Old Apr 08, 2012, 09:37 AM
bobepine is online now
Find More Posts by bobepine
bobepine's Avatar
Joined Jun 2011
My V911's new look. Flight video coming up soon.
V911 with Xtreme flybar and canopy mod (2 min 25 sec)
Chris
bobepine is online now Find More Posts by bobepine
Site Sponsor
Old Apr 08, 2012, 10:20 AM
cgpirre is offline
Find More Posts by cgpirre
cgpirre's Avatar
Belgium
Joined Dec 2011
Then you're more lucky then me, I had a bad crash yesterday, and one end of the flybar-noodle was bend -underneath- the canopy o_O
I managed to bend it back without breaking, and it still flies, luckily.
Can't wait for my new flybars to arrive so I can do some experimenting. I can't do anything else beside slow turns without getting violent flybar strikes.
cgpirre is offline Find More Posts by cgpirre
Old Apr 08, 2012, 10:21 AM
mcmoyer is offline
Find More Posts by mcmoyer
450x, 180CFX
United States, TX, Burleson
Joined Feb 2012
After my flybar strikes this morning....I'm eyeing that flybar replacement.
That canopy is really sharp bob pine
mcmoyer is offline Find More Posts by mcmoyer
Old Apr 08, 2012, 10:54 AM
erdnuckel2 is offline
Find More Posts by erdnuckel2
erdnuckel2's Avatar
Joined Mar 2009
If you are talking about this one here:
http://www.miracle-mart.com/store/in...oducts_id=7023
that is a really great idea IMHO ... have that on mine for a while now, and ever since I installed it, I have not even been able to induce a flybar strike anymore ...
Old Apr 08, 2012, 11:21 AM
Jake8131 is offline
Find More Posts by Jake8131
Jake From Planet Mascoutah, IL
Jake8131's Avatar
United States, IL, Mascoutah
Joined Dec 2010
http://youtu.be/iIypQqMSHwk
Chris
I have the cx nano....is the canopy a direct fit??
Jake8131 is offline Find More Posts by Jake8131
Old Apr 08, 2012, 11:22 AM
cgpirre is offline
cgpirre's Avatar
Belgium
Joined Dec 2011
Are there any other V911 upgrades or parts you would advise to get from miracle-mart?
Got some nice monnies for my birthday, and I'm putting it all into my toy-budget, of course, so I might as well get some extras if I decide to get the CF flybar
Spare main/tail motor, different canopy, batteries, charger...?
Old Apr 08, 2012, 12:31 PM
Apphoard is offline
Find More Posts by Apphoard
Apphoard's Avatar
United States, MD, Silver Spring
Joined Mar 2011
I don't know, after my motor went south, I replaced it with a blade msr motor and now my 911 has a lot more thrust and it's a lot more quiet. Almost makes me wish I would have replaced it earlier.
I have a spare MCPX motor I bought for my Genius. I guess it's not the same as a MSR motor is it? Anyone know if it will work?
I ordered my V911 Friday from Bang good because of the deal for 40.00. But now I don't want to wait. I saw a seller on Ebay for 49.00 in NY state that should get to me in three days.I'm going to get it.
What should I buy for the little Heli as for spares, mods, and extra batteries. The MSR motor sounds good more power and quieter. Because this is going to be my main indoor Heli. Any suggestions would be greatly appreciated.
Apphoard is offline Find More Posts by Apphoard
Old Apr 08, 2012, 12:35 PM
bobepine's Avatar
Joined Jun 2011
That's the flybar shown in the picture I posted above. I can confirm that it eliminates flybar strikes. Flies very well, too, in my opinion.
Frank,
The Nano canopy is too small. I had to dremel part of it to add clearance for the linkage. It's tight. It just clips on there. It works, but it moves if you crash. Might be a good thing as it may not break as easily if it can move on impact.
In any case, I like that canopy. It's lighter and smaller than the MIA S300 canopy, and the built is nicer. Looks better up close and feels sturdier.
Best,
Chris
Site Sponsor
Latest blog entry: Armattan F1 Lineup Revealed
Old Apr 08, 2012, 01:05 PM
Proud Infidel is offline
Find More Posts by Proud Infidel
9958 gave me the toilet bowl
Proud Infidel's Avatar
United States, IL, Rockford
Joined Jan 2012
Cheapest batteries are at aliexpress (wtotoy.com), 5 for $12.99. The ones I got are 42 mm long, which are likely the 130 mAh version. In my many crashes, only the canopy got badly cracked and the landing gear got busted, which I was able to repair.
