Old Apr 20, 2012, 01:43 PM
SG Mason Knives is offline
Find More Posts by SG Mason Knives
Canada, ON, Iroquois
Joined Mar 2012
Originally Posted by Apphoard View Post
Where did you get the Copterx TX? And how much? I want to get one but they say the Turnigy 9XR is coming. But I don't think I want to wait that long. 😄
I got it from RC Helicopter Select $118 Canadian dollars and then I paid the extra for EMS shipping so after taxes and such it was 139.79 Canadian. Its worth the extra for EMS shipping, I ordered on the 10th and it was here today. Now I am waiting for my Chaos 600, if I hadn't ordered that I would have just stuck with the stock Tx. I am not sure if I am going to get into all the other hacks and upgrades fr the CopterX Tx, I don't think I will need them
SG Mason Knives is offline Find More Posts by SG Mason Knives
Old Apr 20, 2012, 01:45 PM
Daryoon is offline
Find More Posts by Daryoon
Team WarpSquad
Daryoon's Avatar
United States, CA, San Diego
Joined Dec 2010
It's one of those properties to know and understand for the modder, tinkerer. So they can fine tune to their liking. The recommended action depends on what you're trying to achieve.
Daryoon is offline Find More Posts by Daryoon
Old Apr 20, 2012, 01:49 PM
andur is offline
Find More Posts by andur
Joined Nov 2011
Daryoon I got the idea when I was looking for some motors for the S107G, I found a site that had various micro motors of the same size, but with various resistances, like 1.7Ohm, 2.3Ohm, 3.3Ohm and I figure that must mean a different magnetic field, different revs etc. I thought I could measure the V911 motors resistance and then we could compare them to other motors and possibly measure thrust etc. I'm not too good at electronics to say what the resistance of the motors actually means to the helis flying.
andur is offline Find More Posts by andur
Old Apr 20, 2012, 01:54 PM
MassiveOverkill is offline
Find More Posts by MassiveOverkill
MassiveOverkill's Avatar
United States, SD, Custer
Joined Feb 2011
Lighter weight is always better indoors, outdoors........in windy conditions, being heavier can make you more stable.
A lighter boom and anything hung off of it is always better, but having your tail rotor further out gives it more authority, so it's a catch-22. This is why EQMOD did a shaft-driven mod with the tail motor being close to the frame, giving better center of gravity, and having a lighter tail since the motor isn't hung off of it.
I'd like to do a shaft driven tail motor mod, but now that I think of it, I think it may be easier to do some sort of vectored thrust mod. Simply mount the tail rotor somewhere on the frame, and attach an appropriate smaller ducted-fan, and use a straw or tube to direct the exhaust to the boom.
I wonder how big the smallest DC squirrel cage fan is.
Hmmmmm:
http://www.sunon.com/pro2.php?c1=10&c2=2
MassiveOverkill is offline Find More Posts by MassiveOverkill
Site Sponsor
Old Apr 20, 2012, 01:56 PM
dave1993 is offline
Find More Posts by dave1993
RC beginner
New York
Joined Oct 2008
Originally Posted by erdnuckel2 View Post
Could we kind of summarize what the recommended action is, based on all the information that gets passed along at the moment??
moral of the story: if you lighten the tail move battery aft. if tail gets heavier move it fore. bigger batteries are better than adding dead weights. using this philosophy i was able to lighten my syma enough to change 7 min flight time to 22 min. motors did not over-heat as predicted by some.
low ohms motors draw more power and require a lower voltage to stay cool. they will generally have a shorter life than high resistance ones. also note that there are core and coreless types, the latter being more efficient for a given weight.
dave1993 is offline Find More Posts by dave1993
Old Apr 20, 2012, 01:58 PM
Joined Mar 2012
ok, so what is the actual "lesson" to be learned from this??
light is good (ie better) - but not necessarily always?? You need to actually cut the longer than standard boom of the V911 short?? You have to move the CG without adding weight?? All of the above??
My opinion from personal experience with the S107 main motor as a replacement for a stock tail motor is don't do it.
Lighter is faster and quicker, but outdoors it will suck once you go past a certain point. What is it? I don't know and wont find out because I am not modding my V911, it works good enough for me and the new Tx takes care of any little issues with the rudder.
If you fly mainly outdoors, only add weight at the center of gravity, the flybar, or nose. Keep in mind there is a line to cross there too. Once you cross it the loss of flying time, speed and lift isn't worth the trouble.
