This thread is privately moderated by boredom.is.me, who may elect to delete unwanted replies.
Old Dec 01, 2011, 10:45 AM
miatamama is online now
Find More Posts by miatamama
miataman
miatamama's Avatar
Erie Pa.
Joined Oct 2007
HK 5230 Servos 1.9 with arm
JCS
miatamama is online now Find More Posts by miatamama
Old Dec 01, 2011, 10:48 AM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
Originally Posted by BryanEW710 View Post
What brand are the "LZ" items?
Microflierradio - not cheap but some really nice servos.
boredom.is.me is offline Find More Posts by boredom.is.me
Old Dec 01, 2011, 08:27 PM
Andy2No is offline
Find More Posts by Andy2No
NaN
Andy2No's Avatar
Manchester, UK
Joined Nov 2005
Originally Posted by Terry Rigden View Post
Thanks for the tip I will bear it in mind and try again with a metal pan on the scales.
Terry
I think that would have to be a non-ferrous one, e.g. aluminium, but I would think a closed cardboard box would work better - it's distancing the magnets from the scales that counts.
I wouldn't have thought of it either, and I guess it applies to weighing servos too.
Andy2No is offline Find More Posts by Andy2No
Old Dec 01, 2011, 09:10 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Brushless ESC's:
XP-7a (with wires/connector): 4.62g
HK 3A ESC: .79g
HK 3A Wiring Harness: .97g
Brushed ESC's:
Pixie-7P (with wires/connector): 3.28g
Landing Gear:
Mustang Wing gear with Mounts: 1.63g
T-28 Gear + wing mounts: 2.22g
Albatros Tire (1): .79g
J-3 Cub Tire (1): .45g
Props:
E-Flite 110 X 80mm 3 Blade: 1.40g
Corsair Nose Cone: .28g
UNGN is offline Find More Posts by UNGN
Old Dec 02, 2011, 05:33 AM
Terry Rigden is offline
Find More Posts by Terry Rigden
Terry Rigden's Avatar
UK, Bedworth
Joined Apr 2004
Actually I was going to try a ferrous tray to contain the magnetic field
Terry
Terry Rigden is offline Find More Posts by Terry Rigden
Old Dec 02, 2011, 06:24 AM
Andy2No is offline
NaN
Andy2No's Avatar
Manchester, UK
Joined Nov 2005
I don't think it will work, Terry. If you put a bit of steel on the end of a magnet, it effectively becomes part of the magnet.
The strength of the field drops off quite quickly with distance though, so all you need is something to distance the magnets from the pan of the scales, e.g. an empty box, a couple of inches thick, that you can stand things on top of.
Old Dec 02, 2011, 02:26 PM
phil alvirez is offline
Find More Posts by phil alvirez
Windsor, Canada, near Detroit
Joined Jul 2007
more weights
gws props:
6/3 : 2.2 gr
6/5 sf: 2.1
7/35: 2.9
7/6 sf: 3.4
R415 rx: 2.0
cirrus 1 cell esc-brushed
(p/n micro joule S5A1)
stock: 1.88
mod: 1.00
single cells:
turnigy 160: 4.24
nano 160: 4.54
hk 240 w/o wires/connectors: 5.21
ready: 5.87
hyperion 240: w/o: 6.5
ready: 7.5
servos:
HK 2g (p/n 282A): 2.6
HK 1.7g (p/n 5320 ): 2.0
1.5 shaft prop adapter for 6-7 gws: 0.8
(horizon p/n EFLM 1933)
phil alvirez is offline Find More Posts by phil alvirez
Old Dec 02, 2011, 03:54 PM
coriolan is offline
Find More Posts by coriolan
"Unnecessary Necessity"
coriolan's Avatar
Canada
Joined Sep 2006
FlyDream 4 ch. 2.4 Rx: 1.2 gram(with small Velcro on bottom)
TGY DP 3A, 1 cell esc: 1.5 gram(with all wiring and Molex-pico)
