Old Mar 19, 2012, 04:17 PM
Proud Infidel is offline
Find More Posts by Proud Infidel
9958 gave me the toilet bowl
Proud Infidel's Avatar
United States, IL, Rockford
Joined Jan 2012
Originally Posted by markkona View Post
WOW are you sure your 9958 has TBE???
Yep, the circular motion got bigger the longer I hovered.
Proud Infidel is offline Find More Posts by Proud Infidel
Old Mar 19, 2012, 04:22 PM
afloyd82 is offline
Find More Posts by afloyd82
ladybird, miniCP, msrx, 4F180
Joined Jan 2012
did you try to counter it with cyclic input? Because you CAN tame TBE sir.
afloyd82 is offline Find More Posts by afloyd82
Old Mar 19, 2012, 04:24 PM
afloyd82 is offline
Joined Jan 2012
Just took the corter out into some wind weather, as WL toys says " first helicopter than can fly in wind weather grade 3-5".
I took it out into wind weather grade 10-15 and it got thrown around like a ragdoll. Just keeping to from floating away was a challenge. Its not good for anything more than 5mph winds unless you just have a lot of space because it will get tossed around.
Old Mar 19, 2012, 04:25 PM
gordonzo is offline
Find More Posts by gordonzo
Different fly 4 different guy
gordonzo's Avatar
Joined Jan 2011
Originally Posted by Killer Bee View Post
I had read on one of these pages that quality and performance can vary based on the color you choose. Has anybody found this to be true recently with the new design changes?
We have black and red and they fly exactly the same.
The only difference could be if they come from different production batches, and that is only a guess.
gordonzo is offline Find More Posts by gordonzo
Old Mar 19, 2012, 04:37 PM
stonecutter is offline
Find More Posts by stonecutter
Sir Crashalot
stonecutter's Avatar
Joined Oct 2011
Originally Posted by cgpirre View Post
This has probably been posted before, but the thread is a bit big to quickly browse through.
Is there a shop that ships these paddles to Europe for an acceptable price?
Links and pictures of the V911 with paddles are more then welcome!
Here's mine with xtreme CF. Added bonus of the paddles is that you can adjust the radius, which varies the controllability/responsiveness to your liking.
stonecutter is offline Find More Posts by stonecutter
Old Mar 19, 2012, 06:03 PM
Wasp09 is offline
Find More Posts by Wasp09
Canada, ON, Ottawa
Joined Jun 2009
Well, you have the white tail rotor on your yellow and black main rotor. The white rotor seems a bit bigger than the black (visually??) on mine. That may be an upgrade too.
Wasp09 is offline Find More Posts by Wasp09
Hayabusa Heli is offline
Find More Posts by Hayabusa Heli
Heli Mania
Hayabusa Heli's Avatar
PNW
Joined Dec 2010
Originally Posted by SG Mason Knives View Post
So I am really enjoying this little helicopter out doors, still working on my right hand turns though. It seems to whip around no matter how little rudder I give it, while the left turns are much smoother on the rudder.
On these single blade fixed pitch helis, you need to add right aileron (right roll) with the yaw in right hand turns to make it bank and not slide through the corner.
Hayabusa Heli is offline Find More Posts by Hayabusa Heli
Old Mar 19, 2012, 06:51 PM
derehu1234 is offline
Find More Posts by derehu1234
Joined Jan 2012
I just experienced that the new tail motor mount is nowhere as good as the old one. The old one is more secure while the new one can just pop the white top(where the brushes are) on the tail motor off when striked.
derehu1234 is offline Find More Posts by derehu1234
Old Mar 19, 2012, 07:33 PM
SG Mason Knives is offline
Find More Posts by SG Mason Knives
Canada, ON, Iroquois
Joined Mar 2012
I am banking, but it is such a fine line on the rudder that it either just slides to the right or snaps around, I am sure its just me needing to get a bit better at finessing it around
SG Mason Knives is offline Find More Posts by SG Mason Knives
Old Mar 19, 2012, 07:40 PM
Joined Mar 2012
You know I will admit to slamming mine a few times, OK more than a few times, but the only problem I have had with the new design is how they ran the wires. I nearly severed one of the tail rotor wires and started getting some shorting causing the heli to twitch under full power.
Old Mar 19, 2012, 08:18 PM
Jake8131 is online now
Find More Posts by Jake8131
Jake From Planet Mascoutah, IL
Jake8131's Avatar
United States, IL, Mascoutah
Joined Dec 2010
Wives Are Funny
My wife re-arranged this just for me.....
"I want that helicopter..ooooohhh....give me that helicopter...ooohhhh!!!"
Wife is funny!
Jake8131 is online now Find More Posts by Jake8131
Old Mar 19, 2012, 08:24 PM
Heli Mania
PNW
Joined Dec 2010
I've found that if the flybar pivot screw is too tight on a V911, it will induce TBE. Loosed it up a little bit at a time until the TBE goes away.
Old Mar 19, 2012, 09:10 PM
Bare is online now
Find More Posts by Bare
Canada
Joined Nov 2000
IF yer lusting after flybar paddles... buy 'em from another heli.
My old esky FP ones could easily be modded to fit.
Check out Xheli's or Heli directs' Esky FP heli parts.
Bare is online now Find More Posts by Bare
Old Mar 19, 2012, 10:15 PM
bobepine is offline
Find More Posts by bobepine
bobepine's Avatar
Joined Jun 2011
If there is ANYTHING rubbing or too tight in the head assembly, the heli will show TBE. All linkages, flybar, mixing arms and horizontal shaft have to allow smooth and unrestrained movement.
Someone mentioned earlier wanting to tighten the flybar to reduce flybar strikes. This would not work. It would make the heli unstable and likely to have more flybar strikes.
Just my 2 cents.
Chris
bobepine is offline Find More Posts by bobepine
Site Sponsor
Latest blog entry: Armattan F1 Lineup Revealed
Old Mar 19, 2012, 11:01 PM
jameschen072 is offline
Find More Posts by jameschen072
The flightless bird
jameschen072's Avatar
Joined Aug 2004
Hey everyone, I just finished talking to WLToys and passed on our comments.
So here are some new info:
-Swashplate has been fixed (He said that the newer batches shouldn't experience any problems with the swashplate separating)
-The next batch of TXs will show the correct mode (instead of mode 1 regardless)
- An icon showing Low/High rates is in the works... but probably wont be seen on recent revisions.
Finally, the word "borken" will be changed to "broken" on the main rotors.
I will talk to him again in a few hours because he will provide me with a list of improvements..
anything else you guys want me to pass to him?
I'm really looking forward to future generation V911s
jameschen072 is offline Find More Posts by jameschen072
Latest blog entry: The Fei-Lun FT011 Review
New Product Jiuchon 9C002, a Solo Pro clone? SoloProFan Micro Helis 103 Feb 29, 2012 02:24 PM
Discussion Interesting Solo Pro? Clone gordonzo Micro Helis 46 Nov 30, 2011 03:15 AM
Question Which 100 sized heli after Solo Pro? Tuc Micro Helis 16 Jun 13, 2011 01:52 PM
Sold $100 !NEW ARF Storm 250 (Trex Clone) With Align Upgrades, Tons of Extras! $100!! RChelisrule Aircraft - Electric - Helis (FS/W) 1 May 31, 2011 12:26 AM
