This thread is privately moderated by boredom.is.me, who may elect to delete unwanted replies.
Old Dec 11, 2011, 06:08 PM
phil alvirez is offline
Find More Posts by phil alvirez
Windsor, Canada, near Detroit
Joined Jul 2007
it always matters
Originally Posted by boredom.is.me View Post
It would be really funny when someone asks how much something weighs, a week from now when this thread drops... It's going to happen.
if it really happens still would be very convenient to have that data available somewhere. for instance you may add to your blog so the data will be available whenever.
phil alvirez is offline Find More Posts by phil alvirez
Old Dec 12, 2011, 02:38 AM
flying-llama is offline
Find More Posts by flying-llama
Sopwith Camel's Cousin
Between my tx and crashed aircraft
Joined Mar 2006
I think this is the type of thread that should be made into a sticky so that it stays on top.
I wish I knew the procedure for asking to make it a sticky.
flying-llama is offline Find More Posts by flying-llama
Old Dec 12, 2011, 04:13 AM
Graham Stabler is offline
Find More Posts by Graham Stabler
Sticky Shepherd
Graham Stabler's Avatar
Oxford/England
Joined May 2001
I have stuck the thread for a while as requested so people see it, later it can be unstuck and added to the index.
Graham Stabler is offline Find More Posts by Graham Stabler
Old Dec 12, 2011, 06:45 AM
scruffy1 is offline
Find More Posts by scruffy1
looking up down under
scruffy1's Avatar
Australia, NSW, Fairlight
Joined Feb 2008
full river 50mah lipo 1.6gm
scruffy1 is offline Find More Posts by scruffy1
Old Dec 12, 2011, 05:59 PM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
Sweet, thanks.
Is there any other categories people would like to see?
boredom.is.me is offline Find More Posts by boredom.is.me
Old Dec 13, 2011, 02:26 AM
David T is offline
Find More Posts by David T
UK
Joined Aug 2000
How about depron and alternatives.
dt.
David T is offline Find More Posts by David T
Old Dec 13, 2011, 02:29 AM
David T is offline
UK
Joined Aug 2000
I have these:
Sheet materials g/m2
EPP White 3mm 70
EPP White 6mm 124
EPP Grey 27mm 737
EPP White 150mm 3000
Kneeling pad Green 24mm 2111
Polystyrene White 6mm 94
Polystyrene White 12mm 189
Polystyrene White 18mm 14.7kg foam (1226x715 248g) 283
Blue foam 3mm 92
Blue foam 6mm 184
Blue foam 10mm 307
Styrofoam I.B. Blue foam 75mm 2306
Correx 2mm Clear 293
Correx 2mm Black 303
Great Planes Pro Formance (1mm) 49
Durobatics (1.3mm) 63
Depron; white (0.5mm) 51
Depron; white (1.1mm China - film removed 1 side) 80
Depron 'Selitac'; green (2mm) 82
Depron; white (1mm) 100
Depron; white (2.2mm) 112
Depron; grey (3mm) 121
Depron; white (3mm) 135
Depron; white (5mm) 217
Depron 'Selitron'; white (6mm) 232
Depron with skin; white (6mm) 353
Old Dec 13, 2011, 08:43 AM
Joined Nov 2007
Nice, I'll add those.
Old Dec 13, 2011, 12:18 PM
starscream4002 is offline
Find More Posts by starscream4002
starscream4002's Avatar
Tabriz, Iran
Joined Sep 2008
Kyosho minium brick: 3.21g
Kyosho minium 6mm motor and gearbox: 2.20
SS
starscream4002 is offline Find More Posts by starscream4002
Old Dec 13, 2011, 06:48 PM
Joined Nov 2007
Which brick is it? I have the AD one listed for 5.70g.
Old Dec 13, 2011, 08:53 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
That is the regular minium brick.
UNGN is offline Find More Posts by UNGN
Old Dec 14, 2011, 03:28 AM
Joined Mar 2006
Originally Posted by David T View Post
I have these:
EPP White 3mm 70
EPP White 6mm 124
It might be good to note that there is often quite a variation in foam weight for various reasons.
For EPP, which is often cut to the proper thickness, 3 sources of variation are:
A. variations in how thick the actual cut is
B. Variation in foam density (there is 1.3, 1.9, etc.), I forget the units
C. whether the sheet is hot wire cut (forms a dense but strong skin on the foam surface) or not
Old Dec 14, 2011, 07:45 PM
Joined Nov 2007
Good call. I completely forgot about the stuff you mentioned.
Old Dec 14, 2011, 07:55 PM
glenn2626 is offline
Find More Posts by glenn2626
RC Connectors dot com
glenn2626's Avatar
United States, CO, Colorado Springs
Great thread idea Kev, and lots of good info, keep it up.
glenn2626 is offline Find More Posts by glenn2626
Latest blog entry: Horrible "MX" connector on...
Old Dec 19, 2011, 11:55 AM
g_kandylakis is offline
Find More Posts by g_kandylakis
free flight or micro RC ???
g_kandylakis's Avatar
Greece, Central Macedonia, Thessalonika
Joined May 2006
Excellent idea !
took me some days to notice this thread
Some input from me as well
Zippy Lipo batteries, with welded PZ type connectors
50mAh 20C, 2,05gr
70mAh 20C, 2,30gr
100mAh 20C, 3,17gr
Hyperion G3 Lipo batteries, with factory connectors
70mAh 25C, 2,51gr
130mAh 25C, 3,92gr
160mAh 25C, 4,76gr
There must be an error in the batteries list, the Hyperion 240 is listed twice, the first value at 3,22gr is wrong, or the battery type...
e-Flight battery 250mAh 20C (for Parkzone Mosquito) 8,56gr
Brushless ESC YGE 4S 4A, 0,6gr without wires, 1,1 with motor wires+connector
Brushless motors
Microinvent Classic 22, 2,9gr without wires, 3,2 with wires+connector
Gasparin G15 4W, 4,6gr including mount+wires+connector
Gasparin G15 5W, 5,8gr including mount+wires+connector
Gasparin G10 Micro 30, 2,4gr including mount
A final suggestion, to somehow sort individual entities within a table, for example batteries by capacity or maker...
George
g_kandylakis is offline Find More Posts by g_kandylakis
Discussion Esky Lama V3/V4 component weight data knutb Coaxial Helicopters 4 Jan 05, 2009 09:58 PM
watts/weight chart thingy buffpants24 Parkflyers 3 Apr 16, 2005 09:46 PM
Covering Weight Chart genovia Parkflyers 14 Oct 21, 2003 07:05 PM
Oracover/Ultracote weight chart here Balin Electric Plane Talk 1 Nov 25, 2002 11:06 PM
Cell/Pack weight... chart?? JamesMadison10 Parkflyers 7 Mar 12, 2002 10:24 PM
