Old Apr 07, 2012, 06:21 AM
dave1993 is offline
Find More Posts by dave1993
RC beginner
New York
Joined Oct 2008
most battery damage occurs from too fast charging. not overdischarge which is the popular theory. truth is the slower you charge the longer they last. check voltage with a meter and make sure they get up to 4.0-4.2v though. if motors are not running hot or no obvious mechanical issues then the problem is probably your battery. i added a better connector to mine so lower cost ($1) cells can be used and i can swap out with my s107s.
dave1993 is offline Find More Posts by dave1993
Old Apr 07, 2012, 06:38 AM
SG Mason Knives is offline
Find More Posts by SG Mason Knives
Canada, ON, Iroquois
Joined Mar 2012
Originally Posted by Hayabusa Heli View Post
Nothing new ... that seller just put a "B" after V911 for some unwarranted reason. It's maybe possible that the "B" is something WLToys put on the model number to signify some level of improvements we've seen lately ... but the description says nothing like that.
The "WLToys-Heli-V911-B" is the part number for the V911 at that store. If you look at the title it says:
WL V911 Micro Helicopter (Black & Orange) WLToys-Heli-V911-B
What is misleading is that there is no comma between the product name and part number. With all the changes, what is coming off the factory floor right now almost could be called the B model
SG Mason Knives is offline Find More Posts by SG Mason Knives
Old Apr 07, 2012, 06:52 AM
nr1 is offline
nr1
Find More Posts by nr1
nr1
Joined Feb 2012
Originally Posted by nr1 View Post
Can someone tell me the cable diameter of the tail motor cable?
(I have to replace it by a new one)
Again this question.
I got a 0.8 mm (outer diameter) | 0.05 mm˛ cable, but this is too thick.
Which gauge size is the cable for the tail rotor?
nr1 is offline Find More Posts by nr1
Old Apr 07, 2012, 08:46 AM
MassiveOverkill is offline
Find More Posts by MassiveOverkill
MassiveOverkill's Avatar
United States, SD, Custer
Joined Feb 2011
Originally Posted by BlackSh33P View Post
Hello all, my first post here.
I bought the V911 from HK in December but only got it 2 days ago, I won't bore anyone with the story that to HK.
I followed the thread religously after I oredered my 911 but lost interest after HK me around for so long. Now I have finally got it, it has multiple problems.
I cannot keep it airborn for more than 60 seconds as the batteries do not seem to charge or hold a charge. Not sure how to figure out what is wrong, charger or battery or even Heli.
TBE but it is hard to tell without getting flight time up.
My Heli on the last short flight started to lurch in the air and make a grinding noise.
What to do, where to start, is there a blog or sticky somewhere I can look at?
Any help greatly appreciated, I read everyones posts early on and thought I was buying a great Heli, I think it may still be but it is so frustrating. The Co Ax I bought at the same time was great to learn on and got repaired several times over the 2 days I flew it but I really want to get the 911 flying.
Is there a better battery charger, my skid does not come off so cannot do the skid change.
Check your battery contacts on both the charger as well as the heli. Take small pin and pry the contancts out a little so there's more tension on the leaf springs on both the charger and heli. Clean the battery contacts with rubbing alcohol (on heli, charger, and battery). You are charging with the USB charger and not the onboard charger in the transmitter right?
MassiveOverkill is offline Find More Posts by MassiveOverkill
Site Sponsor
Latest blog entry: MassiveRC ZMR PDB
Old Apr 07, 2012, 09:04 AM
Proud Infidel is offline
Find More Posts by Proud Infidel
9958 gave me the toilet bowl
Proud Infidel's Avatar
United States, IL, Rockford
Joined Jan 2012
Originally Posted by Ribble View Post
I am about to trim the trailing edges to lower the pitch ... to get the blades spinning faster to handle more wind ... Comments?
I don't like the idea at all.
Max out forward trim to increase forward speed.
