Old Nov 29, 2011, 07:10 PM
zeroback is offline
Find More Posts by zeroback
United States, FL, Pompano Beach
Joined Oct 2011
Mini-Review
HK 2730 DIY kit
Hobby King 2730???? ( I haven't measured anything on this motor that correlates to these numbers)
Stator 22X5 mm single frame 9 or 10 laminations
3.3mm wire 20turns with inslation 0.30mm/.012" insulation sraped off
wind= distributed LRK W/ wye termination
14 poles
weight 26.5g
air gap=0.0893mm
Supposed to be a link to you tube of the motor run.
Special thanks to gobrushless.com and Brian Mulder at Southern soaring Club for the really great articles about motor winding, info so that a first time winder can have this kind of success.
I got the bug!
Have to build a few test devices (static thrust meter, a way to measure kv etc) Will continue to add data as it becomes available. The article on scavenging CD-rom motors got me to thinking.
I'm a Mercury Outboard tech and I was noticing the fly wheel and stator on an outboard remind me of something. There are 14 teeth on the stator and 12 magnetic poles on the fly wheel. I believe there is an LRK wind that could be used to make one heck of an out runner. The ring gear removed of course. I have all ready picked the parts out of my used stack of ... stuff. Thats a bit ambitious and will take a little time to engineer the shaft and probably have to come up with different magnets
But back to airplanes I have already started another LRK wind motor ( 25mm stator) will publish as it moves along.
zeroback is offline Find More Posts by zeroback
Reply With Quote  (Disabled)
Old Nov 29, 2011, 07:28 PM
zeroback is offline
Joined Oct 2011
Completion photos
Old Nov 29, 2011, 07:48 PM
zeroback is offline
Joined Oct 2011
RCPowers Extra 300S is a home for this motor...I think
Old Nov 29, 2011, 07:52 PM
zeroback is offline
Joined Oct 2011
Fixing Utube link
Old Nov 29, 2011, 09:19 PM
Bill Smudge is offline
Find More Posts by Bill Smudge
Bill Smudge's Avatar
United States, KY, Bowling Green
Joined Jul 2011
Hey Zero,
Your winds look very nice and neat, did the motor run ok?
One caution I have for you, the vise grips on the motor tube might be a bad thing. I believe most of the motor tubes are pretty soft aluminum and can distort pretty easy on the small motors. I learned this the hard way by over tightening grub screws on a fire wall motor mount caused the tube to mash a bearing too much and ruined the bearings..
btw your youtube link seems not to work.
Take it easy,
Bill
Bill Smudge is offline Find More Posts by Bill Smudge
Old Nov 29, 2011, 11:06 PM
zeroback is offline
Joined Oct 2011
The test prop is a 10X4.7 APC SF. didnt have help to check rpm (it was dark outside) didn't want to work in the dark with a flash light.
2205/20 (3 min 22 sec)
Old Nov 29, 2011, 11:09 PM
zeroback is offline
Joined Oct 2011
Thank you for the caution on the bearing tube. The motor mount was supposed to be included. HK svc. department is working on sending it to me.
I got the video working, I really like the sound!
Old Dec 11, 2011, 08:55 AM
zeroback is offline
Joined Oct 2011
The Hobby King promised a motor mount and I'm still waiting.
Old Dec 11, 2011, 12:57 PM
Ron van Sommeren is offline
Find More Posts by Ron van Sommeren
homo ludens modellisticus
Ron van Sommeren's Avatar
Netherlands, GE, Nijmegen
Joined Feb 2001
Originally Posted by zeroback View Post
Hobby King 2730???? ...
www.aircraft-world.com is more likely.
Vriendelijke groeten Ron
diy motor tips Drive Calculator
diy motor group Cumulus MFC
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Dec 11, 2011, 08:13 PM
lectroglide is offline
Find More Posts by lectroglide
lectroglide's Avatar
United States, WA, Puyallup
Joined Aug 2006
Originally Posted by Ron van Sommeren View Post
motor in the pix looks like a double stator??
lectroglide is offline Find More Posts by lectroglide
Old Dec 12, 2011, 05:12 AM
Joined Feb 2001
Difficult to tell from down here.
diy motor tipsDrive Calculator
diy motor groupCumulus MFC
Old Dec 12, 2011, 07:18 AM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
Looks like a single stator motor in this photo:
http://static.rcgroups.net/forums/at...g?d=1322611569
Jack
jackerbes is offline Find More Posts by jackerbes
Old Dec 12, 2011, 11:55 AM
Joined Aug 2006
we must be looking at 2 diffrent things, the motor kit on that site ron posted is a double stator
Old Dec 12, 2011, 02:00 PM
Jack
USA, ME, Ellsworth
Joined May 2008
We must have been, I was talking about the kit in the photos in post #1 here.
You must be talking about this one at Air Craft:
http://www.aircraft-world.com/shopexd.asp?id=6376
Here is the datasheet on it:
http://aircraft-world.com/prod_datasheets/rcr-rev.htm
and here are the assembly notes:
http://aircraft-world.com/prod_datas...r-rev-assy.htm
And it does look like the stator is two of them stacked that have slightly different finishes on the ends of the hammerheads. But they describe it as a as "..a whopping 10mm long, 20.2mm diameter 9-pole stator...".
Jack
Old Dec 12, 2011, 05:46 PM
Joined Aug 2006
"WHOPPING? Ha, sounds like a burger from "jack in the box" all seriousness aside that double info you posted looks like fun prodject/wind, at a reasonable price too, ya cant have enuff prodjects! as if I need anymore
Discussion DIY PPM Sum for HK-T6A Version 1 Users ben123 Multirotor Talk 1 Apr 30, 2013 03:45 PM
Mini-Review HXT 2730-1500 (~1690Kv) and Turnigy R&B 2730-1500 (~1600Kv) Dr Kiwi Power Systems 73 Mar 07, 2012 05:14 PM
Discussion Were is the UH 2730 DIY Kit thread ?? Bare Electric Motor Design and Construction 2 Jan 17, 2008 12:57 PM
