Old Dec 31, 2012, 12:41 PM
coaldust is offline
Find More Posts by coaldust
Joined Apr 2012
Originally Posted by Jasen40 View Post
Does it happen in the beginning or end of flight? Your pack may also need some seasoning (a few charges to for peak run time). Also make sure the tail blade is not on to tight.
yeah pretty much from the start, but a bit of rudder trim and its fine.
could allways pop another tail motor on. only notice it when hovering its very slight
coaldust is offline Find More Posts by coaldust
Old Dec 31, 2012, 12:52 PM
2_Crash_Thumbs is offline
Find More Posts by 2_Crash_Thumbs
2_Crash_Thumbs's Avatar
Canada, AB, Calgary
Joined Aug 2012
Originally Posted by coaldust View Post
...are there any other better packs i could use ?...
My y911's are very sensitive to extra weight and so my two 150 mah cells, which weigh 1 gram more than the stock 120 mah cells, don't get any more flight time/quality than my five 145 mah cells, which weigh 1/2 gram more than the stock 120 mah cells.
2_Crash_Thumbs is offline Find More Posts by 2_Crash_Thumbs
Old Dec 31, 2012, 12:57 PM
Picko990 is offline
Find More Posts by Picko990
Joined Dec 2012
Originally Posted by Picko990 View Post
ok. i was just in flight. about 2 minutes in.... and suddenly it lost power and dropped to the floor. nothing responded.
i pulled the battery and put it back in. it went through the binding process but instead of the LED coming up solid it would flash. so i tried a battery fresh off the charger and it did exactly the same thing.
any suggestions??
cheers
anyone have any input into this? i would really like to fly my helicopter
Picko990 is offline Find More Posts by Picko990
Old Dec 31, 2012, 01:16 PM
GiantScale is offline
Find More Posts by GiantScale
Iowa City Iowa
Joined Jun 2000
9116 tx
I'm looking at buying a 9116 TX.. Are double horse heli's any good? I was thinking about just buying a heli package which includes the 9116 TX but wasn't sure if double horse heli's are worth a damn..
Are any heli's packaged and sold with the 9X?
GiantScale is offline Find More Posts by GiantScale
Old Dec 31, 2012, 01:22 PM
stonecutter is offline
Find More Posts by stonecutter
Sir Crashalot
stonecutter's Avatar
Joined Oct 2011
If battery is good and antenna is intact, then nonbinding issues often times point to the crystal. Lots of posts on this thread about that, search a bit you will find them.
stonecutter is offline Find More Posts by stonecutter
Old Dec 31, 2012, 01:30 PM
coaldust is offline
Joined Apr 2012
Looks like i have a slightly dodgy lipo, the tail drifts left on one lipo, the other lipo it holds really solid.
Least its not the heli, Does it mean one of the lipos are underpowered i geuss ?
Old Dec 31, 2012, 01:45 PM
JCMorgan is offline
Find More Posts by JCMorgan
Krueminator
United States
Joined Apr 2012
Originally Posted by 2_Crash_Thumbs View Post
Whoa Back Big_Deck. JC already said how much he loves his v911 toy:
He is happy to enjoy a great heli toy for 1/3 the cost. He would probably be 1/3 less grumpy if the weather in his area was 1/3 less rainy, snowy, freezing and flooding.
Weather still hasn't changed. Wife and kids are out, though. My V911's are flying all over the house.
JCMorgan is offline Find More Posts by JCMorgan
Old Dec 31, 2012, 01:49 PM
gordonzo is offline
Find More Posts by gordonzo
Different fly 4 different guy
gordonzo's Avatar
Joined Jan 2011
Are you trying this (re)binding procedure?:
Plug the battery in on your v911 and then set it down and really, really quickly turn on the tx. Wait a few seconds until it binds.
Also verify your battery conn's from the skid to the board.
regards . . . g
gordonzo is offline Find More Posts by gordonzo
Old Dec 31, 2012, 02:18 PM
Heli Pad is online now
Find More Posts by Heli Pad
Against Helicopter Cruelty
Heli Pad's Avatar
Joined Aug 2011
any suggestions??
cheers
The symptoms sound consistent with a failed crystal on your Rx board, although this crystal is usually damaged in crashes. I've never seen it gone bad in mid flight. This thread is long, I know. But you should search back for keyword Crystal. I think you would find that consistent with the problems you're having.
Heli Pad is online now Find More Posts by Heli Pad
Old Dec 31, 2012, 02:26 PM
153stars is offline
Find More Posts by 153stars
United States, IL, Braidwood
Joined Nov 2012
There is no model memory so switching would be a pain. Doublehorse is a durable easy to fly heli. Hobbypartz is only 7 & 5 shipping
153stars is offline Find More Posts by 153stars
Old Dec 31, 2012, 02:35 PM
Jasen40 is offline
Find More Posts by Jasen40
United States, CA, San Jose
Joined Jun 2012
Maybe it will get better after a few charges.You can check the voltage and amps with a meter.
Jasen40 is offline Find More Posts by Jasen40
Old Dec 31, 2012, 02:40 PM
Canada, AB, Calgary
Joined Aug 2012
Too much wifey cuteness in my house for a v911. Living on the edge of the Rocky Mountains gets you roller coaster weather. This week is lookig like this:
Name: Weather For Calgary Alberta Canada on December 31 2012.jpg
Description: Weather For Calgary Alberta Canada on December 31 2012
Christmas week was 20'C colder and yes we had a 'White Christmas'. Average is halfway in between and usually too windy to fly outside. I'm ready to test my TX mods at the church hall.
coaldust is offline
Joined Apr 2012
just put two packs through it again, both drifted a bit, two click on rudder trim and it was perfect, then after that it needed no clicks on trim lol i have no idea, only thing is the tx resets rudder trim on start up.
maybe im to used to my hk450 TT heh. still fly great for the price
Old Dec 31, 2012, 02:41 PM
Jasen40 is offline
Joined Jun 2012
The 9116 I had moved like a bus.Great FFF speed,but poor handling.What I hated was changing the tail motor out every 10 flights.WL toy has a helicopter in the same class, I believe the TX is compatible with a V911,not 100 % sure though.
I use the 9116tx with my Wl toys helicopters and quads, and I am very happy with it.
Old Dec 31, 2012, 02:44 PM
jwilkers is offline
Find More Posts by jwilkers
Amateur copter crasher.
United States, OH, Worthington
Joined Dec 2012
Banggood is rocking! I ordered a y911 (as a spare) on the 24th.. It is here in my house now! 5 days from ship to delivery. They shipped on the day I ordered. I have a ton of parts I ordered on the 25th, so I expect them wed. All I really noticed different was a sturdier skid, although I didn't take too close of a look. The swash looks the same from a casual glance.
jwilkers is offline Find More Posts by jwilkers
New Product Jiuchon 9C002, a Solo Pro clone? SoloProFan Micro Helis 103 Feb 29, 2012 03:24 PM
Discussion Interesting Solo Pro? Clone gordonzo Micro Helis 46 Nov 30, 2011 04:15 AM
Question Which 100 sized heli after Solo Pro? Tuc Micro Helis 16 Jun 13, 2011 02:52 PM
Sold $100 !NEW ARF Storm 250 (Trex Clone) With Align Upgrades, Tons of Extras! $100!! RChelisrule Aircraft - Electric - Helis (FS/W) 1 May 31, 2011 01:26 AM