Another idea is to add 1 to 2 grams of additional weight. That'll force you to increase throttle, which will increase forward speed. You'll want a drug dealers' scale if you don't already have one.
Proud Infidel is offline Find More Posts by Proud Infidel
Old Apr 07, 2012, 09:09 AM
Joined Jan 2012
If it looks like this, you need a new motor.
V911 Chicken Dance (1 min 7 sec)
On my Xieda 9958, the toilet bowl effect is easily seen upon lift off.
Old Apr 07, 2012, 11:42 AM
Hayabusa Heli is offline
Find More Posts by Hayabusa Heli
Heli Mania
Hayabusa Heli's Avatar
PNW
Joined Dec 2010
The 9958 TBE ghost lives through you ... LOL.
Hayabusa Heli is offline Find More Posts by Hayabusa Heli
Old Apr 07, 2012, 12:40 PM
Danlb25 is offline
Find More Posts by Danlb25
United States, IA, Glenwood
Joined Jan 2012
It's become almost a personal challenge to me, I would love to have Infidels 9958 for a while just to prove I could get the TBE out of it
Danlb25 is offline Find More Posts by Danlb25
Old Apr 07, 2012, 01:10 PM
Joined Jan 2012
Too late now, it became a parts donor!
Old Apr 07, 2012, 01:52 PM
cedddddd is offline
Find More Posts by cedddddd
Joined Apr 2011
Hi everybody,
I'm pretty new in the RC heli world so ...
I just received my v911 yesterday .
I noticed different things that made me wondering if everything is alright.
1) I don't have the 2nd screw on my PCB (the one on the pic), is it normal?
2) I find my v911 drifting to the left a lot, I can manage it with the "software trim" but I think it need A LOT of trimming. How can I fix that the "hardware" way? I try to unscrewed the black part on the servo's arm but after reflexion I don't think it is the good way to do it...
3) Is it normal that my V911 "whistle" like when you play a saw with a bow ???
Thank you very much
cedddddd is offline Find More Posts by cedddddd
Old Apr 07, 2012, 02:00 PM
madmito is offline
Find More Posts by madmito
my precious Corter
madmito's Avatar
Joined Jan 2012
the screw should be there.
For mechanical trimming search my posts, couple of pages ago.
I never played saw with a bow, LOL !
madmito is offline Find More Posts by madmito
Old Apr 07, 2012, 02:07 PM
talktodan is offline
Find More Posts by talktodan
Joined Dec 2004
Mine does this too.
talktodan is offline Find More Posts by talktodan
Old Apr 07, 2012, 02:20 PM
tech69x is offline
Find More Posts by tech69x
Custom quad builder
tech69x's Avatar
United States, CO, Boulder
Joined Apr 2012
Can I get parts for the V911 in the U.S.
tech69x is offline Find More Posts by tech69x
Old Apr 07, 2012, 02:25 PM
Joined Mar 2012
Yes you can there are a couple of places that sell them. You will pay more for them then if you ordered from China/Hong Kong, but delivery will be faster
The one place that I have book marked is
http://helircstore.com/shop/index.ph...ry&path=60_108
Old Apr 07, 2012, 02:53 PM
tech69x is offline
Custom quad builder
tech69x's Avatar
Joined Apr 2012
New Product Jiuchon 9C002, a Solo Pro clone? SoloProFan Micro Helis 103 Feb 29, 2012 02:24 PM
Discussion Interesting Solo Pro? Clone gordonzo Micro Helis 46 Nov 30, 2011 03:15 AM
Question Which 100 sized heli after Solo Pro? Tuc Micro Helis 16 Jun 13, 2011 01:52 PM
Sold $100 !NEW ARF Storm 250 (Trex Clone) With Align Upgrades, Tons of Extras! $100!! RChelisrule Aircraft - Electric - Helis (FS/W) 1 May 31, 2011 12:26 AM
