Old Mar 03, 2012, 07:25 AM
madmito is offline
Find More Posts by madmito
my precious Corter
madmito's Avatar
Joined Jan 2012
Originally Posted by cpuken View Post
I really do need to write down what parts I'm ordering because I keep double and triple ordering stuff (sometimes accidentally).
Ken
Yes, it's the same thing I tell my wife
madmito is offline Find More Posts by madmito
Old Mar 03, 2012, 08:06 AM
tonytester is offline
Find More Posts by tonytester
Yo R Wee Too Lo
United States, OH, Cleveland
Joined Oct 2011
geeze why did they send me this
must be a computer mistake. when I was a kid 1955 , I ordered a battle ship for .25cents and 2 box tops kellogs. every couple days a battle ship came in the mail.
no email or long distance for us at that time my mom had to write a letter to get them to stop. I could not fit in the bathtub also couldn't afford batteries for all of them either.
Tonytester
tonytester is offline Find More Posts by tonytester
Old Mar 03, 2012, 08:56 AM
Proud Infidel is offline
Find More Posts by Proud Infidel
9958 gave me the toilet bowl
Proud Infidel's Avatar
United States, IL, Rockford
Joined Jan 2012
Originally Posted by jameschen072 View Post
Hey guys,
We have micro-heli gatherings at our club and a friend thought of an ingenious idea! Charging the batteries from a portable mobile phone charger!!
I charge mine with a cell phone charger also. Here's a Motorola USB charger at Amazon for $4.59 with free shipping.
Proud Infidel is offline Find More Posts by Proud Infidel
Old Mar 03, 2012, 09:07 AM
Joined Jan 2012
Originally Posted by Hayabusa Heli View Post
Soldering them is best ... twisting might work, but it's subject to failure.
When I had to replace the defective motor on my V911 with the motor from my Xieda 9958 with a toilet bowl effect, I just twisted the suckers.
That was a month ago ...
Old Mar 03, 2012, 09:12 AM
Joined Jan 2012
I noticed I could not completely trim out the yaw to the right. With the trim at its max, it still has a slight yaw to the right. I'll wait to see if it is still there after a few more break-in flights but I guess if it is, there is nothing that can be done (if I'm understanding other post here).
Check the numbers on your PCB. Do they look like mine?
Old Mar 03, 2012, 09:19 AM
eagle75 is offline
Find More Posts by eagle75
Joined Feb 2012
Thanks guys. I am not sure I will be able to solder those tiny wires. Good to know twisting them will also work.
eagle75 is offline Find More Posts by eagle75
Old Mar 03, 2012, 09:23 AM
MassiveOverkill is online now
Find More Posts by MassiveOverkill
MassiveOverkill's Avatar
United States, SD, Custer
Joined Feb 2011
I converted my regular soldering iron to a micro by securing a stainless steel nail into it, you could probably use a large needle or other suitable shaft, but it's hard to get the solder to stick to the tips. It's not optimal, but will work in a bind.
MassiveOverkill is online now Find More Posts by MassiveOverkill
Site Sponsor
Latest blog entry: MassiveRC ZMR PDB
Old Mar 03, 2012, 09:32 AM
roadglidec is offline
Find More Posts by roadglidec
Joined Jan 2012
260A Aluminum Swash
Hey Guys, a quick heads up on the swash that came w/ my 260 A parts kit. Make sure you check your brass linkage balls on the aluminum swash for tightness,I just installed mine without thinking about it and after 2 flights 1 of the balls came completely out ,but luckily it was still hanging in the swash link! I used some anaerobics retainer ( RC Red Threadlocker ) and that sucker is in there for good. The anaerobics retainer is a great addition to your flight box as it is designed to react to metal for a permanent bond,use the regular blue if you want to ever get stuff apart again
roadglidec is offline Find More Posts by roadglidec
Old Mar 03, 2012, 09:51 AM
Daryoon is offline
Find More Posts by Daryoon
Team WarpSquad
Daryoon's Avatar
United States, CA, San Diego
Joined Dec 2010
@cpuken:
Just to clarify...when you say yaw, you're talking about rudder. Correct? Not left and right aileron.
