RChelisrule Aircraft - Electric - Helis (FS/W) 1 May 31, 2011 01:26 AM
