This thread is privately moderated by boredom.is.me, who may elect to delete unwanted replies.
Old Jan 10, 2012, 07:43 AM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Originally Posted by phil alvirez View Post
ungn is talking about 6400T.
what he says makes sense:
i just checked 6400L, which has a little bit longer servos: 4.92
and just in case, i checked weights of the original 6400: 3.90
by the way, the brick on the champ weighs the same: 3.90-although it is de-tuned to develop less power, as confirmed by horizon.
i did bench tests on both (detailed figures somewhere in my blog).
Phil, your scale is off.
Depending on the wire length, a Champ/J-3/PKZ3351 brick weighs between 3.60 and 3.75.
The difference between it and the AR6400 and the Champ brick are the 3 plugs soldered to it.
The AR6400L weight listed is correct.
I have a couple nib, one weighs 4.21g, the other 4.23g.
Also, the T has the longer servos of the L, so Horizon should have named it LT.
UNGN is offline Find More Posts by UNGN
Old Jan 10, 2012, 01:38 PM
phil alvirez is offline
Find More Posts by phil alvirez
Windsor, Canada, near Detroit
Joined Jul 2007
checking weights again
ok. it is not the scale. i checked again-several times-and got this:
champ brick: 3.90
original 6400 brick: 3.90
longer servos 6400: 4.08
all same wire lenght.
so, i don't know if there are variations of those models. sometimes during manufacturing they just change something and don't tell. but again, these are the weights i got.
the 4.96 i had was with an extra connector that i overlooked when weighing. i already corrected it on the post.
phil alvirez is offline Find More Posts by phil alvirez
Old Jan 10, 2012, 02:01 PM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
Are we all agreeing on weights now?
boredom.is.me is offline Find More Posts by boredom.is.me
Old Jan 11, 2012, 03:01 PM
red_z06 is offline
Find More Posts by red_z06
plank n shankbone pilot
red_z06's Avatar
Dumont, NJ
Joined Feb 2005
Spek AR6400LBL 7.8g
TechOne C05 3400kv motor for 2s 5.5g
ThunderPower 1s160mah 5.0g
red_z06 is offline Find More Posts by red_z06
Old Jan 15, 2012, 04:39 AM
Joined Jul 2007
carbon fiber rods
1 meter long (40 in.):
0.5mm---0.36 grams---(0.009 grams/inch)
0.6mm---0.42-----------(0.011 " )
0.8-------0.80-----------(0.020)
1.0-------1.25-----------(0.030)
1.5-------2.90-----------(0.074)
Old Jan 15, 2012, 12:02 PM
Joined Jul 2007
fiberglass cloth
ultra-thin fiberglass cloth 18 grams per sq meter (PRODUCT ID: GF-003MQS)
(ideal for lightweight reinforcements with epoxy or whatever) found it here:
http://www.hobbyking.com/hobbyking/s...dProduct=10905
Old Jan 16, 2012, 01:22 PM
Joined Jul 2007
carbon fiber veil
carbon fiber veil: 6.7 gr/sq meter
aka mat, tissue, from cst, about $16
on post 9, Andy asks for use of this: for cowlings or nose cones, i carve the piece from soft foam, cover it with saran wrap, epoxy, then the cf, and saran wrap again,well stretched. when cured, remove the wrap and add microbaloons mixed with epoxy. let cure, sand and cover with shrink covering or paint. remove from the core. look at my stick and tissue models on my blog-somewhere on page 2 or 3.
Old Jan 16, 2012, 01:32 PM
356Jim is offline
Find More Posts by 356Jim
West of California Speedway, East of LaLa, North of Disneyland
Joined May 2001
Some foam weights I just measured:
Selitac 1 mm 80 gm/m^2
Selitac 2 mm 81 gm/m^2
Proformance 1 mm 58 gm/m^2
Now, the 2 Selitac samples were both quite inaccurate in thickness, being 1.67mm and 2.77 mm, respectively. Obviously, the "closeness" in my density calculations is due to differences in the absolute densities of the differing batches they came from. My scale is accurate to 0.01 gm, less than 0.25% of the weights measured. (My Ohaus calibration weights are accurate to 0.04% at 5 gms (ASTM Class 6, e.g., 2 mg/5gm).
356Jim is offline Find More Posts by 356Jim
Old Jan 18, 2012, 10:14 AM
Joined Jul 2007
EPP foam, white
1.3 density:
6mm: 124 (g/sq meter) >>>(this 1 is shown on page 2 but with no density)
9mm: 183
1.9 density:
6mm: 183
9mm: 275
Old Jan 26, 2012, 04:55 AM
nemoskull is offline
Find More Posts by nemoskull
Pilot, Co-pilot, Navagator
nemoskull's Avatar
United States, AZ, Yuma
Joined Sep 2009
esaki black tissue, pre tusnami. 3.4g a sheet (17.5 X 23.5)
or 1.19 gram/square foot
nemoskull is offline Find More Posts by nemoskull
Old Feb 25, 2012, 09:29 PM
numanair is offline
Find More Posts by numanair
numanair's Avatar
United States, WA, Kirkland
Joined Sep 2010
I think the hk-5320 is mislabeled as a 5230 in the original post.
numanair is offline Find More Posts by numanair
Old Feb 26, 2012, 05:22 PM
Joined Nov 2007
Fixed
Old Feb 29, 2012, 01:06 AM
numanair is offline
numanair's Avatar
Joined Sep 2010
Dollar tree foam board without paper: 76.90 g/m2
With paper: 34.91 g/m2
Old Feb 29, 2012, 01:41 AM
Joined Nov 2007
I assume that you have that backwards.
Old Feb 29, 2012, 02:20 AM
numanair is offline
numanair's Avatar
Joined Sep 2010
Oops! Yep that's backwards.
Discussion Esky Lama V3/V4 component weight data knutb Coaxial Helicopters 4 Jan 05, 2009 10:58 PM
watts/weight chart thingy buffpants24 Parkflyers 3 Apr 16, 2005 10:46 PM
Covering Weight Chart genovia Parkflyers 14 Oct 21, 2003 08:05 PM
Oracover/Ultracote weight chart here Balin Electric Plane Talk 1 Nov 26, 2002 12:06 AM
Cell/Pack weight... chart?? JamesMadison10 Parkflyers 7 Mar 12, 2002 11:24 PM
