Old Apr 24, 2012, 12:25 PM
Joined Feb 2012
Originally Posted by Bare View Post
Practical for Whom? How does that protect/survive Postal handlers across half the planet, when.. only... wrapped in Yellow packing tape?
Foam box inside. safe.
FCMan is offline Find More Posts by FCMan
Reply With Quote  (Disabled)
Old Apr 24, 2012, 12:41 PM
Joined Jan 2012
Originally Posted by andur View Post
I wanted to share my thoughts on the CNC piece. I love that aluminum look! So I bought one. It turned out fairly heavy, even with a carbon main shaft it was a bit too heavy. I can't recall the weight but the kit was over 2g I think.
So I made some mods. I cut off the shorter arms, which I never use. Then I sanded everything down as far as I felt strong enough and drilled some 1-2mm holes for lightness (and looks!). Also I did some math and the easy idea was that if the lower longer arms are made shorter, it will increase the motion of the upper arms. I sanded the lower arms shorter by about 1.0-1.1mm, which I guess gives me about 1-2 degrees more rotation in the upper swash. Well the details don't matter much I guess but the idea was worth investigating. Now I'm thinking we should drill holes in the side of the swashplates lower arm and attach the pivot balls closer to the main shaft that way.
A second very important mod was I glued down the pivot ball inside the swash plate. It wasn't too snug and moved up and down so I dipped some super glue inside the ball and slid it in place. I know I can't get it off anymore but if the shaft breaks (unlikely) I'll just have to drill the remaining carbon out of there. Now the result is pretty nice and tight, also a lot faster than before. The amount the swash moves is considerable - when I go full backwards and sideways at the same time it will actually choke the main shaft so I guess that means I'm close to the maximum of available swash tilt. It will snag at the middle pivot balls retainer ring, very little room to tilt there. I ground it down a bit so it's better but still will stop the blades at mid flight if I tilt the swash diagonally back at high rates. But forward it's OK so it's good to fly. My swash is adjusted so it is tilted backwards a bit (tuned so it will hover on spot), that's why it doesn't affect forward flight.
Which swash are you using and where did you find it?
Thanks!
Killer Bee is offline Find More Posts by Killer Bee
Old Apr 24, 2012, 12:44 PM
Apphoard's Avatar
Joined Mar 2011
Originally Posted by erdnuckel2 View Post
... and that means??
The boom the carbon fiber part is a quarter inch longer than the genius. I was thinking of using the 911 boom because of that on my genius. Everyone says to make it that much longer. But then I saw BP Hobbies sells the 2 by 2 mm carbon square tube that is used on both of them for much cheaper. But just about every time I break the tail on the genius the tail motor wires break as well. So it is a lot easier for me to just replace the whole tail on the genius. Because I find it very hard soldering those wires back together. Also I don't have the right wire. So I have not gotten the carbon tube from BP yet but it's cheap!!
Apphoard is offline Find More Posts by Apphoard
Old Apr 24, 2012, 12:50 PM
erdnuckel2's Avatar
Joined Mar 2009
Originally Posted by dazr33 View Post
Took mine outside today and it would hardly fly at all even after taking the lateral play out of the blades. Massive rumbling Vibration plus toilet bowl effect. Steering right and forward and circling down. When throttling Its kinda like a wheel out of balance and effects the hovering stability. I'll try reassemble it all from scratch (other than than the motor and circuit board connections) oh well if all else fails after installing the upgrade kit you can buy another whole v911 (copter only) for $26.
Has anyone tried this on their v911? http://www.ebay.com.au/itm/WLToys-WL...item4164ddf41c
got one of these in the mail from aliexpress - I only suppose it will be exactly the same as the silver one I already have (and only used THE UPPER HALF of the swash and the set collar) ... but for the particular purpose I have in mind it would/will be really neat to have a all red CNC kit ...
Latest blog entry: The WLToys V912
Old Apr 24, 2012, 02:00 PM
Joined Nov 2011
Yep I used the same alu CNC bit. I guess now they have just anodized it and called it a V911 but it's the same piece as the Solo Pro one.
The top piece is nice I guess only because of the inner pivot ball. I have yet to buy a plastic one that has a pivot ball, but I've seen some on eBay. Aluminium is easier to work with but heavier on the other hand.
andur is offline Find More Posts by andur
Old Apr 24, 2012, 02:09 PM
erdnuckel2's Avatar
Joined Mar 2009
Here is the one I got in the mail for one of my next "special projects" ...
http://www.aliexpress.com/product-gs...olesalers.html
Old Apr 24, 2012, 02:36 PM
Joined Apr 2012
Finally got my v911 in the mail last Friday! I ordered it April 2nd when I finally made the plunge into 4ch helis, moving up from my syma s107.
Out of the box I could tell it definitely needed a bit of trim work, but once I was able to accomplish that my beautiful new blue and white R6 board copter hovered like a charm in my living room. It came with the servo arms already in the second (advanced) holes, and I've been flying it around with ease with the controller turned to the lower rates. One of my batteries appears to have gone bad already, after probably 10 flight cycles. It charged, and when plugged into the heli the red light on the board no longer turns on, but the other battery worked fine. So I decided to recharge it, and then it suddenly powered the heli, bu upon flying it the heli seemed to disconnect itself from the controller and fall from the sky, and then turn off. I think it may be time to recycle that lipo.
The only think that I really don't like about this heli is of course the battery placement, I would love for someone to come up with a detailed guide as to how to rearrange the placement of the battery so it slides into the canopy, and wont come flying out every time I crash violently. And also my landing gear has broken at the joint on the front left side, and is now even floppier and flimsier than usual, are there any drop in upgrades for the landing gear, or any recommendations of what kind I could buy and easily modify to work for mine?