One of the cheapest BNFs is at aliexpress (wtotoy.com) at $21.99. They went from that price to $23.99, then back down to $21.99.
Proud Infidel is offline Find More Posts by Proud Infidel
Old Apr 08, 2012, 01:41 PM
Ribble is offline
Find More Posts by Ribble
Crash and learn
United States, PA
Joined Dec 2011
Originally Posted by a_novice View Post
my tail struck the wall in my house. The tail blade actually came off, so I just pushed it back on. However now when I turn up the throttle, the heli wants to spin constantly and I can't trim it out.
The bald seems fine, the heli seems fine, the left yaw control stops the tail from spinning and right yaw seems to apply more tail rotor power.
Test the gyro.
Hold the V911 in your hand and add throttle to get the tail motor turning.
Rotate clockwise and the tail motor should slow.
Rotate counter-clockwise and the tail motor should speed up.
You also should closely inspect the main gear, shaft, and everything up to the tip of the flybar. Look for links pushed in off the balls
There may be nothing wrong with the tail.
Ribble is offline Find More Posts by Ribble
Old Apr 08, 2012, 02:14 PM
andur is offline
Find More Posts by andur
Joined Nov 2011
I found that holding the heli in your hands and throttling up might not make the tail motor spin, because the gyro senses the heli isn't spinning around. You should check these things on the floor or the table to make sure. I almost threw a motor away because I thought it wasn't working but I only checked to see if it worked in my hand. Only later after soldering it for a few times did I notice putting it on the floor made it work very nicely!
andur is offline Find More Posts by andur
Old Apr 08, 2012, 02:15 PM
Apphoard is offline
Apphoard's Avatar
Joined Mar 2011
Thanks for the info. I think I will order one of those BNF sooner or later that's a great deal. Also I will probably order the lipos to. But I want to make sure they are the 130's. With 10mah I wonder if there is even a difference though.
Old Apr 08, 2012, 02:38 PM
markkona is offline
Find More Posts by markkona
when is the wind stopping??
markkona's Avatar
Malta, Marsaskala
Joined Apr 2011
that was crazy! I was a a pretty good altitude with my copter and pulling some hard aileron moves when I had a flybar strike. It struck hard enough to pop the canopy off and I watched it slowly fall to the ground.
The heli, though, stayed aloft. Only problem is that without the canopy, that heli is really quiet with the blade MSR motor it's pretty darn hard to see without the canopy!
took me a couple seconds to find it. Luckily this heli will just hover with any input from the sticks!
Well thats strange cos without the canopy my v911 will drift backwards not hover unless you put a lot of forward trim!!
markkona is offline Find More Posts by markkona
SG Mason Knives is offline
Find More Posts by SG Mason Knives
Canada, ON, Iroquois
Joined Mar 2012
What is being explained is how to test to see if the gyro is working. If you hold on to the heli and throttle it up till the tail rotor spins, rotating the heli clockwise and counter clockwise will cause the tail motor to speed up or slow down, you can hear it and feel it try to correct in your hand.
SG Mason Knives is offline Find More Posts by SG Mason Knives
Old Apr 08, 2012, 02:46 PM
IceRail is offline
Find More Posts by IceRail
We NEED a LiPo w a USB plug!!!
IceRail's Avatar
Orland Park, Illinois
Joined Feb 2010
Whatever they are, like PI mentioned, they're longer than the ones included with the complete factory v911 set.
I ordered ten (and 2 BnF v911's) from Ali in the middle of March and they arrived last week. I know they're longer because they don't even come close to fitting in the battery slots in the factory box (the ones included drop right in .. loosly).
They ARE at least as strong as the original ones though, and mine last a good minute longer.
I'm ordering more as soon as I come up with an excuse to buy 2 more short CORPTERs.
IceRail is offline Find More Posts by IceRail
New Product Jiuchon 9C002, a Solo Pro clone? SoloProFan Micro Helis 103 Feb 29, 2012 02:24 PM
Discussion Interesting Solo Pro? Clone gordonzo Micro Helis 46 Nov 30, 2011 03:15 AM
Question Which 100 sized heli after Solo Pro? Tuc Micro Helis 16 Jun 13, 2011 01:52 PM
Sold $100 !NEW ARF Storm 250 (Trex Clone) With Align Upgrades, Tons of Extras! $100!! RChelisrule Aircraft - Electric - Helis (FS/W) 1 May 31, 2011 12:26 AM
