Old Dec 05, 2011, 09:45 AM
Washburn,ME
Joined Jul 2008
Tom, On my Stinson (Top Flite) with the DLE 30 i had two batteries under the fuel tank shelf. One was a sub-c 6 volt and the other was a 4.8 volt sub-c for ignition. I also put a brick style 6 volt under one of the front seats. Servos were installed per the plan. No extra weight was required. Balance point was right on target. I did use a tru-turn prop hub on the engine also. We still have no snow in northern Maine-should have kept the birds unpickled.
Frank
smithfj is offline Find More Posts by smithfj
Old Dec 05, 2011, 10:45 AM
Hamburger Eatin' Fool
TomCrump's Avatar
Traverse City, Michigan
Joined Dec 2005
Thanks, Frank.
I know, with the G-38, no weight is needed. That's why I was wondering about the DLE.
I wrongly assumed that weight would be required.
TomCrump is offline Find More Posts by TomCrump
Old Dec 05, 2011, 03:22 PM
Jack of all master of none
splinterz25's Avatar
Baltimore MD USA
Joined Jan 2011
Tom I don't know yet I haven't done the final balance but I used 1/4 scale servos in the forward area and they weigh more than reg. servos and I have alot going on in the cab and my dummy engine is a full scale model. so I made a batt. box mid section of the fuse for 4.8 v sub c batt. and the batt's for the ignition are between the servos for now. I will post what happens when I figure out how to balance this big bird.
Bruce
splinterz25 is offline Find More Posts by splinterz25
Old Jan 30, 2013, 07:08 AM
Australia, WA, Baldivis
Joined Jan 2012
I have been reading as much as I can on the Stinson, as it is my next project. Has anybody used the Saito Radial, the 170R3? it quotes 2.5 hp with a weight of 46oz. This is a bit over the specs for this, however I am looking for a plane to use as a tug for a 1/5 scale Minimoa from a Krick kit and a couple of other similar size gliders. Any thoughts would be greatly appreciated....
gliderguide is offline Find More Posts by gliderguide
Old Jan 30, 2013, 11:26 AM
Sackie's Avatar
Steinbach, MB, Canada
Joined Nov 2004
Hi Glider,
Not sure if you are aware, but there is at least one good thread in this forum with lots of info about the TF Stinson, the thread is http://www.rcgroups.com/forums/showthread.php?t=925665.
Lots of pictures as well, supplied by many guys, of their changes and builds along the way.
Sackie
Sackie is offline Find More Posts by Sackie
Old Jan 30, 2013, 04:39 PM
Baltimore MD USA
Joined Jan 2011
Here's another site. http://www.rcgroups.com/forums/membe...=344567&page=8
Good luck w/ your build I hope this helps,
Bruce
Sold NIB! Top Flite Stinson Reliant SR-9 Giant Kit w/100.5" WS...$150 SHIPPED2U! bighank13 Aircraft - Fuel - Airplanes (FS/W) 5 Nov 24, 2011 06:11 PM
Sold Top Flite Stinson Reliant SR-9 NIB cooper998 Aircraft - Fuel - Airplanes (FS/W) 0 Sep 08, 2009 07:17 AM
Question Top Flight Stinson Reliant SR-9 Kit rceagle1a Giant Scale Airplanes 8 Nov 23, 2007 08:41 AM
Sold Or Trade:Top Flite Stinson Reliant SR9 Kit NIB for a TF GE P51 Giant scale Kit rceagle1a Aircraft - Fuel - Airplanes (FS/W) 0 Jan 28, 2007 05:51 PM