I'd say I get about a 5 min flight time per charge now after having lubed my engines and joints on the heli, but would love to achieve more. My metal swashplate should be getting here soon, as well as my MSR flybar paddles. Hopefully those will help my heli do semi-decently out in the wind, I've yet to try it outside though.
Lastly, my tail boom appears to have cracked, and the wires started coming out, so i took a little tape and wrapped it around to hold it together, and it seems to be doing fine so far. I intend to go home today after class and CA the tail boom in place, the cracks on the tail boom, the tail motor, and the front part of my skids where the battery connects since it keeps popping out when I crash.
All in all, I am very happy with my heli for the small amount of money it cost me! It's very fun having the ability to cruise around at speeds much higher than that of my s107, and perform quick piro's as I'm just about to smash into my walls. But of course, now I'm left wondering what's next, I really would love to get into 3d flying
-grandpappy
GrandpappyToke is offline Find More Posts by GrandpappyToke
Old Apr 24, 2012, 02:47 PM
Brosol
Brosol's Avatar
Canada
Joined Dec 2010
Another option is Solo Pro 270A swash
http://www.myrcmart.com/ne402270010a...te-p-4630.html
http://www.hobbyking.com/hobbyking/s...o_Pro_270.html
Pros:
- Has a main shaft pivot ball
- Weighs 1.22g
- Weighs less than CNC swash & XTreme SP swash = improved performance, agility, flight time
- 16mm, 19mm Swash hub arms
- Less expensive than XTreme SP swash
- Can be installed on Solo Pro, Bravo SX, V911 frame by rototating
the swash pin guide to match the SP 270A swash pin angle/orientation
- SP 270A swash hub & bearing can be transplanted to Solo Pro, Bravo SX, V911 swash base
I transplanted a SP 270A swash hub and bearing to a V911 swash base because my V911's swash pin guide was factory CA glued preventing rotation.
Brosol is offline Find More Posts by Brosol
Old Apr 24, 2012, 03:18 PM
Flying mostly micro's
BlueHavoc's Avatar
United States, WV, Vienna
Joined Mar 2007
Originally Posted by Killer Bee View Post
I found the high rate and wow... this thing really moves! I noticed it likes to nose dive and then balloon on FFF but that is just the nature of the fly bar I guess. For now I am going to focus on some indoor slow flying and try trimming out a little left drift. It also has a weird sound when hovering. I can only describe it as the sound a saw blade makes when you shake it.... whats that all about?
I've been pressing the button on the top left side of the Tx but I get no difference in the rates at all, is that the correct button?
BlueHavoc is offline Find More Posts by BlueHavoc
Old Apr 24, 2012, 03:27 PM
Canada
Joined Nov 2000
Thanx HK one at least ..Only.. requires $2.99 postage
Have an Ali setup already though
Bare is offline Find More Posts by Bare
Old Apr 24, 2012, 03:33 PM
Canada
Joined Nov 2000
Originally Posted by FCMan View Post
[IMG]
Certainly Better than I had assumed.
But that Foamy doesn't appear to fit the V911 overly well, 2 V911's I have so far bought arrived 100% unscathed in their WL 'factory' boxes .
Shipping costs somehow cheaper with the bag?
Old Apr 24, 2012, 03:45 PM
partly crasher
United States, OH, Cleveland
Joined Oct 2011
mine came in a cardboard box with a molded plastic inside perfectly safe , took 5 minutes to dig out the charger.
tonytester is offline Find More Posts by tonytester
Old Apr 24, 2012, 03:54 PM
partly crasher
Joined Oct 2011
I have 2 rates one 3 bar one 4bars.
ok it was not as calm as I thought, after ,2 indoor out of the box great flights ,
I recharged and went outside it was windy with little gusts say 10mph.
that damn thing flew into the wind across the wind and with the wind. I flew 2 paks I thought iwould have to go back inside. does anyone else have one with this much power.mine must be a cyborg or something.
Old Apr 24, 2012, 05:41 PM
Heli Mania
Hayabusa Heli's Avatar
PNW
Joined Dec 2010
Originally Posted by markkona View Post
Well today I finally discovered why my new tx has tamer rudder control on slow rates!!! The new tx when on slow rates only gives 50%(left stick) of throw when making turns or pirouettes while my older tx that came with my first corter has 75% of throws on both rudder and cyclic!! Could it be a one off or has WL toys adjusted it after reading our earlier comments in this thread about the handful rudder controls !!!
I'm betting someone from WL Toys reads this thread, and has tweaked the Tx to make the yaw rate not so wild ... same result at the "resistor mod" done by members here.
Hayabusa Heli is offline Find More Posts by Hayabusa Heli
Old Apr 24, 2012, 05:43 PM
Heli Mania
PNW
Joined Dec 2010
Originally Posted by Proud Infidel View Post
And no toilet bowl effect !!
Save it for page 538.
New Product Jiuchon 9C002, a Solo Pro clone? SoloProFan Micro Helis 103 Feb 29, 2012 02:24 PM
Discussion Interesting Solo Pro? Clone gordonzo Micro Helis 46 Nov 30, 2011 03:15 AM
Question Which 100 sized heli after Solo Pro? Tuc Micro Helis 16 Jun 13, 2011 01:52 PM
Sold $100 !NEW ARF Storm 250 (Trex Clone) With Align Upgrades, Tons of Extras! $100!! RChelisrule Aircraft - Electric - Helis (FS/W) 1 May 31, 2011 12:26 AM
