Old Apr 25, 2012, 05:42 PM
Canada
Joined Nov 2000
Originally Posted by Wasp09 View Post
Sure, it is CanadaPost, it is slow but quite reliable.
That is why I prefer not to use UPS.
Live close to the US border? I do and I have a 'receiving' business address for All US bought goods. Border guards simply don't care about items of $250~ or less.
So no taxes.. Let alone the ridiculous $5 handling fee from the Disgruntled Postal Worker twits
Bare is offline Find More Posts by Bare
Old Apr 25, 2012, 05:46 PM
Canada, ON, Iroquois
Joined Mar 2012
I will attest to UPS gouging us to the maximum they can I recently had a $22 order come from the US, and the only shipping options were USPS express and UPS Standard. On the surface UPS Standard looked like the better way to go, until the package arrived. There was an extra $20 brokerage charge tacked on plus all the taxes. None of this was printed in plain sight, and I didn't know about it till the delivery man knocked on the door. If I had gone with USPS Express it would have been $5 cheaper and gotten here a week sooner.
About the best thing you can do Wasp is find someone you can trust State side and have them let you use their mailing address, then pay them to ship it to you. In the long run it would still be cheaper than UPS.
CanadaPost won't work holidays, Saturday and Sunday even for "Express" services. When we complain about missing target delivery standard, CanadaPost would simply tell us to claim the shipping charge back. It is taxpayer's money anyway.
I meant the cheap Solo Pro's from HK are only stocked in the States. I can order from the US stock but the only option available to ship to Canada when I check out is UPS. UPS would usually ask for a ransom crossing the border, holding my shipment hostage.
The declared value to Customs could to be quite inflated from some shops in the States. Sometimes they put a value much higher than the price of the goods there. (Not sure what HK US will do though) It may even be kind of bootstrapping the declared value from shipping, handling and brokage charges. . The more UPS charges results in more import tax and the more tax to be collected results in more UPS brokage fee.....
In comparison, CanadaPost's service charge for import tax collection is fixed, $5 I believe. Usually unless the item is obviously very valuable, it would often get rubber stamped through.
UPS is more eager to get everything import taxed and brokage fee charged.
Otherwise I would have ordered a 100D or 180. I ordered my D02S from eHirobo (Hong Kong) instead.
SG Mason Knives is offline Find More Posts by SG Mason Knives
Old Apr 25, 2012, 05:47 PM
Joined Apr 2012
Originally Posted by RicksterRC View Post
Are all the servo and mixer arms on correct?
The arms going from swash to mixer should be on the longer pair of balls on the swash.
The links going up to the mixer have a slot that goes on a pin.
The "left side" of the mixer arm (the little horizontal piece of plastic that pivots on the main blade) is shorter than the right side.
Final idea, are there any bad teeth on the main gear?
Spin the heli slowly while holding the main blade.
Maybe swap the main gear with your other heli. It's only one screw.
One more. Maybe swap the head with your other.
Again, one screw.
Take the head, and the main blades.
Thanks for your help RicksterRC
I will try these suggestions later on, bit tied up right now. Will let you know how I get on.
latestart is offline Find More Posts by latestart
Old Apr 25, 2012, 06:03 PM
Daryoon's Avatar
San Diego, CA
Joined Dec 2010
Originally Posted by Daryoon View Post
Originally Posted by andur View Post
Could anyone measure the resistance of a good bravo motor?
I have a brand new Bravo SX motor I can get a resistance reading off of. Just keep in mind, it's a single sample.
I have two new, in the bag white cap Bravo SX. Both measured 0.7ohms each.
I also have a brand new, in bag mSR X motor. And it measured 0.6ohms.
Not sure what to do with those numbers, but I said I'd measure them when I get a chance. So there they are. Hope it helps.
