Old Jan 18, 2012, 09:00 AM
shafter is offline
Find More Posts by shafter
Poland, Śląskie, Bielsko-Biala
Joined Jan 2012
It took my package 4 days to travel HK- Poland and now it's under customs review since 5 days ... they requested invoice and wire confirmation and probably i will be VAT taxed ... which means few days more waiting ... ... ...
Lucky you guys living in less restrictive jurdistrictions
shafter is offline Find More Posts by shafter
Old Jan 18, 2012, 09:01 AM
Mulder_ is offline
Find More Posts by Mulder_
FPV Pilot
Mulder_'s Avatar
Germany, NRW, Herzogenrath
Joined Jun 2010
Turnigy Nano Tech 160mAh
Today I got 2 Turnigy Nano Tech 160mAh lipos, I already had one of those mysterious battery connectors (SKU026090). Against Hobbykings advice, these do not fit the v911 without mods. I swapped the connector housings and got it working
battery connectors are not compatible, the 160mAh battery is just few mm longer:
Take some small pliers and cut off the stock connector, just the plastic, not the metal terminals, they are needed! Be careful not to cut through the wires an especially pay attention not to shorten the battery terminals.
Once the old plastic housing is removed, run both battery terminals through the new connector housing and slide the connector fully onto the battery. Now, take each battery terminal and slide it into the new connector, they are a 100% match and fit staright into the rails of the new connector as if they were made for it. secure everything with hot glue (use less than I did )
Fits into the v911, though there is no limiter, but you could have a drop of hot glue or something else if you want one:
... and the charger:
Mulder_ is offline Find More Posts by Mulder_
Old Jan 18, 2012, 09:35 AM
shafter is offline
Joined Jan 2012
^^ gr* news as i ordered 6 of those 160 mAh lipos
shame on HK, bcs of their advice i just ordered 1 spare batt connector
Old Jan 18, 2012, 11:06 AM
stonecutter is offline
Find More Posts by stonecutter
Sir Crashalot
stonecutter's Avatar
Joined Oct 2011
Where do you guys order the battery connectors, I searched HK's site and can't find it.
stonecutter is offline Find More Posts by stonecutter
Old Jan 18, 2012, 11:10 AM
ryknoll3 is offline
Find More Posts by ryknoll3
Joined Dec 2011
http://www.myrcmart.com/wlv91118-bat...or-p-4251.html
ryknoll3 is offline Find More Posts by ryknoll3
Old Jan 18, 2012, 11:14 AM
Sir Crashalot
Joined Oct 2011
Originally Posted by adjangs View Post
20 flights in and the tail motor doesn't spin up anymore except at full throttle, and only half-heartedly then.
One suggestion to (try to) determine if the motor is bad, throttle up and apply full right rudder (hold the heli in hand, needless to say); if the motor (and rx) is working properly, then the tail rotor should spin at max speed.
Old Jan 18, 2012, 11:28 AM
Sir Crashalot
Joined Oct 2011
Thanks for the link ryknoll3.
So, $1.17 for the battery, $0.99 for the connector, plus shipping; my guess is then around $2.50 to $3.00 each for the Turnigy-Nano route. I think extra stock batteries are available for that much shipped.
My question is, how much better are the Turnigy-Nano's compared to stock? What is the consensus here?
Old Jan 18, 2012, 11:30 AM
Mulder_ is offline
FPV Pilot
Mulder_'s Avatar
Joined Jun 2010
banggood is 3 cents cheaper but most important free shipping!
MyRcMart want $6.82 additional shipping
shafter is offline
Joined Jan 2012
Stock is 130 mAh or even a bit less ??
Turninigy are 160 mAh (and nano tech should be better than std lipo but most probably it's bsh*t)
Old Jan 18, 2012, 12:05 PM
_sprowt is offline
Find More Posts by _sprowt
_sprowt's Avatar
United Kingdom, England, Essex
Joined Jan 2012
these batteries look like they have the correct connector, but unsure if they are compatible
http://www.ebay.co.uk/itm/HIGH-CAPAC...-/330509053685
_sprowt is offline Find More Posts by _sprowt
Old Jan 18, 2012, 12:11 PM
RicksterRC is offline
Find More Posts by RicksterRC
Joined Sep 2007
Mulder:
Do you see any improvement from the Turnigy batteries?
Longer flights, more punch?
Would the turnigies fit (I mean slide into) the battery well of the V911, but just not stay?
I was thinking from looking at your pics like if you glued something in the slots on the turnigies to make like the rails on the V911?
RicksterRC is offline Find More Posts by RicksterRC
Old Jan 18, 2012, 12:14 PM
erdnuckel2 is offline
Find More Posts by erdnuckel2
erdnuckel2's Avatar
Joined Mar 2009
I still dont understand, why you guys are all keep on discussing which batteries and how and how to change the connectors etc.
NE changed their battery style a while ago - this is why the chargers for NE were labeled "Solo Pro - New Model" for some time.
Wouldnt the easiest just be to "give" the V911 an original solo pro landing skid with the "right" plug - then the whole "battery drama" would just EVAPORATE ...
csomi2 is offline
Find More Posts by csomi2
Magyarország, Borsod-Abaúj-Zemplén, Miskolc
Joined Dec 2011
Not fit, I try.
csomi2 is offline Find More Posts by csomi2
Old Jan 18, 2012, 12:15 PM
_sprowt is offline
_sprowt's Avatar
Joined Jan 2012
found an old post in the solo pro section, see below
http://www.rcgroups.com/forums/showp...postcount=4371
Old Jan 18, 2012, 12:17 PM
_sprowt is offline
_sprowt's Avatar
Joined Jan 2012
but if you have tried the other one then these are also a no
New Product Jiuchon 9C002, a Solo Pro clone? SoloProFan Micro Helis 103 Feb 29, 2012 02:24 PM
Discussion Interesting Solo Pro? Clone gordonzo Micro Helis 46 Nov 30, 2011 03:15 AM
Question Which 100 sized heli after Solo Pro? Tuc Micro Helis 16 Jun 13, 2011 01:52 PM
Sold $100 !NEW ARF Storm 250 (Trex Clone) With Align Upgrades, Tons of Extras! $100!! RChelisrule Aircraft - Electric - Helis (FS/W) 1 May 31, 2011 12:26 AM
