Canada, NS, Yarmouth
Topmodel Ventus 2cx build and electric conversion
I have been looking at buying a Topmodel Ventus for nearly 2 years now and the opportunity to own one of these beauties finally presented itself to me. I picked up the plane at the ICARE warehouse whilst on holiday in Montreal.
As far as I am aware, there is no slope flying or aero-towing happening in my part of the woods, so I am going to mount an electric motor in the nose. Fortunately there are electric nose mounted sustainers on full scale gliders these days, so I can make a case for it being a scale glider (maybe the folding prop is a little on the big side) Also much more affordable than the commercial SLS units.http://soaringcafe.com/2011/03/maide...ulsion-system/ I found the following threads about the same model on RC Groups; http://www.rcgroups.com/forums/showt...opmodel+ventus http://www.rcgroups.com/forums/showt...opmodel+ventus Pictures and build log to follow Frans |
The Ventus came well packaged and had no damage. Everything was wrapped in bubble wrap or taped to the inside of the box. All-in-all it was a good first impression.
The fuselage comes with canopy already hinged and the latch is accessible through the canopy window. Retract, tail-wheel, tow-release and wire-harness were also installed. The gaps at the retract doors are a little bigger than what I would like, but still a very solid installation. Paying a little extra for the delux kit is totally worth it. The wings are wood over foam, covered with oracover. Only on close inspection does one realise that it is not a moulded wing, yes it is that good. The wire-harness, wing retainer and spoilers were already installed. Flaps and ailerons were already hinged with tape. I hate it when they use the covering material as hinging material, so seeing tape hinges is a nice touch. Pictures as promised............
After installing the wing servos, I started work on the wiring-harness. The wiring-harness and connectors at the wing root were already installed, but I still had to solder the servo leads onto the harness and attach servo plugs to the wires in the fuselage.
Next up was the most stressful part of the build, cutting the nose. After measuring, marking and rechecking it a 100 times I committed to the cut. The last few millimeters I carefully did by sanding the nose by hand, till the spinner fitted perfectly. I then wrapped the motor in tape and attached it to firewall. Next I coated the inside of the nose and firewall with 20min epoxy and slid the motor into place. Then attached the spinner to make sure everything is lined up properly, while waiting for the epoxy to set.
Thank you for the advice SZD16, but I have to agree with Bie. That said, I am planning to user metal clevises on both sides of the elevator control rod.
Z-bends are not as elegant as a metal clevis, but they are quick and easy to make. Z-bends are also a little forgiving if everything is not lined up properly. If I was using metal servo arms, I will then most definitely use metal clevises or ball links to get a slop free setup. I always make sure that the hole for the wire in the plastic servo arm is a fraction smaller than the diameter of the wire I am using. That assures me a slop free setup. Over time the the hole in the plastic servo arm can get bigger and that has happened to me before with cheapo servos using soft plastics for their servo arms. I don't see how using a metal clevis will make the wear of a plastic servo arm significantly less. Frans |
Hi Highfly
I had to take some time out of the build to do some real work. I always laugh at when manufactures say that assembly time is only 3-5hours. It takes me that long just to install the control horns. I will have some time free around x-mass and will spend that time in my workshop with the ventus. ![]() Frans |
Seattle, WA, USA
Joined Oct 2005
I have the same ship and have also electrified mine with a nose prop. This suggestion is moot at this point since you have already glued in the mount - sorry, I only just saw the thread), but after using various glues over the years for mounting motors I've settled on West Systems G-Flex. It handles the vibration and is extremely tough. On the other hand, when using 20 minute epoxies years ago (such as Devcon) I have experienced them fracturing over time. I'd be concerned about using them for this application, especially in a ship at this price point.
Joined May 2010
Discus 2c Deluxe (ARF)
This is my take on Discus 2c Deluxe + FanAir 200 unit.
Zb/Esprit Model http://www.espritmodel.com/discus-2c-deluxe-arf.aspx |
| Thread Tools | |
| Discussion Ventus 2cx or Discus 2c Deluxe from Topmodel | thevirginian | Scale Sailplanes | 66 | Today 05:51 AM |
| Help! Topmodel Ventus 2cx - receiver | Tomas Hejzlar | Scale Sailplanes | 6 | Jan 14, 2011 07:35 AM |
| Discussion Ventus 2cx 6-meter Build | GudmundT | Scale Sailplanes | 147 | Aug 13, 2010 10:13 AM |
| Discussion Topmodel Ventus 2cx Questions | Heather | Scale Sailplanes | 7 | Aug 08, 2008 02:16 AM |
| Cool ventus 2cx topmodel | Antonio.adi | Power Systems | 3 | Aug 02, 2008 11:03 PM |