-Daryoon
Daryoon is offline Find More Posts by Daryoon
Old Mar 03, 2012, 10:15 AM
cpuken is offline
Find More Posts by cpuken
cpuken's Avatar
United States, IN, Indianapolis
Joined Dec 2011
Originally Posted by Daryoon View Post
@cpuken:
-Daryoon
Yes, rudder problem, sorry about that... I promise to sit down soon and commit the various heli terms to memory (at least Yaw, Rudder, etc.)
After a lube job and a few more flights, the rudder problem (for now) seems to be gone. This new Blue-White heli is certainly a little different then the 1st two I owned. It doesn't appear to be as stable but not bad. It may yet smooth out. And the flight times are lower then my other two (when then first arrived). I've observed a little shudder a few times and it will also change altitude on occasion on its on.
cpuken is offline Find More Posts by cpuken
Old Mar 03, 2012, 10:29 AM
afloyd82 is offline
Find More Posts by afloyd82
ladybird, miniCP, msrx, 4F180
Joined Jan 2012
Hey guys finally got my V911 today. A little dissappointed....the canopy says Copter. I was hoping to get a CORTER, I mean it Im a little bit sad I really thought that typo was hilarious. My flybar is straight and has no bends to it, PCB board is v6. The servos are on the outer holes and swash is on the long balls. So from the factory shes set up to be as responsive as possible. Tail Boom is a LOT longer than either my MSRX or 9958. I plan to use a KBB tailblade on this as its larger and has more pitch. Im gonna fly it stock for a couple batteries and then go metal swash, rotor head, xtreme blades, xtreme CF flybar with MSR paddles.
Everything looks good so far out of the box. Pretty excited, haha
afloyd82 is offline Find More Posts by afloyd82
Old Mar 03, 2012, 10:31 AM
afloyd82 is offline
Joined Jan 2012
Here's a better link.
The battery has the digits LB11. I interpret those digits as 2012 Feb 11.
The batteries that came with my v911 appear to the the 130mah. I got it from Banggood. Pretty happy to have 2 130mah in the box.
Old Mar 03, 2012, 10:41 AM
afloyd82 is offline
Joined Jan 2012
dude your so funny, you have to ALWAYS mention TBE from your 9958. If you would have taken some time address it instead of quitting maybe you would be flying your 9958 right now instead of complaining about it. But you quit on that poor heli, seems like a waste to me. Should have shipped it to me for free and I could have had it hovering on a dime. Oh well.
Old Mar 03, 2012, 11:10 AM
Hayabusa Heli is offline
Find More Posts by Hayabusa Heli
Heli Mania
Hayabusa Heli's Avatar
PNW
Joined Dec 2010
@cpuken:
-Daryoon
Yaw is controlled by the rudder (tail prop on a heli).
Roll is controlled by the ailerons (left/right cyclic on a heli)
Hayabusa Heli is offline Find More Posts by Hayabusa Heli
Old Mar 03, 2012, 11:14 AM
Heli Mania
PNW
Joined Dec 2010
Not sure the bigger tail prop is going to get you any improvements ... seems the tail is as fast as lightning on the V911 in stock form. They all come setup from the factory with the servo arms on outer holes and linkage on outer balls for fastest movements.
Let us know how you like the V911.
New Product Jiuchon 9C002, a Solo Pro clone? SoloProFan Micro Helis 103 Feb 29, 2012 02:24 PM
Discussion Interesting Solo Pro? Clone gordonzo Micro Helis 46 Nov 30, 2011 03:15 AM
Question Which 100 sized heli after Solo Pro? Tuc Micro Helis 16 Jun 13, 2011 01:52 PM
Sold $100 !NEW ARF Storm 250 (Trex Clone) With Align Upgrades, Tons of Extras! $100!! RChelisrule Aircraft - Electric - Helis (FS/W) 1 May 31, 2011 12:26 AM