I love my little CoRter, but I fly mainly outdoors. I decided to buy a larger helicopter for outdoor fun and keep the V911 for indoors and fair weather. Yes when I said larger I went a little overboard, the V911 is basically a 100 size heli and I ordered a 600. Sizing is pretty much the length of a rotor blade, the V911 has as I measure it a 94mm blade, the Chaos has a 600mm blade, thats an 53" rotor disc if you count the head and the ready to fly weight jumps from 32g to about 3000g.
Old Apr 20, 2012, 02:20 PM
Wasp09 is offline
Find More Posts by Wasp09
Canada, ON, Ottawa
Joined Jun 2009
Perhaps I should borrow your mod'ed CoRter since mine hasn't been doing well in the wind. Well I am just 45 minutes away. You probably won't need your small birds once you get your flying lawn mower going.
Wasp09 is offline Find More Posts by Wasp09
Old Apr 20, 2012, 02:33 PM
RicksterRC is offline
Find More Posts by RicksterRC
Joined Sep 2007
Hmmmmm:
Not to discourage you, but
Fans get WAY less efficient as they get smaller.
One half the size puts out WAY less than the 1/4 you would expect.
Think celing fan. They move an enormous amount of air with very little power.
Though I think a NOTAR V911 would be fantastic!
RicksterRC is offline Find More Posts by RicksterRC
Old Apr 20, 2012, 02:42 PM
Joined Mar 2012
My V911 is UNmodded and I think I will be still using it a fair amount when the wind is blowing too hard , or I can't get to an area that is big enough to take the flying mower of death into the air
In reality I wont have the big one built up for about another month and a half, right now all I have is the radio for it, the helicopter and the 2 gyros (one came with the kit, one for spending over $300) are still in transit. I don't expect them till the end of next week or early the week after. then its $150 worth of servos, $250 for motor and ESC, and $300+ for a good charger and a couple of 6S 5000mah batteries to power the beast.
Old Apr 20, 2012, 02:51 PM
Brosol is offline
Find More Posts by Brosol
Brosol
Brosol's Avatar
Canada
Joined Dec 2010
Hmmmmm:
Wow convert the V911 to a Notar!
MD NOTAR 520N (5 min 40 sec)
Brosol is offline Find More Posts by Brosol
Old Apr 20, 2012, 02:56 PM
Joined Feb 2011
I wonder how much static pressure our tail rotor assembly puts out at max thrust?
Site Sponsor
Old Apr 20, 2012, 03:45 PM
Apphoard is offline
Find More Posts by Apphoard
Apphoard's Avatar
United States, MD, Silver Spring
Joined Mar 2011
When I push up on the cyclic on the TX. Are both of the servos suppose to go down evenly?
Apphoard is offline Find More Posts by Apphoard
Old Apr 20, 2012, 03:50 PM
Proud Infidel is offline
Find More Posts by Proud Infidel
9958 gave me the toilet bowl
Proud Infidel's Avatar
United States, IL, Rockford
Joined Jan 2012
To fly forward, only the right servo moves down.
Proud Infidel is offline Find More Posts by Proud Infidel
Old Apr 20, 2012, 04:38 PM
tech69x is offline
Find More Posts by tech69x
Custom quad builder
tech69x's Avatar
United States, CO, Boulder
Joined Apr 2012
Will the tail motor from the 9958 work in the v911?
tech69x is offline Find More Posts by tech69x
Old Apr 20, 2012, 04:40 PM
latestart is offline
Find More Posts by latestart
Joined Apr 2012
Originally Posted by RicksterRC View Post
See if the blades "slide" side to side (as a pair) when holding the head.
If so, you have "the shudders".
Disassemble the main blades (two screws).
Fashion a thin washer to go over the pivot pin that holds the main blades.
Reassemble and make sure there is no more play, but not too much binding.
My second CoPter would be fine while manouvering, but in a hover it would shake terribly.
I used a rubber oring from a canopy.
All fixed.
Tried this RicksterRC, made no difference
latestart is offline Find More Posts by latestart
New Product Jiuchon 9C002, a Solo Pro clone? SoloProFan Micro Helis 103 Feb 29, 2012 02:24 PM
Discussion Interesting Solo Pro? Clone gordonzo Micro Helis 46 Nov 30, 2011 03:15 AM
Question Which 100 sized heli after Solo Pro? Tuc Micro Helis 16 Jun 13, 2011 01:52 PM
Sold $100 !NEW ARF Storm 250 (Trex Clone) With Align Upgrades, Tons of Extras! $100!! RChelisrule Aircraft - Electric - Helis (FS/W) 1 May 31, 2011 12:26 AM
