Link to v911 BNF at BangGood
Attachment 5533887
Click on for larger image As you can see the test has the stock 120mah batteries create very good power although not lasting as long flight time...I think they are great batteries especially for the cost. |
![]() Let's be clear. I am also talking about the tail motor. My point is, if you need a tail motor right away, from a USA retailer or Local Hobby Shop...you can simply buy a Blade Tandem helicopter's CCW motor. It is the right size to be used as a tail motor on the v911. The Blade Tandem motor comes with a pinion already installed on it. It's easy to remove by simply crushing the brass pinion with a pair of pliers. Or, if you have a micro pinion puller, you can use that instead and get a free pinion. Some sellers are clearing out stock of the Tandem's motor for cheap. But some seem to have raised the price in recent times. Likely because people started buying them for tail motors on their other helis. ![]() Hope that makes sense now. |
Latest blog entry: Syma S105 Battery Mod
I think I'll go with the cheaper batteries. Probably better for motor life if the flights are ~5min with a cool-down between lipo changes. Ever see the current 911 battery connectors, both genders, available anywhere? I'd like to mod my 107 clone, which has a very inconvenient connector, as well as the batteries. |
Joined Jan 2013
I was about to place an order on banggood, for 5 200mah battteries, so i guess i better get the 5 120mah ones |
Get the 150mah I heard those are the best out off all the batteries. I have the 130mah and 200mah, the 130 last about :20s longer but don't seem to have the punch or power that the 200mah have but I do notice the extra weight in the 200 that in fff then when I let off it will rock back because of the weight of the batteries.
But either way you look at it the stock 120s are great performers power wise. My preferance will be the lower weight however of the 120s |
Joined Feb 2013
Looks like my tail motor really is going the way of the dodo, having trouble yawing right but it easily does left, that happen with anybody's? And still the problem before where it often won't spin unless I flick the blade a little. No visible hairs, fibers stuck as far as I can see either.
Should help that I got rid of that led and speaker too.
Ive started a blog for my build up when my orders arrive."WL V911 Build". Still waiting on the first order to arrive then ill place another one after the 18th sometime; due to the chinese new year being over with. My first order is a RTF with some spare blades and flybars,tail blades and batteries..Second order will be a BNF with some upgrade parts and a few more spares..May be a little while but it will be a project to keep an eye on. The BNF i plan to keep all stock though....Have a few surprises in store.
Look on Tmart...you can buy 3000mah AA rechargeables pretty cheap and a charger..Still way more cost effective than buying expensive batteries every month or so. |
| Thread Tools | |
| New Product Jiuchon 9C002, a Solo Pro clone? | SoloProFan | Micro Helis | 103 | Feb 29, 2012 02:24 PM |
| Discussion Interesting Solo Pro? Clone | gordonzo | Micro Helis | 46 | Nov 30, 2011 03:15 AM |
| Question Which 100 sized heli after Solo Pro? | Tuc | Micro Helis | 16 | Jun 13, 2011 01:52 PM |
| Sold $100 !NEW ARF Storm 250 (Trex Clone) With Align Upgrades, Tons of Extras! $100!! | RChelisrule | Aircraft - Electric - Helis (FS/W) | 1 | May 31, 2011 12:26 AM |
