Old Feb 03, 2013, 11:14 AM
Bvc is offline
Bvc
Find More Posts by Bvc
Bvc
United States, TX, Houston
Joined May 2012
Originally Posted by Tumppi T View Post
While waiting my new Hughes s300 canopy from China, I painted the original canopy matt black and put some silver tape on it
Ahhh Yeah! That's exactly (silver/black with solo pro blades) what I thought about doing, but was too lazy and just painted it black (gloss windshield) and used steel wool to take the paint off the blades.
Bvc is offline Find More Posts by Bvc
Old Feb 03, 2013, 12:00 PM
ourbluehorizon is offline
Find More Posts by ourbluehorizon
UK, Ballymena, Ballymena
Joined Aug 2008
elevator servo not working
Hi,
New out of box and elevator servo is not working. Anyone else had this problem?
ourbluehorizon is offline Find More Posts by ourbluehorizon
Old Feb 03, 2013, 12:13 PM
Thwock is offline
Find More Posts by Thwock
United Kingdom
Joined Nov 2012
Check wires and solder joints on/between the servo and the board.
If you have the time and inclination I suppose you might return it, depends where you bought it.
Otherwise, and if you can't fix it with soldering, the next best option is probably to get a BNF (helicopter only) from somewhere like banggood, just make sure you get one with the same battery connector. Being positive, at least you'll have a good stock of spare parts then.
Sorry you got a faulty one.
Thwock is offline Find More Posts by Thwock
Old Feb 03, 2013, 02:01 PM
ITS ME DAVID is offline
Find More Posts by ITS ME DAVID
ITS ME DAVID's Avatar
Joined Apr 2011
Originally Posted by 153stars View Post
HELIOS is an other v911 size heli somewhat faster, bigger batteries, paddled flybar. Dosent bind with other nicer transmitters though.
http://www.banggood.com/Wholesale-Be...o-p-47798.html
What parts can I use on my v911 that are better on the helio that will make my bird better ?
ITS ME DAVID is offline Find More Posts by ITS ME DAVID
Old Feb 03, 2013, 02:30 PM
R.sok is offline
Find More Posts by R.sok
Joined Dec 2012
That looks good
R.sok is offline Find More Posts by R.sok
Old Feb 03, 2013, 02:35 PM
R.sok is offline
Joined Dec 2012
Originally Posted by 6sharky9 View Post
Looking further i see the solo pro shaft is alot cheaper price wise...So is it safe to say i can remove the head from that shaft and use it without mods?..I thought i read something about having to drill another hole in the shaft..is this correct?
I ordered this one, the price went up a couple bucks though
http://www.amazon.com/gp/product/B00...ls_o03_s00_i00
It comes with the shaft, collar & plastic head. In order to use with your original blades you use the original v911 head. The shaft is actually shorter than the original v911 but it has the exact same mounting points so it's no big deal.
I recommend this as a first mod for anyone, I really like it. No need to drill anything.
Clubheli.com looks cheapest in the u.s. but they might be out of stock
Old Feb 03, 2013, 02:41 PM
NOFREDZ is offline
Find More Posts by NOFREDZ
Joined Jan 2013
Dh 9116-26
Quick question. I just picked up a DH 9116 Tx and the throttle is super sensitive. How is it adjusted? I can get to EPA and DR for all the other channles but can't see to navigate to the throttle seting. What does the Thro Tri 1, Tri 2, Tri 3 and Tri 4 do?? Thanks.
NOFREDZ is offline Find More Posts by NOFREDZ
Old Feb 03, 2013, 02:54 PM
Jasen40 is online now
Find More Posts by Jasen40
United States, CA, San Jose
Joined Jun 2012
Throttle setting is under D/R setting. Here is the default, just change the percentages till your happy. You also need to reverse the rudder and elevator.
press of the MENU button, ELEV REV flashes – NOA
press of the SEL button, RUDD REV flashes – NOA
press of the MENU button, THRO TRI 0 - 000%
press of the SEL button, THRO TRI 1 - 025%
press of the SEL button, THRO TRI 2 - 050%
press of the SEL button, THRO TRI 3 - 075%
press of the SEL button, THRO TRI 4 - 100%
Jasen40 is online now Find More Posts by Jasen40
Old Feb 03, 2013, 05:17 PM
NOFREDZ is offline
Joined Jan 2013
Okay. I played with those 4 percentages. From 0 to 100. Throttle was still too sensitive. Either full on or off. No in between. Why are there 4 seperate adjustments? Thanks.
Old Feb 03, 2013, 05:26 PM
6sharky9 is offline
Find More Posts by 6sharky9
6sharky9's Avatar
Joined Jan 2013
Thanks Subpixel..looks good.
6sharky9 is offline Find More Posts by 6sharky9
Old Feb 03, 2013, 07:44 PM
153stars is offline
Find More Posts by 153stars
United States, IL, Braidwood
Joined Nov 2012
Depends what you want heli to do precise indoors or fast out doors.
http://www.banggood.com/Wholesale-V9...et-p-49035.htm
Should make precise in doors not slow it down outdoors.
Helios fly bar better for outdoors less stable indoors
Helios main motor faster out harder to control in.
I bought 5 pack of 150mah batts from bangood litle better not too much extra wieght.
153stars is offline Find More Posts by 153stars
Old Feb 03, 2013, 07:58 PM
Joined Apr 2011
^ thanks I want outdoors setup
Old Feb 03, 2013, 08:13 PM
153stars is offline
Joined Nov 2012
check bangood for spare heli alone $20 stock up on spares they have helios screw kit in v911 parts as well good to have.
Some have modded battery turned forward for faster forward flight.
Old Feb 03, 2013, 08:20 PM
Joined Apr 2011
I have 4 battery's but with the new version v911 style my h911 seems pretty zippy fff but haven't tried it outside yet I have been practicing flying the heli inside with the fan on high and dang it's pretty hard to control.
Old Feb 03, 2013, 08:27 PM
Hit N Run is offline
Find More Posts by Hit N Run
Fly it low.. and fly it fast!
Hit N Run's Avatar
United States, MA, Westport
Joined Nov 2011
I can't believe i've never thought of that!
As soon as my replacement motors come in, i'll be trying that out for some good "wind exercises".
Hit N Run is offline Find More Posts by Hit N Run
New Product Jiuchon 9C002, a Solo Pro clone? SoloProFan Micro Helis 103 Feb 29, 2012 02:24 PM
Discussion Interesting Solo Pro? Clone gordonzo Micro Helis 46 Nov 30, 2011 03:15 AM
Question Which 100 sized heli after Solo Pro? Tuc Micro Helis 16 Jun 13, 2011 01:52 PM
Sold $100 !NEW ARF Storm 250 (Trex Clone) With Align Upgrades, Tons of Extras! $100!! RChelisrule Aircraft - Electric - Helis (FS/W) 1 May 31, 2011 12:26 AM