Daryoon is online now Find More Posts by Daryoon
Latest blog entry: Syma S105 Battery Mod
Old Apr 25, 2012, 06:30 PM
Joined Jan 2012
So I noticed today my V911 has the shakes during a hover. Its not a constant thing but it will have a spell and shake like the main shaft is bent but it doesn't lose altitude. Any ideas?
Killer Bee is offline Find More Posts by Killer Bee
Old Apr 25, 2012, 08:29 PM
Apphoard's Avatar
Joined Mar 2011
Is anyone swash near level even after you manually adjust it to hover perfect? Because mine is nowhere close.
Apphoard is offline Find More Posts by Apphoard
Old Apr 25, 2012, 08:38 PM
partly crasher
United States, OH, Cleveland
Joined Oct 2011
similar swash question.
with the heli sitting on a flat surface ,the left skid has the 2 nubs on it which lift the heli off level, SHOULD the two swash arms be level with the ground or level with the maingear of the heli?????
thanks
TT
tonytester is offline Find More Posts by tonytester
Old Apr 25, 2012, 08:40 PM
I need a bigger shed..
sammyc's Avatar
Australia, TAS, Launceston
Joined Nov 2011
Originally Posted by Proud Infidel View Post
In case anyone's thinking of moving onto a collective pitch heli, HobbyKing.com is selling the Solo Pro 100 RTF for $79.99. Incidentally, the BNF is $87.59, go figure.
Ahhh not fair, nearly twice the price in international warehouse at ~$140
sammyc is offline Find More Posts by sammyc
Old Apr 25, 2012, 08:47 PM
If It Works, I'll Break It
Jake8131's Avatar
United States, IL, Mascoutah
Joined Dec 2010
Mine did that the other day....I sat it down look at the back of the rx and saw that the right hand servo arm was touching the canopy.....hmmmmm. IDEA!! Put o-rings on the canopy rods and then put the canopy back on....no more touching the inside of the canopy and shakes went away!
Jake8131 is offline Find More Posts by Jake8131
Old Apr 25, 2012, 08:56 PM
Brosol
Brosol's Avatar
Canada
Joined Dec 2010
Brosol is offline Find More Posts by Brosol
Old Apr 25, 2012, 09:12 PM
Apphoard's Avatar
Joined Mar 2011
thanks
TT
I don't know on these fixed pitch. But on a CP Heli the swash has to be level with the Heli. I would assume the same with these. But mine is not working out that way.
Old Apr 25, 2012, 09:32 PM
Joined Jan 2012
I just checked mine and the servo arms have plenty of clearance. Wonder if the tail motor is failing already since I have to add a lot of rudder trim on a fresh battery.
Old Apr 25, 2012, 10:00 PM
Apphoard's Avatar
Joined Mar 2011
It has to be hell soldering the tail motor wires back onto the board. Because I can barely see where they go with the magnifying glass on my cheap helping hands. I think I need a stronger glass.
Old Apr 25, 2012, 10:17 PM
Joined Jan 2012
Yeah I was looking at that. Maybe it would be easier to splice and solder wires together than attempt to solder the board.
Old Apr 25, 2012, 10:20 PM
Jake8131's Avatar
Joined Dec 2010
When I first got mine it had the shake right out of the box. I replaced the blades with the spare set and the shakes went away. My heli had drops of hot glue everywhere. Blades had the glue the worse and I guess they got imbalanced. Cleaned them up and still no shakes....why was my heli and tx have glue drops everywhere???
New Product Jiuchon 9C002, a Solo Pro clone? SoloProFan Micro Helis 103 Feb 29, 2012 02:24 PM
Discussion Interesting Solo Pro? Clone gordonzo Micro Helis 46 Nov 30, 2011 03:15 AM
Question Which 100 sized heli after Solo Pro? Tuc Micro Helis 16 Jun 13, 2011 01:52 PM
Sold $100 !NEW ARF Storm 250 (Trex Clone) With Align Upgrades, Tons of Extras! $100!! RChelisrule Aircraft - Electric - Helis (FS/W) 1 May 31, 2011 12:26 AM
