Old Feb 08, 2013, 09:00 PM
ITS ME DAVID is offline
Find More Posts by ITS ME DAVID
ITS ME DAVID's Avatar
Joined Apr 2011
Yea usual zero trim fixes it. It did for some other people on this thread If it didn't work maybe finally your servos are out.
ITS ME DAVID is offline Find More Posts by ITS ME DAVID
Old Feb 08, 2013, 10:12 PM
stringrazor is online now
Find More Posts by stringrazor
Certifiable
stringrazor's Avatar
United States, CA, Burbank
Joined Dec 2012
Originally Posted by ITS ME DAVID View Post
My h911 chillin lol
I just ordered one from Hero RC yesterday. Can't wait ... but gonna have to... somehow. Guess I'll spend some more time here reading what else I'm gonna need. This will be Heli#2 after familiar sequence of getting hooked by a 3ch coax Christmas gift.
stringrazor is online now Find More Posts by stringrazor
Old Feb 08, 2013, 10:39 PM
Joined Apr 2011
I havent broke anything (knockonwood) yet and I have been flying pretty aggressively lately.
Old Feb 08, 2013, 10:45 PM
SMEGS888 is offline
Find More Posts by SMEGS888
Futaba 9CRAPTOR 90V911V922
SMEGS888's Avatar
United States, CA, Hacienda Heights
Joined Dec 2012
What part of southern ca do you fly at.
SMEGS888 is offline Find More Posts by SMEGS888
Old Feb 08, 2013, 10:47 PM
Certifiable
Joined Dec 2012
Beautiful (not quite) downtown Burbank...
Old Feb 08, 2013, 11:07 PM
Joined Apr 2011
Haha I'm South Pasadena
Old Feb 08, 2013, 11:43 PM
georgeintexas is offline
Find More Posts by georgeintexas
United States, TX, St Paul
Joined Dec 2012
I finally got around to making a movie out of the footage I took flying the v911 in the atrium on Wednesday. I flew at high rates the whole time and the yaw is so sensitive it really causes trouble making smooth turns. Consequently it looks more like what I used to do flying pattern 20 years ago. Back and forth in front of me pulling up into some kind of tight turn around at each end. I cut out a fair bit of banter from co-workers walking by on their way to lunch. I'm still learning how to use the head cam and don't always keep the heli in the frame very well. Anyway, here's the video...
George
Micro Heli Video 2 (0 min 0 sec)
georgeintexas is offline Find More Posts by georgeintexas
Old Feb 08, 2013, 11:47 PM
Kev7274 is offline
Find More Posts by Kev7274
United States, NC, Morganton
Joined Nov 2012
Guys,
who is running the er9x firmware with the v911?
I am having issues with the heli going full throttle when the th9x binds to it. It does it for 4-5 seconds then stops.It's ok until I turn on the tx again. I know it's some sort of setting.
I was thinking of using Daryoons eepe file to see what happens.
Kev7274 is offline Find More Posts by Kev7274
Old Feb 08, 2013, 11:54 PM
Heli Pad is offline
Find More Posts by Heli Pad
Against Helicopter Cruelty
Heli Pad's Avatar
Joined Aug 2011
Yes, using er9x here (with T9x), never had a problem with surprise throttle. But I'm in the habit of always turning radio on first. Have you tried that?
Heli Pad is offline Find More Posts by Heli Pad
Old Feb 09, 2013, 12:12 AM
Kev7274 is offline
Joined Nov 2012
Ill try that and see what happens. I have more adjusting to do also,it wants to raise straight back on take off.
Old Feb 09, 2013, 12:18 AM
josephdyland is offline
Find More Posts by josephdyland
Joined Dec 2012
I installed a Fisheye swash and new carbon shaft this evening.
Had to do quite a bit of mechanical trim and it is flying pretty decent now. -- Still always rotating to the right.
I had noticed when moving the servos with the right stick with no throttle;
moving the right stick to top right. the shaft and main gear starts to rise and spin a little.
Any ideas what I could have done wrong? I think the swash may not be level because arm coming out of the swashplate into the guide is close to the bottom when servos are in neutral
wltoys v911 main gear and shaft rise / spin (0 min 25 sec)
josephdyland is offline Find More Posts by josephdyland
Old Feb 09, 2013, 12:32 AM
Joined Apr 2011
The screw that goes into the pinion into the shaft isn't aligned correctly and it's not screwed I to the shaft just screwed against it.
Old Feb 09, 2013, 01:05 AM
Heli Pad is offline
Heli Pad's Avatar
Joined Aug 2011
I don't think what you described there in and of itself is much of a problem. When you move the servos they change the angle of the swash plate, which pushes on to the head and thing could rotate. The main thing is that it flies well. So, I don't think you have a problem.
However, there seems to be too much play on that shaft for my taste. That's why the gear and the whole shaft is moving up and down so much. I think you heli will fly even better after you take up that slack.
Did you say you put a CF shaft in? And the drill holes are in the exact same position as before? Check and see if you didn't have the shaft collar (the ring that sits on the top side of the bearings) installed upside down, cause that will give you the extra slack. What you want is very little play between that collar and the frame. The other end of that shaft is gear. So the gear and the collar should sandwich the frame snugly.
Old Feb 09, 2013, 01:49 AM
Certifiable
Joined Dec 2012
Know of any local shops that have batteries and or parts for when waiting just won't cut it? I could really use at least one good battery for my Smya 107 clone this w/e. Have some on order and in transit but they're at least a week away, as is the H911. Think there's a RC shop here in town I'll pay a visit to...
Old Feb 09, 2013, 01:56 AM
Joined Apr 2011
None that carry this stuff most carry blade and higher end models.
New Product Jiuchon 9C002, a Solo Pro clone? SoloProFan Micro Helis 103 Feb 29, 2012 03:24 PM
Discussion Interesting Solo Pro? Clone gordonzo Micro Helis 46 Nov 30, 2011 04:15 AM
Question Which 100 sized heli after Solo Pro? Tuc Micro Helis 16 Jun 13, 2011 02:52 PM
Sold $100 !NEW ARF Storm 250 (Trex Clone) With Align Upgrades, Tons of Extras! $100!! RChelisrule Aircraft - Electric - Helis (FS/W) 1 May 31, 2011 01:26 AM
