Old Jan 04, 2013, 11:34 AM
jonathan2tran is offline
Find More Posts by jonathan2tran
United States, CA, Fountain Valley
Joined Dec 2012
So After waiting 2 week for my bird to arrive form Banggood.com the packaging was a bit poor, but everything in the inside (Tx, v911, extra batteries) were well protected. After charging up the batteries i took the bird out to fly and all i can say is wow! it handles very well and with minor trimming it hovered perfectly fine! well build unit and as everyone else on here had said its was well worth getting . Thanks
jonathan2tran is offline Find More Posts by jonathan2tran
Old Jan 04, 2013, 11:36 AM
bbrackeen is offline
Find More Posts by bbrackeen
Joined Dec 2012
Originally Posted by pshkong View Post
I believe the new style batter is using the same plug as NANO CPX, so you can use a 6S or 3S harness with any parellel charger. BUT PLEASE MAKE SURE THE +/- side are correct because they may be reversed...
As far as I can tell this is not true, the new plug is a 2 pin JST-PH style similar to what is used on a mCP X (see Here where he refers to the plug as a JST-PH). The nano and mSr use a ultra micro "UM" style.
This looks promising;
Which would allow charging of your v911 batteries, mSr and/or nano and mCp x in parallel.
http://epbuddy.com/index.php?main_pa...roducts_id=347
bbrackeen is offline Find More Posts by bbrackeen
Old Jan 04, 2013, 12:32 PM
mystman is offline
Find More Posts by mystman
Joined Jan 2012
This one is cheaper and doing the same :
http://www.hobbyking.com/hobbyking/s...g_Harness.html
mystman is offline Find More Posts by mystman
Old Jan 04, 2013, 12:35 PM
Raul11982 is offline
Find More Posts by Raul11982
Joined Jan 2013
http://www.rcdude.com/servlet/the-25...PH2-for/Detail
It sure looks like the new connector, and its the right polarity too. Can anyone confirm that the mcpx batteries have the same connector as the new v911 batteries?
Raul11982 is offline Find More Posts by Raul11982
Old Jan 04, 2013, 12:36 PM
mystman is offline
Joined Jan 2012
Yes, they have.
Old Jan 04, 2013, 12:42 PM
Joined Jan 2013
Originally Posted by mystman View Post
Yes, they have.
Thanks!
Old Jan 04, 2013, 12:45 PM
Bat97 is offline
Find More Posts by Bat97
Joined Dec 2012
Yes, they have.
This is what I have been looking for and I will find a good lipoly charger since I just bought the 5 200mah lipos from amazon.
Thanks again to Mystman!
Bat97 is offline Find More Posts by Bat97
Old Jan 04, 2013, 02:14 PM
dferrey is offline
Find More Posts by dferrey
United States, CO, Longmont
Joined Jan 2013
I received my Lightning Bird today! The first thing I did was tame it a bit for its first flight. I moved the servo rods to the innermost holes on the servo arms and then I moved the connection rod to the shorter ball links on the swash plate..
I received my Lightning Bird today. Man, the parts are tiny. I want to do what you did and before I just start in, I wonder if you have any tips regarding how you moved the rods? Should I remove the canopy? Remove the screws on the servo arms, etc.
dferrey is offline Find More Posts by dferrey
Old Jan 04, 2013, 02:21 PM
2_Crash_Thumbs is offline
Find More Posts by 2_Crash_Thumbs
2_Crash_Thumbs's Avatar
Canada, AB, Calgary
Joined Aug 2012
An Exponential Effort
I have converted the stock TX from linear to exponential curve response by soldering resistors on the PCB. Expo'ing the yaw control is the most helpfull. I modified the yaw control with 1.8K ohm resistors. I modified the pitch control with 2.2K ohm resistors. I modified the roll control with 2.7K ohm resistors.
2_Crash_Thumbs is offline Find More Posts by 2_Crash_Thumbs
Old Jan 04, 2013, 02:22 PM
stonecutter is offline
Find More Posts by stonecutter
Sir Crashalot
stonecutter's Avatar
Joined Oct 2011
Remove the canopy, then carefully pop off the rod from the swashplate balls (strong fingernail would help here), the rod comes off without unscrewing the servo arms.
stonecutter is offline Find More Posts by stonecutter
Old Jan 04, 2013, 02:26 PM
Joined Jan 2013
Originally Posted by stonecutter View Post
Remove the canopy, then carefully pop off the rod from the swashplate balls (strong figernail would help here), the rod comes off without unscrewing the servo arms.
That's exactly what I did. The only reason I removed one of the servo screws was to center the servo arm. If your arms are near center then don't worry about this.
Old Jan 04, 2013, 02:32 PM
dferrey is offline
Joined Jan 2013
Thanks, looks like I'll learn a lot quickly - First major impact with a wall and my blades came flying off
Old Jan 04, 2013, 03:14 PM
bad_mofo is offline
Find More Posts by bad_mofo
Joined Jan 2013
tail motor problems. again.
Hi people. My second v911 arrived today. After some intensive and extensive flying and a couple of not so brutal crashes the bottom (the posterior lid) of the tail motor is disconnected. The same problem as my first v911, but the first one took some seriuos beating prior. Now it was a banal crash. I suppose i should buy a couple of new motors. But i havent been able to remove the damaged motor. Anybody knows how to remove the bloody tail motor? thanks.
bad_mofo is offline Find More Posts by bad_mofo
Old Jan 04, 2013, 03:25 PM
dferrey is offline
Joined Jan 2013
I've got the blades and linkages apart (some done for me due to the crash). I can't seem to get one of links onto the blades. The blade "knob" has bumps. See the picture.
I found some pictures and realized where the different links go and got it all back together. Now I just need to figure out how to fly. Hovers not so much as seems to have a mind of it's own
Old Jan 04, 2013, 03:30 PM
JaapDub is offline
Find More Posts by JaapDub
JaapDub's Avatar
The Netherlands
Joined Jan 2012
Have you seen this:
http://www.banggood.com/Wholesale-Li...o-p-61148.html
Seems to be bigger than the V911 but price is only bit higher.
What do you think?
JaapDub is offline Find More Posts by JaapDub
New Product Jiuchon 9C002, a Solo Pro clone? SoloProFan Micro Helis 103 Feb 29, 2012 02:24 PM
Discussion Interesting Solo Pro? Clone gordonzo Micro Helis 46 Nov 30, 2011 03:15 AM
Question Which 100 sized heli after Solo Pro? Tuc Micro Helis 16 Jun 13, 2011 01:52 PM
Sold $100 !NEW ARF Storm 250 (Trex Clone) With Align Upgrades, Tons of Extras! $100!! RChelisrule Aircraft - Electric - Helis (FS/W) 1 May 31, 2011 12:26 AM
