This thread is privately moderated by boredom.is.me, who may elect to delete unwanted replies.
Old Dec 31, 2011, 04:17 PM
glenn2626 is offline
Find More Posts by glenn2626
RC Connectors dot com
glenn2626's Avatar
United States, CO, Colorado Springs
Chris' post made me think...
If there's any connector parts that you guys need weighed, let me know.
For instance, I can easily get weights of the red jst connectors without any wires, including 2 pins.
If I have it in stock I'll be glad to weigh it. (and if it's micro RC plane related, you know I've got it)
Glenn
glenn2626 is offline Find More Posts by glenn2626
Latest blog entry: Horrible "MX" connector on...
Old Dec 31, 2011, 06:58 PM
phil alvirez is offline
Find More Posts by phil alvirez
Windsor, Canada, near Detroit
Joined Jul 2007
APC props
APC props:
04141 2.94 gr
04541 3.38
04742 2.91
04747 3.11
06040E 4.57
06040EP 4.57 (left hand)
06055E 5.02
07038WSE 7.06
how large can we go to still be considered micro?...
phil alvirez is offline Find More Posts by phil alvirez
Old Jan 02, 2012, 06:34 AM
starscream4002 is offline
Find More Posts by starscream4002
starscream4002's Avatar
Tabriz, Iran
Joined Sep 2008
Sorry for the confusion but the brick weight I posted is without motor wires. with the motor wires it comes at 3.71g.
SS
starscream4002 is offline Find More Posts by starscream4002
Old Jan 02, 2012, 09:28 AM
Joined Jul 2007
to be sure
SS
i guess you are talking about this: Kyosho minium brick: 3.21g. (your post 54/page 4)
right?
Old Jan 02, 2012, 09:50 AM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
I have a minium brick that weighs 3.60g with 1" motor wires.
This seems heavy, but that is what the scale says.
UNGN is offline Find More Posts by UNGN
Old Jan 02, 2012, 10:48 AM
Tabriz, Iran
Joined Sep 2008
Yes "phil alvirez".
UNGN, I've also added a connector.
SS
Old Jan 02, 2012, 11:24 AM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
4-site Gearbox - 1.78g
Old Jan 02, 2012, 03:22 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
The R610 RX listed seems a little light.
I have 2 of them. The old one (large Cap) weights 3.99g with a brand new R610 (small Cap) weighs 3.67g.
Both are no case with satelite hook up.
Neither are anywhere near 2.5g. The connectors would need to be modified to get to 2.5g.
Old Jan 04, 2012, 06:40 AM
nemoskull is offline
Find More Posts by nemoskull
Pilot, Co-pilot, Navagator
nemoskull's Avatar
United States, AZ, Yuma
Joined Sep 2009
yeah, the r610 data is wrong. i got one down to 2.5 grams by removing (not cutting) all the pins and clipping off the sat connector and replacing the cap with a ceramic one.
on way its 2.5 grams stock. the r415 is, tho.
nemoskull is offline Find More Posts by nemoskull
Old Jan 06, 2012, 12:48 PM
RNAF is offline
Find More Posts by RNAF
RNAF's Avatar
The Netherlands
Joined Dec 2003
Brushless category
hexTronik 2 gram Brushless Outrunner 7700kv 2.1 grams
On my scale. Seems to vary per batch/ person. Probably due to wire length or other densities (magnets, bell etc.). Mostly around this weight.
Propellors
MicroInvent MCF 5030S 0.5 grams
Just as specified by the manufacturer. This prop is intended to be screwed on the motor/ gearbox shaft with the use of washers and a screw.
I bought a plastic adapter with is a push-on (1mm shaft) and uses two rubber bands. The weight stated above is CF prop only.
RNAF is offline Find More Posts by RNAF
Old Jan 09, 2012, 11:02 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Not sure where the AR6400T weight came from, but it is way off.
The AR6400T weighs 4.70g
Old Jan 09, 2012, 11:22 PM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
I got it from Spektrum.
boredom.is.me is offline Find More Posts by boredom.is.me
Old Jan 09, 2012, 11:24 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
They must have borrowed HK's scale.
Old Jan 09, 2012, 11:26 PM
Joined Nov 2007
lol
I'll update everything from the last week or so in the morning.
Old Jan 10, 2012, 04:19 AM
Joined Jul 2007
6400l
ungn is talking about 6400T.
what he says makes sense:
i just checked 6400L, which has a little bit longer servos: 4.08 edit:>>>corrected weight<<<
and just in case, i checked weights of the original 6400: 3.90
by the way, the brick on the champ weighs the same: 3.90-although it is de-tuned to develop less power, as confirmed by horizon.
i did bench tests on both (detailed figures somewhere in my blog).
Discussion Esky Lama V3/V4 component weight data knutb Coaxial Helicopters 4 Jan 05, 2009 09:58 PM
watts/weight chart thingy buffpants24 Parkflyers 3 Apr 16, 2005 09:46 PM
Covering Weight Chart genovia Parkflyers 14 Oct 21, 2003 07:05 PM
Oracover/Ultracote weight chart here Balin Electric Plane Talk 1 Nov 25, 2002 11:06 PM
Cell/Pack weight... chart?? JamesMadison10 Parkflyers 7 Mar 12, 2002 10:24 PM