2.5 Grams Servo (from r/c Modules): 2.9 grams!
coriolan is offline Find More Posts by coriolan
Old Dec 02, 2011, 08:11 PM
Andy2No is offline
NaN
Andy2No's Avatar
Manchester, UK
Joined Nov 2005
Rx42 DSM2 Micro Actuator Receiver with 2A ESC and Connectors pre-fitted
Weight: 0.68 gm
A customised version of the Rx42, sold by Micron Radio Control (UK), which has Plantraco style motor and actuator sockets fitted, plus a short (35mm) power lead with a 2 pin polarised micro connector (pin is positive, socket is negative EDIT: so on the battery, the socket has to be positive, and the pin has to be negative).
http://www.micronradiocontrol.co.uk/...2_conn_2pinpwr
Other wiring options are available on request. I ordered one with a JST-SH servo socket for Pad C on a short trailing cable. Unfortunately, I forgot to weigh it before I sent it to DT to be reflashed. I'll do it when it comes back.
Old Dec 04, 2011, 04:33 PM
Andy2No is offline
NaN
Andy2No's Avatar
Manchester, UK
Joined Nov 2005
SuperMicro Systems Mi-LSM1300 linear servo
Quoted Specs:
Size: 18.1mm x 15.2mm x 7.8mm
Servo throw: 8mm
Weight: 1.1g (wires not included)
Torque: 35g @ 4.2V
Speed: 0.12s @ 4.2V
Voltage: 3.0V~4.2V
Actually weighs 10.7g for eight servos (to 0.1g) = 1.34g each (with cable and JST-SH plug for AR6400 / DT Rx33, as sold)
Sources: Micron Radio Control (UK) / HobbyKing (also known as HK1300 Single Linear Servo)
Old Dec 04, 2011, 04:50 PM
Andy2No is offline
NaN
Andy2No's Avatar
Manchester, UK
Joined Nov 2005
Falcon 1.6g servo 1.6g
Falcon 1.6g servo wired for AR6400 / DT Rx33 (custom option from http://www.micronradiocontrol.co.uk/...tml#flcn-servo) 1.8g
Old Dec 04, 2011, 04:53 PM
Andy2No is offline
NaN
Andy2No's Avatar
Manchester, UK
Joined Nov 2005
Not exactly a micro component, but just for reference:
Orange R610 2.4GHz 6CH DSM2 receiver in orange plastic case (as sold) 9.7g
Orange R410 2.4GHz 4CH DSM2 receiver (no case, as sold, plus some heatshrink to protect it, added by me) 2.6g
- Both of those are for Futaba / JR servo plugs. I have used both types on indoor planes - FlyingWings Bongo (6CH Rx) and MiniBongo (4CH Rx, used with "3.7g" servos)
Last edited by Andy2No; Dec 06, 2011 at 09:35 AM. Reason: Added model numbers of receivers
Old Dec 04, 2011, 06:26 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
HK GPS-8 Brushed 8.56mm Motor/Gearbox: 6.90g
Old Dec 08, 2011, 03:34 PM
Andy2No is offline
NaN
Andy2No's Avatar
Manchester, UK
Joined Nov 2005
boredom.is.me,
Are you planning to add the weights people are contributing to the tables in your first two posts?
Old Dec 08, 2011, 03:48 PM
Joined Nov 2007
I update it continuously. It has doubled in size from when I first posted.
I would prefer to not add modded weights because the human variable is very large.
Discussion Esky Lama V3/V4 component weight data knutb Coaxial Helicopters 4 Jan 05, 2009 10:58 PM
watts/weight chart thingy buffpants24 Parkflyers 3 Apr 16, 2005 10:46 PM
Covering Weight Chart genovia Parkflyers 14 Oct 21, 2003 08:05 PM
Oracover/Ultracote weight chart here Balin Electric Plane Talk 1 Nov 26, 2002 12:06 AM
Cell/Pack weight... chart?? JamesMadison10 Parkflyers 7 Mar 12, 2002 11:24 PM
