Old Nov 29, 2011, 09:59 AM
billd76 is offline
Find More Posts by billd76
billd76's Avatar
United States, PA, Nottingham
Joined Aug 2009
PA Extra MX with Hacker A40 10S
Good day,
I have a PA extra MX, here are the specs
Specifications
Wingspan: 1.472mm / 58 in
Length: 1316.5mm / 51.83 in
All up weight: approx 1750g / 61.7oz /3.85lb (using thrust 50 motor and two 3c2200 lipo's)
Wing area: 721 sq.in
Wing loading: 12oz/sq.ft
I'm planning on using the Hacker A40 10s with a 14 X 7 Xroar prop in this plan. What battery or batteries would give me the best results? 10s manual says no more than 5c Lipos. Could the motor handle the two battery 3c, 2200 MaH setup?
billd76 is offline Find More Posts by billd76
Old Nov 30, 2011, 10:56 PM
FL62 is offline
Find More Posts by FL62
Average Joe 2 Semi-Pro n Back!
FL62's Avatar
United States, AZ, Queen Creek
Joined Feb 2004
Bill, if you want to use the 6 cell setup like the manual recommends, the A40-14S would be the best choice.
FL62 is offline Find More Posts by FL62
Old Dec 01, 2011, 04:44 AM
billd76 is offline
billd76's Avatar
Joined Aug 2009
THanks, but bought the 10s, which is what the folks at hacker recommended. One guy on the Mx forum says he uses the 10S with a 4c batt and that it works great, guess I will give that a try. After all this, I'm thinking that probably should have spent the extra cash and just went the Thrust 50 setup
Discussion Hacker A40 10s billd76 Power Systems 0 Nov 02, 2011 12:04 PM
Discussion hacker A40 10s prop mounting billd76 Power Systems 2 Oct 31, 2011 08:31 PM
Sold Hacker A40-10S r/cdawg Aircraft - Electric - Power Systems (FS/W) 1 Oct 28, 2011 06:25 AM
Sold Hacker A40-10s V2 vienquach Aircraft - Electric - Power Systems (FS/W) 3 Sep 17, 2011 07:16 PM
Wanted Looking or a Hacker A40-10S Mr Big Head Aircraft - Electric - Power Systems (FS/W) 1 Sep 16, 2011 10:46 AM
