Old Jan 05, 2013, 12:44 PM
dferrey is offline
Find More Posts by dferrey
United States, CO, Longmont
Joined Jan 2013
Originally Posted by Jasen40 View Post
On a FP the swash will not be level.Have look at the mixing arm(center of the links), if it rubs the blades in any way, the helicopter will not hover in one spot.
Is the mixing arm the one at the bottom of this picture?
Sorry, I'm just not up to speed yet on the terminology. The manual isn't a lot of help and I'm pretty sure mine has the mainshaft (8) and the swashplate (7) reversed
The good news is I'm rapidly improving my skills with the sticks, what with trying to keep it steady and all
dferrey is offline Find More Posts by dferrey
Old Jan 05, 2013, 12:53 PM
igotit is offline
Find More Posts by igotit
United States, LA, Houma
Joined Jun 2008
my wl v911 blades are stamped b1 computer board says rev.01 date 2012.05.29
is this a good version?
igotit is offline Find More Posts by igotit
GiantScale is offline
Find More Posts by GiantScale
Iowa City Iowa
Joined Jun 2000
Originally Posted by dferrey View Post
I'm struggling mightily getting this thing to behave. It simply won't hover in a reasonably stable way. I don't expect complete stillness, but if let it go in the center of a 15x15 room, it will run into a wall within a few seconds. I can control the nose turn but it seems to degrade into what I guess is called TBE. I found some suggestions about the flybar but it hasn't helped. I've attached a picture and am wondering if the swashplate looks right. It isn't level. Any other ideas would also be appreciated. The servos are level in that picture.
Make sure the links aren't pushed on to far.
After a midair, one of mine controlling the flybar got pushed on to far and bound up the movement.
Pop them all off and back on and make sure you hear one click.
GiantScale is offline Find More Posts by GiantScale
Old Jan 05, 2013, 12:56 PM
fauconnier is offline
Find More Posts by fauconnier
Flying a Falcon or a 3D plane.
fauconnier's Avatar
Canada, QC, Rimouski
Joined Jul 2012
Everybody, take a look at the mixing arm, it is not a regular 911 mixing arm , there is an angle on the middle. The crook mixing arms of my Walkera and my F45 are reversed to what I see on the picture. Could be the problem.
fauconnier is offline Find More Posts by fauconnier
Old Jan 05, 2013, 01:04 PM
stonecutter is offline
Find More Posts by stonecutter
Sir Crashalot
stonecutter's Avatar
Joined Oct 2011
The crookedness of the mixer arm on the heli could be an optical illusion. The photo of the arm with the other links in his later photos shows no angle.
stonecutter is offline Find More Posts by stonecutter
Old Jan 05, 2013, 01:23 PM
dferrey is offline
Joined Jan 2013
What piece is the mixing arm? The picture of the 3 pieces on white background above are just from googling V911 linkage and picking the ones that looked pretty much like mine. I've updated the picture and put a circle around what may be perceived as crooked. In real life it's straight.
Old Jan 05, 2013, 01:26 PM
Sir Crashalot
Joined Oct 2011
The mixer arm is the bottom one in the photo. The one with two balls that transfer movements of the swashplate and fly bar to the blades. Thus the name.
Old Jan 05, 2013, 01:28 PM
fauconnier's Avatar
Joined Jul 2012
The mixing arm is locked to the blade by 1/4 of a turn. It is the shorter on the last picture. On all my 911 the mixing arm is strait.
Old Jan 05, 2013, 01:38 PM
Heli Pad is offline
Find More Posts by Heli Pad
Against Helicopter Cruelty
Heli Pad's Avatar
Joined Aug 2011
Most of these helicopters with Flybar (FB) has linkages. There are linkages from the swash to the blade/FB (depends on the design) and then there are linkages between the blades and the FB. Sometimes the linkages would be the same. But other times, these linkages would be different, as in the case of the V911. One linkage has one rod between the rings. One linkage has two rods between the rings.
The middle piece, with a longer and a shorter arm is the mixing arm. It's mixing, because it is a lever. Movements are mixed rather than a 1:1 ratio.
DFerrey. I've been reading these posts of suggestions to you. The photo helped but I wish it was clear and sharper. Try again with the MACRO mode on.
But if I were you, I would check for Swash Separation. It seems to me in the blurry photo that the swash plate might begin to separate. Press them back together. Check also in each linkage, that the ring part is ON the ball part, that it does not go pass the ball and sits on the arm to the ball. So that all the moving parts move freely with no binding. Try these. They may not solve your problem, but worth checking them anyways.
Heli Pad is offline Find More Posts by Heli Pad
Old Jan 05, 2013, 02:18 PM
Jasen40 is online now
Find More Posts by Jasen40
United States, CA, San Jose
Joined Jun 2012
As others said the mixing arm is the one on the bottom.
Jasen40 is online now Find More Posts by Jasen40
Old Jan 05, 2013, 02:24 PM
dferrey is offline
Joined Jan 2013
Thanks Heli Pad - I'll try to get better pictures. The linkages don't appear to be pushed past the balls. I also used a needle nose to press the two parts of the plate together. There is still a slight separation. I didn't want to press too hard on them.
I didn't see any change.
Old Jan 05, 2013, 02:34 PM
Joined Jun 2012
@Dferrey. Are servo arms centered? Does the issue happen after some right stick input or right from the begging using just throttle? You also try removing the servo horn and inspect the servo gear.
Old Jan 05, 2013, 02:51 PM
CCbusa05 is offline
Find More Posts by CCbusa05
CCbusa05's Avatar
USA, NV, Carson City
Joined Sep 2006
Originally Posted by larryka View Post
I might just order a Syma 107G for inside, since flying my kids' slow coaxials around the living room is more relaxing than the V911, but I'm definitely keeping this guy for outside or larger indoor rooms.
Exactly what I did! Bought a Syma 107g coaxial and a 108g (military series - Marine Cobra). Quality and durability of these little 3-CH wonders are unsurpassed! For indoors fun, out of the sun, the hover stability and maneuverability will surprise you. 20 flights on each and no issues. I know, this all should be over on the coaxial forum, but you did mention it!
CCbusa05 is offline Find More Posts by CCbusa05
Old Jan 05, 2013, 02:52 PM
Heli Pad is offline
Heli Pad's Avatar
Joined Aug 2011
@Dferrey, Sorry that didn't do it for you. Hope you find the real issue soon.
Old Jan 05, 2013, 03:22 PM
dferrey is offline
Joined Jan 2013
Can you explain what you mean by centered? Normally (I just looked now), after landing and turning off to transmitter, the outer part of arms (the end with the 2 holes) are both slightly lower then the end with the screw.
Can't say as most of the time as soon as it lifts off I'm trying to get control. Next time (maybe not until late tonight or tomorrow) I'll check it out.
What is the servo horn?
New Product Jiuchon 9C002, a Solo Pro clone? SoloProFan Micro Helis 103 Feb 29, 2012 02:24 PM
Discussion Interesting Solo Pro? Clone gordonzo Micro Helis 46 Nov 30, 2011 03:15 AM
Question Which 100 sized heli after Solo Pro? Tuc Micro Helis 16 Jun 13, 2011 01:52 PM
Sold $100 !NEW ARF Storm 250 (Trex Clone) With Align Upgrades, Tons of Extras! $100!! RChelisrule Aircraft - Electric - Helis (FS/W) 1 May 31, 2011 12:26 AM
