Old Jan 21, 2013, 05:19 PM
fauconnier is online now
Find More Posts by fauconnier
Flying a Falcon or a RC Heli.
fauconnier's Avatar
Canada, QC, Rimouski
Joined Jul 2012
Originally Posted by R.sok View Post
Diy Heatsink with solo pro v2 tail motor
Paper Canopy for the hell of it
Third servo arm mounting point
Lightning bird with mini rubber band for my 240 mah
You paper canopy is great, nice work. Good source of inspiration, I will try it.
fauconnier is online now Find More Posts by fauconnier
Old Jan 21, 2013, 05:22 PM
R.sok is offline
Find More Posts by R.sok
Joined Dec 2012
Thnx. Here is the link, your supposed to use photo paper, but I just used regular flimsy paper as I wasn't sure how it would turn out.
http://www.rcgroups.com/forums/showthread.php?t=1812966
R.sok is offline Find More Posts by R.sok
ashtodust2000 is offline
Find More Posts by ashtodust2000
Flying mostly pop-wings now.
ashtodust2000's Avatar
United States, WI, Sheboygan
Joined Dec 2011
Originally Posted by shortfellow View Post
Thanks for the reply Ash. It was a cold solder joint where the antenna wire connects to the PCB. Works now. Vince
You are welcome.
I have had one of mine lose a antenna and it worked just as good, I have since soldered one back on, I cut a piece of speaker wire.
ashtodust2000 is offline Find More Posts by ashtodust2000
Old Jan 21, 2013, 06:47 PM
ilmystic is offline
Find More Posts by ilmystic
Joined Dec 2012
Nice heatsink mod R.sok, I gotta try that.
That reminds me,
I was brainstorming last night about ways to keep these tail motors cool and thought, "why not open the can somehow"? maybe slice down the side with a dremel loaded with a cut-off wheel to allow the motor to let out some heat while it's running. Then that lead me to thinking about how a lot of electric motors are designed with holes. So why doesn't WLtoys have holes drilled in their motors? Cost? And what if we were to drill holes in our tail motors, or slice the sides, think it would keep it any cooler? Probably have to take it apart first though before cutting or drilling to avoid damage to the armature and whatever else is in there and to clean all the metal shavings out before running it. So maybe not worth it. Probably a crazy idea but thought I would throw it out there anyways.
ilmystic is offline Find More Posts by ilmystic
Old Jan 21, 2013, 06:53 PM
ilmystic is offline
Joined Dec 2012
Originally Posted by Heli Pad View Post
Search this thread for "debonder".
That was the magic word. Thanks
Old Jan 21, 2013, 07:15 PM
tominjax is offline
Find More Posts by tominjax
tominjax's Avatar
United States, FL, Jacksonville
Joined Dec 2012
To the guys that have burnt out tail motors...
What kind of outside temperature were you flying in? How many batteries did you go through? Any break between flights?
I only ask because at first I was flying my Lightning Bird back to back five times with the 200mah batteries (I have 5). I was even flying until the heli could not get any altitude anymore. Outside temps here in FL have been anywhere from 60F to 80F.
Since finding this thread I have begun giving it a rest between batteries.
tominjax is offline Find More Posts by tominjax
Old Jan 21, 2013, 07:16 PM
R.sok is offline
Joined Dec 2012
That reminds me,
Correct me if I'm wrong, but you can't cut slits in coreless motors?
Old Jan 21, 2013, 07:26 PM
2_Crash_Thumbs is offline
Find More Posts by 2_Crash_Thumbs
2_Crash_Thumbs's Avatar
Canada, AB, Calgary
Joined Aug 2012
...brainstorming...maybe slice down the side with a dremel loaded with a cut-off wheel ...
These little motors use the magnetized case as the stator magnets.
2_Crash_Thumbs is offline Find More Posts by 2_Crash_Thumbs
Old Jan 21, 2013, 09:02 PM
ilmystic is offline
Joined Dec 2012
Alright, I'll scrap that idea.
R.sok, what type of thermal paste would be best to use?
And is the thermal paste all that is needed to adhere the aluminum to the motor?
Old Jan 21, 2013, 09:06 PM
R.sok is offline
Joined Dec 2012
I used a tiny tiny amount of this http://www.amazon.com/Arctic-Silver-...paste+compound
& then once all the fins are how you like them I took super glue & blotched it around the small areas so all the fins come as one
Old Jan 21, 2013, 09:16 PM
ilmystic is offline
Joined Dec 2012
I was flying in about 70F and only running the two 130 mAh stock batteries that came with it. Usually no breaks in between flights but the tail motor didn't even feel hot. Just a little warm. I estimate that I flew about 30 to 40 times before the motor would stick at the beginning of each flight and I had to give the rotor a nudge to get it going. I'm not even a 100% sure that I did burn it out; maybe I just had a bad motor from the start. Hopefully that's all it was.
Old Jan 21, 2013, 10:35 PM
R.sok is offline
Joined Dec 2012
I also have the lightning bird, my tail motor didn't go completely out, But after I flew into a tree tail first, it started to stick so I replaced it with a Nine Eagles motor.
Temps have been 32/40 f 5 minute breaks
Old Jan 21, 2013, 11:24 PM
Jasen40 is online now
Find More Posts by Jasen40
United States, CA, San Jose
Joined Jun 2012
Does any one have a spare 9116 TX they would like to sale? My 4 year old knocked mine off my desk and broke the left stick internally. I can get it back together with good response.
Jasen40 is online now Find More Posts by Jasen40
Old Jan 21, 2013, 11:46 PM
Heloo is offline
Find More Posts by Heloo
Joined Jan 2013
What's the best way to maintain the batteries overnight or for two or three days without flying? Charged, partial charge, depleted after flight and recharged before next flight, etc. If charged should they be topped off before flying? Does this apply to all LiPos or just these small ones?
Thanks in advance, I did some searches but came up empty.
Heloo is offline Find More Posts by Heloo
Old Jan 21, 2013, 11:58 PM
stonecutter is offline
Find More Posts by stonecutter
Sir Crashalot
stonecutter's Avatar
Joined Oct 2011
Don't know much about the theory, based solely on practicality I leave mine fully charged when able. Haven't noticed any ill effects.
stonecutter is offline Find More Posts by stonecutter
New Product Jiuchon 9C002, a Solo Pro clone? SoloProFan Micro Helis 103 Feb 29, 2012 02:24 PM
Discussion Interesting Solo Pro? Clone gordonzo Micro Helis 46 Nov 30, 2011 03:15 AM
Question Which 100 sized heli after Solo Pro? Tuc Micro Helis 16 Jun 13, 2011 01:52 PM
Sold $100 !NEW ARF Storm 250 (Trex Clone) With Align Upgrades, Tons of Extras! $100!! RChelisrule Aircraft - Electric - Helis (FS/W) 1 May 31, 2011 12:26 AM
