Old Apr 11, 2012, 04:50 PM
robbynaish is offline
Find More Posts by robbynaish
robbynaish's Avatar
Rome
Joined Oct 2003
I dont know if its another problem or im doing in a bad way...
When heli is starting lift, looking from back, it go on left side. So i trimmed the aileron on the opposite side, i trimmed to maximum, but it go always on sx direction...
Is it so unlucky model mine?
Tnks
Ale
robbynaish is offline Find More Posts by robbynaish
Old Apr 11, 2012, 04:52 PM
Jake8131 is offline
Find More Posts by Jake8131
Jake From Planet Mascoutah, IL
Jake8131's Avatar
United States, IL, Mascoutah
Joined Dec 2010
Are you talking about taking off from the floor? If so, they all lean to the left taking off. I give mine some right aileron when first lifting off and have no problems.
Jake8131 is offline Find More Posts by Jake8131
Old Apr 11, 2012, 04:53 PM
Jake8131 is offline
Jake8131's Avatar
Joined Dec 2010
Another video of the v911 in my living room. (anyone know a chant to stop the wind?).
http://www.youtube.com/watch?v=DNSzDg0-3g8
Old Apr 11, 2012, 04:54 PM
robbynaish's Avatar
Rome
Joined Oct 2003
yes yes... so no need to trim to maximum on right side, yes?
Tnks
Ale
Old Apr 11, 2012, 04:55 PM
MassiveOverkill is offline
Find More Posts by MassiveOverkill
MassiveOverkill's Avatar
United States, SD, Custer
Joined Feb 2011
Originally Posted by Ribble View Post
When I soldered on a JST battery connector, I scraped green enamel from unused copper areas on both sides of the board.and soldered (+) and (-) wires. I wasn't about to solder those thicker wires where the stock wires go.
And it is so easy to melt any nearby plastic.
My flying is getting faster and faster. Didn't used to break anything. Now I'm killing flybars. Ordered 4 and later 21 more.
Score card:
Two undamaged
Two need flybars
One has repairable flybar that I broke again ten minutes ago.
You say you ordered flybars - you didn't order enough of them. There is going to be a rush on flybars with warm weather coming and flying skills get better, faster, and riskier.
The cold temperatures must be the reason why you're breaking them, making the plastic brittle. I can't imagine ever breaking a flybar.
MassiveOverkill is offline Find More Posts by MassiveOverkill
Site Sponsor
Latest blog entry: MassiveRC ZMR PDB
Old Apr 11, 2012, 05:00 PM
Hayabusa Heli is offline
Find More Posts by Hayabusa Heli
Heli Mania
Hayabusa Heli's Avatar
PNW
Joined Dec 2010
+1 ... the flybar on my V911 literally bent into a U-shape after a crash that caused it to go in between the canopy and frame post for the canopy, and get caught behind the post. Just straightened it out by hand and still flying with that flybar.
Hayabusa Heli is offline Find More Posts by Hayabusa Heli
Old Apr 11, 2012, 05:01 PM
SoloProFan is offline
Find More Posts by SoloProFan
Fan of just about anything RC
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Tnks
Ale
You only need to trim to make it hover in one place. When taking off from the floor, you need to add a little right stick to compensate. Most helis tend to drift when close to the floor, the turbulence from the air from the rotors bouncing back from the ground messes things up. Try to get at least one meter above the ground, then check if the heli stays in the same place, or still needs some adjustment through trim.
SoloProFan is offline Find More Posts by SoloProFan
Old Apr 11, 2012, 05:02 PM
Heli Mania
PNW
Joined Dec 2010
When I take off I punch the throttle to make the heli "jump" up quickly ... that prevents any side drifting during takeoff.
Old Apr 11, 2012, 05:16 PM
Wasp09 is offline
Find More Posts by Wasp09
Canada, ON, Ottawa
Joined Jun 2009
Score card:
Two undamaged
Two need flybars
I am not that aggressive, perhaps I don't have the warrior gene...
I had bounced my V911 off a hard tennis court a number times flying in strong wind. Nothing is broken so far.
The canopy exploded and the front part of the landing skids totally disappeared when my FBL 4#6 dived a few feet into the same tennis court first time.
I cannot complain about the V911.
Thanks for the advice on flybars. I have to watch my spending though.
I can afford quite a lot of flybars but my wife is watching my credit card statements.
Anyway I intend to remove/replace the flybar weight and cut and rejoin to shorten the flybar when the spares arrive.
We'll see if anything works out. If nothing works, there is little point of stocking up.
Have fun.
Wasp09 is offline Find More Posts by Wasp09
Old Apr 11, 2012, 05:30 PM
Ribble is offline
Find More Posts by Ribble
Crash and learn
United States, PA
Joined Dec 2011
You have to get the V911 off the ground swiftly. If you sit and spin it will fall over on left side.
Try taking off from the edge of a cardboard box. Give it a little forward stick, then throttle. Flies off no problems.
Ribble is offline Find More Posts by Ribble
Old Apr 11, 2012, 05:37 PM
Jake8131 is offline
Jake8131's Avatar
Joined Dec 2010
Tnks
Ale
Yes...just use the tx...give it right aileron with the stick and take off..learned that with my msr.
Old Apr 11, 2012, 05:47 PM
tech69x is offline
Find More Posts by tech69x
Custom quad builder
tech69x's Avatar
United States, CO, Boulder
Joined Apr 2012
Got my v911 today I love this bird flu great out of the box gone thrue 2 batt 4 to 5 min fly time and I can fly it not like my 9958 I don't have to fight it
Going to fly some more be back later
tech69x is offline Find More Posts by tech69x
Old Apr 11, 2012, 06:25 PM
Joined Feb 2011
After you've spent more time with her, please update my thread:
http://www.rcgroups.com/forums/showthread.php?t=1578692
Thanks.
Site Sponsor
Old Apr 11, 2012, 06:31 PM
Ribble is offline
Crash and learn
United States, PA
Joined Dec 2011
Yes, and it will fly however you want it to fly. After waiting so long, it has to be far better than you ever expected.
Time to order another now that this one is getting old.
Old Apr 11, 2012, 06:33 PM
Username> is offline
Find More Posts by Username>
Joined Dec 2007
Hi,
i tried do a small video, i think it explain good what is the problem
http://www.youtube.com/watch?v=i9KYzqKL54g
What do you think?
PS: i sent u PM, but i get an automatic answer yr Pm box is full and u sent me email, that i didnt get
Many thanks
Ale
That's exactly the same problem as I and a friend had with our pants servos.
I hosted a " servo fix " thread on here somewhere about a Month ago.
Just remove the servo and follow the instructions, or if you can't be bothered, just buy a new PCB.
It's an easy job either way.
Username> is offline Find More Posts by Username>
Reply With Quote  (Disabled)
New Product Jiuchon 9C002, a Solo Pro clone? SoloProFan Micro Helis 103 Feb 29, 2012 02:24 PM
Discussion Interesting Solo Pro? Clone gordonzo Micro Helis 46 Nov 30, 2011 03:15 AM
Question Which 100 sized heli after Solo Pro? Tuc Micro Helis 16 Jun 13, 2011 01:52 PM
Sold $100 !NEW ARF Storm 250 (Trex Clone) With Align Upgrades, Tons of Extras! $100!! RChelisrule Aircraft - Electric - Helis (FS/W) 1 May 31, 2011 12:26 AM
