Old Dec 24, 2012, 05:06 PM
Jasen40 is online now
Find More Posts by Jasen40
United States, CA, San Jose
Joined Jun 2012
Originally Posted by Bat97 View Post
Hello everyone, I'm very new to this hobby and looking forward to a great adventure! I just ordered my V911 last night and anxiously waiting for it. This will be my first RC helicopter or any RC ever. Don't worry I am a fast learner and I have you people to ask for any tips, suggestions and advice. What a way to start I'm posting on page 1000 of 1000!
Bat
It might easier to learn this bird if you move the links to the short balls and the inner hole on the servos.
Jasen40 is online now Find More Posts by Jasen40
Old Dec 24, 2012, 05:07 PM
2_Crash_Thumbs is offline
Find More Posts by 2_Crash_Thumbs
2_Crash_Thumbs's Avatar
Canada, AB, Calgary
Joined Aug 2012
Originally Posted by jefverstraeten View Post
...Maybe there is a possiblitie to invers the throttle on the TX...
It is possible to rearrange the throttle wiring on the PCB.
There are no circuit tracings on the top of the PCB and all changes could be made on the bottom side. I hesitate to explain in more detail as I think that the project should not be undertaken without sufficient tools, knowledge and skill. A person with the sufficient tools, knowledge and skill would also to discover the rest of the project details.
In My Humble Opinion.
2_Crash_Thumbs is offline Find More Posts by 2_Crash_Thumbs
Old Dec 24, 2012, 05:10 PM
LarryCnAZ is offline
Find More Posts by LarryCnAZ
United States, AZ, Tucson
Joined Dec 2011
Originally Posted by jlk69 View Post
You can download the eepe file here
Thanks jlk69, I just downloaded and wrote it to the TX but now my 9x won't bind. Guess I'm worse at this than I thought.
LarryCnAZ is offline Find More Posts by LarryCnAZ
Old Dec 24, 2012, 08:15 PM
bflan2001 is offline
Find More Posts by bflan2001
Always borking my corter
United States, CA, Mountain View
Joined Feb 2012
Has anyone ever tried using an MSR main motor? I just measured it with some calipers and it is exactly the same size as the Solo Pro 270 motor, which I'm pretty sure is the same size as the stock V911 motor. First I read that the SP 270 motor was an upgrade, then someone said they did it and didn't feel any difference. Maybe the MSR motor is more powerful? I would try this one but unfortunately it has some shotgun damage haha
bflan2001 is offline Find More Posts by bflan2001
Old Dec 24, 2012, 08:25 PM
Canada, AB, Calgary
Joined Aug 2012
[QUOTE=bflan2001;23613199]Has anyone ever tried using an MSR main motor?/QUOTE]
I did and It didn't work as well as the stock motor in my y911.
Old Dec 24, 2012, 08:29 PM
Joined Feb 2012
Hhhmmm, so maybe the v911 main motor would be an upgrade for the MSR! I will have to test that out when my new v911 motors come in.
Old Dec 24, 2012, 11:30 PM
153stars is offline
Find More Posts by 153stars
United States, IL, Braidwood
Joined Nov 2012
Originally Posted by redtags View Post
Hi Tigger, nice to know you are still around
Thanks for the link, will get some motor from them. Very cheap. That 1 is for tail right ? Do you have link for the main motor as well ? They sell v911 batteries as well I noted.
If in US tmart has the pair. Of motors cheap
153stars is offline Find More Posts by 153stars
Old Dec 25, 2012, 12:25 AM
Joined Feb 2012
This info is probably buried in this thread somewhere, but I figured I would post it again to hopefully help out someone like myself...
I have a ton of MSR/MCX2 batteries that I wanted to use in my V911. After experimenting with MSR skids, MCX2 skids and stock new-style skids, I decided it was too much work to convert it. None of them lined up properly. I happened to have some of the older style V911 skids that I ordered by mistake, and finally figured out that you can just clip the wires off them and the MSR batteries fit perfectly and snugly in place. Very simple, easy, and gives you a million more options for batteries. And as a bonus, the older skids are more heavy-duty and look like they can take a beating.
Old Dec 25, 2012, 12:40 AM
tippytoe is offline
Find More Posts by tippytoe
United States, PA, Reading
Joined Mar 2009
I received a V911 from a customer and have flown it around 6 or 7 times.No crashes,just simple flyin to check her out. (GiantScale) Went to fly and it will not bind at all. Batts. charged and trans batts new. Tried every combo to get it to bind,but nothing! Turn on trans. and it does its beeping, insert batt into heli, heli LED. flickers then just does a steady flash.Nothing. Inserted heli batt first then turn on transm., No bind at all. This heli was pretty nice,besides this problem. Penny for your thoughts guys....
tippytoe is offline Find More Posts by tippytoe
Old Dec 25, 2012, 01:44 AM
Joined Jun 2012
The Bravo sx motor has a little more pep, and fits nicely.
Old Dec 25, 2012, 12:10 PM
stonecutter is offline
Find More Posts by stonecutter
Sir Crashalot
stonecutter's Avatar
Joined Oct 2011
Often times non binding is caused by a bad crystal, the cylindrical thing near he bottom of the board. They can be replaced, but requires some soldering.
stonecutter is offline Find More Posts by stonecutter
Old Dec 25, 2012, 12:27 PM
GiantScale is offline
Find More Posts by GiantScale
Iowa City Iowa
Joined Jun 2000
Try this.. strange though since it was working before already.
I'm not sure.. But after I I pushed the sticks "down".. yes vertically. I bound a old style Tx to a new style heli.. I had no luck binding before I found the video and pushed down.. I hope that works..
GiantScale is offline Find More Posts by GiantScale
Old Dec 25, 2012, 01:07 PM
tippytoe is offline
Joined Mar 2009
It's fixed!! It was the transmitter. The left stick was the culprit,I think there was some really large glue bits impeding the stick's movement. I believe the obstruction was preventing the stick from totally reaching the bottom of throttle position for initializing. Bill
Old Dec 25, 2012, 02:31 PM
shahram72 is offline
Find More Posts by shahram72
United States, SC, Irmo
Joined Sep 2011
Did I mention how much I hate the original plug design? Awful. Requires so much force to insert the battery. It's only a matter of time before I break the heli. I ordered a charger and 2 batts and one batt is bad. I will be junking them and ordering new skids with a new charger and batts. Nice little heli, but my elevator servo is twitchy and bad already. Maybe I should just get another BNF.
shahram72 is offline Find More Posts by shahram72
Old Dec 25, 2012, 02:50 PM
jefverstraeten is offline
Find More Posts by jefverstraeten
RC-flyer
Heist op den Berg / Belgium
Joined Mar 2006
Thanks 2_crash_thumbs but i'm a bit reluctant to do that yet.
But maybe there is another solution, perhaps there are other TX's on the market that would bind with the V911.
jefverstraeten is offline Find More Posts by jefverstraeten
New Product Jiuchon 9C002, a Solo Pro clone? SoloProFan Micro Helis 103 Feb 29, 2012 02:24 PM
Discussion Interesting Solo Pro? Clone gordonzo Micro Helis 46 Nov 30, 2011 03:15 AM
Question Which 100 sized heli after Solo Pro? Tuc Micro Helis 16 Jun 13, 2011 01:52 PM
Sold $100 !NEW ARF Storm 250 (Trex Clone) With Align Upgrades, Tons of Extras! $100!! RChelisrule Aircraft - Electric - Helis (FS/W) 1 May 31, 2011 12:26 AM
