My take on flybar strikes...
There are two kinds. The canopy strike and the tail boom strike. Of the two, the canopy strike is easier to recover from. I think the curvature of the canopy aids the flybar to quickly get past the strike should one occur. The tail boom strike on the other hand is more severe, usually takes you out of the sky. Partly because of the maneuver you're doing to cause it to happen, and partly because when it contacts the tail boom, it's more of an abrupt stop. The issue with soliciting feedback about flybar strike is that it's usually missing context. The missing context is how the person generally flies their v911. Additionally where they fly, whether it's flown indoors or outdoors, makes a huge difference in encountering flybar strikes. And lastly, how they handle the control sticks...stick masher or gentle finesse. I can give a lot of details from my personal experience. Both on the Solo Pro and v911 and 9958BSX (a 9958 modded with a Nine Eagles head) because I have experience with all three. The frequency of flybar strikes are different between the them, with strikes on the 9958BSX, follow by the v911 and then the Solo pro. However, it will be a lengthy post. Therefore...
Anyways, that's brief overview IMHO. |
Latest blog entry: Syma S105 Battery Mod
It is similar in size to my HBFP, so about 300 size, but this one is easy to hover and fly. It flys like the smaller fp's, but with extra momentum to account for, especially on fast, banking turns. I hover it easily in my living room but it needs a large area to actually fly. I added the MJX camera attachment which I am still evaluating. I have about 10 flights on it so far. Flight and camera videos will follow soon. But I have to say that the v911 made the biggest impression on me! After reading of some of the problems people are having with it I was pleasantly surprised at how well it flys. I don't find it noisy nor slow. Give it some fwd elevator and a shot of throttle and it takes off very well! Here is my F45. |
@afloyd82:
Don't give up on it yet. My v911 would have fried if I had not read this thread and saw the many people who had smoked RX. So I gave it a once over before I hooked up the battery for the first time. Glad I did because I saw that the two pads where the main motor wires soldered to had a huge blob of solder that bridge both points together. I knew that couldn't be good. So I used a vacuumed sucker to suck the solder blob off. What I learn was there was a capacitor(?) underneath that huge blob. So surely the RX would have smoked had I inserted battery to it without fixing the problem. The second spare RX went to Heli Pad, and that one had a servo issue where it would go past the 180 range of motion and get stuck. Even limiting it's range by adjusting the end point so it only reached 70 degrees of travel via the Turnigy 9x only helped but not fix the issue. Every now and then, it would still move past the 180 mark and get stuck. I learn that the middle point of the three points the servo POTS solder to contacts a large metal plate within the servo. This in turns contact/touches the a plastic wiper arm. Too much heat here will melt part of the plastic nub, causing the servo to act up. So then have to be very careful at the factory. You'll notice that on the Align Trex 100, though it shares a similar servo. The POTS used is more like the Solo Pro and 9958. It sticks out in the PCB like the servo motor does on the v911. I suspect the high potential for melting the plastic servo wiper is why so little solder is sometimes used on the POTS solder points. In some photos, I see gaps between the PCB board and POTS's legs. Anyways, my point is..if you can get past some of these issues...should you be unfortunate to encounter them, it is a fun heli to own and fly. But you already knew that. So...If you're replacing the head, you would expect the need to do some mechanical trimming. If the head is from Solo Pro, then you have to change out the blades too, because the pivot pins are a smaller diameter on the Solo Pro design. The v911 blades will have too much play. Anyways, if your v911 is moving left like it has left aileron input, then giving it right aileron will cancel that out. That means, you have to lengthen(?) the right servo link. Give some right cyclic input. The direction the arm moves determine whether you need to lengthen or shorten your link. Give it a try and let us know. It should be relatively quick to do. |
How do you oil the motor and what did you use ? Could beard trimming oil be any good ? |
Joined Jan 2012
I tried dropping in motor oil into the small holes with a toothpick. It kinda worked. Then I used some clipper oil (same as beard trimmer I would assume) and that seemed to work quite well. My motor was "snatching" causing it to fall out of the sky like a wounded duck. This seemed to fix the problem as it hasn't happened again...yet... Your mileage may vary.
I'm thinking of moving from electrical tape to masking tape. I don't like the adhesive on the electrical tape, not strong enough. |
| Thread Tools | |
| New Product Jiuchon 9C002, a Solo Pro clone? | SoloProFan | Micro Helis | 103 | Feb 29, 2012 02:24 PM |
| Discussion Interesting Solo Pro? Clone | gordonzo | Micro Helis | 46 | Nov 30, 2011 03:15 AM |
| Question Which 100 sized heli after Solo Pro? | Tuc | Micro Helis | 16 | Jun 13, 2011 01:52 PM |
| Sold $100 !NEW ARF Storm 250 (Trex Clone) With Align Upgrades, Tons of Extras! $100!! | RChelisrule | Aircraft - Electric - Helis (FS/W) | 1 | May 31, 2011 12:26 AM |
