Old Jan 27, 2013, 08:05 PM
ITS ME DAVID is offline
Find More Posts by ITS ME DAVID
ITS ME DAVID's Avatar
Joined Apr 2011
Originally Posted by R.sok View Post
looks good, lmk how your run time is compared to before
Before was 6minutes give or take a few seconds in mode 1 ill check after how many minutes I get.
ITS ME DAVID is offline Find More Posts by ITS ME DAVID
Old Jan 27, 2013, 08:40 PM
Uncle Gravity is offline
Find More Posts by Uncle Gravity
Chasin' Auntie Gravity's Tail
Uncle Gravity's Avatar
Joined Nov 2007
My V911 has been experiencing some fairly strong intermittent glitching/shuddering from the elevator servo. It'll be flying normally and then suddenly start lurching forward or shuddering in the air. Likewise, I can often see the servo twitching like crazy when I insert a battery and move the cyclic stick forward or back, then it will settle down and behave normally for a while.
I've searched this thread, and the only solution I've found was one instance where someone heated the servo wire solder joint on the receiver, which apparently caused the solder to flow and close a poor connection, but I've had no luck with that fix.
Any ideas short of replacing the receiver board?
Uncle Gravity is offline Find More Posts by Uncle Gravity
Old Jan 27, 2013, 08:57 PM
2_Crash_Thumbs is offline
Find More Posts by 2_Crash_Thumbs
2_Crash_Thumbs's Avatar
Canada, AB, Calgary
Joined Aug 2012
Shrink wrap on the servo arm to extend the throw & allow the original 2 mounting points along with 2 extra aggressive points
Kool. Could we have a better picture please? And, did you do any mod for canopy clearance?
2_Crash_Thumbs is offline Find More Posts by 2_Crash_Thumbs
Old Jan 27, 2013, 09:12 PM
Hellysmack is offline
Find More Posts by Hellysmack
What package dear?
Hellysmack's Avatar
USA ILLINOIS
Joined Nov 2002
On the msr I would clean the servo strip on the board with tuner cleaner.
Sounds like the pot in the servo needs cleaned sometimes this helps on standard servos.
Hellysmack is offline Find More Posts by Hellysmack
Old Jan 27, 2013, 09:29 PM
Joined Nov 2007
Thanks, Hellysmack.
I'm not sure what the servo "strip" is. And, when you say the potentiometer in the servo needs cleaning, are you referring to something in or on the servo body, or a separate pot on the main board?
Sorry I'm not up on the anatomical lingo yet.
Old Jan 27, 2013, 09:33 PM
flightsfancy is offline
Find More Posts by flightsfancy
Also, what is a tuner cleaner?
flightsfancy is offline Find More Posts by flightsfancy
Old Jan 27, 2013, 09:37 PM
Joined Nov 2007
AFAIK, it's contact cleaner spray.
Old Jan 27, 2013, 10:08 PM
Joined Apr 2011
Anyone know if the nine eagles 260a motor is more powerful then the v911 motor and will it fit in the v911 plug and play?
http://www.banggood.com/Wholesale-Ni...2-p-44942.html
Old Jan 27, 2013, 10:33 PM
R.sok is offline
Find More Posts by R.sok
Joined Dec 2012
Motor should be the same size. On club heli the 260a is 5.99 & bravo sx 7.50 I know for a fact the bravo sx is more powerful & direct fit. Not too sure about the 260a though. Someone mentioned they had great results with the helios 100 motor
R.sok is offline Find More Posts by R.sok
Old Jan 27, 2013, 10:44 PM
R.sok is offline
Joined Dec 2012
My phone doesn't really take good close up pics, but here is another.
I did not mod the canopy, it rubs slightly but nothing negative I can feel while flying. On the furthest hole the elevator is VERY sensitive, You would need to fly it outside to really appreciate the fff
Old Jan 27, 2013, 10:50 PM
Joined Apr 2011
So the bravo sx is a direct swap in plug and play any soldering needed ?
Old Jan 27, 2013, 10:55 PM
R.sok is offline
Joined Dec 2012
You can either solder the new motor on or cut the old wires & twist them together then use shrink wrap
Old Jan 27, 2013, 11:11 PM
Joined Apr 2011
Is this the motor
http://www.oomodel.com/nine-eagles-b...t-p-61632.html
Old Jan 27, 2013, 11:39 PM
R.sok is offline
Joined Dec 2012
Yeah that's the correct one. Seems quite a distance for shipping though.
http://www.amazon.com/NE402320013A-M...words=bravo+sx
http://www.clubheli.com/Bravo-SX-Main-Motor_p_2858.html
Old Jan 28, 2013, 12:51 AM
Joined Apr 2011
Club heli is out of stock right now will I need this tail setup aswell from the bravo sx
http://www.myrcmart.com/ne402320009a...et-p-3796.html
New Product Jiuchon 9C002, a Solo Pro clone? SoloProFan Micro Helis 103 Feb 29, 2012 02:24 PM
Discussion Interesting Solo Pro? Clone gordonzo Micro Helis 46 Nov 30, 2011 03:15 AM
Question Which 100 sized heli after Solo Pro? Tuc Micro Helis 16 Jun 13, 2011 01:52 PM
Sold $100 !NEW ARF Storm 250 (Trex Clone) With Align Upgrades, Tons of Extras! $100!! RChelisrule Aircraft - Electric - Helis (FS/W) 1 May 31, 2011 12:26 AM
