Old Sep 07, 2012, 01:46 PM
w4yn is offline
Find More Posts by w4yn
United States, NC, Charlotte
Joined Jan 2007
Originally Posted by FlyWW1 View Post
I just tried to take my aileron servos out to upgrade them and it's not happening without ripping a hole in the wing Anybody had any luck changing theirs? I'm screwed if they strip
Did you ever get an answer, I made a mess getting elevator and rudder servos out but there is enough foam left to make repairs there.
Would like to change ailerion servos out also.
Tim
w4yn is offline Find More Posts by w4yn
Old Sep 07, 2012, 01:58 PM
FlyWW1 is offline
Find More Posts by FlyWW1
FlyWW1's Avatar
United States, VA, Winchester
Joined Nov 2010
Tim
I could Dremel them out but I choose just to use them. I rarely fly the plane anymore so it's not a concern.
FlyWW1 is offline Find More Posts by FlyWW1
Old Sep 07, 2012, 02:07 PM
UniDaHero is offline
Find More Posts by UniDaHero
Joined Oct 2007
Can I assume ailerion servos are OK to use, they look like a different brand/size.
Tnx Tim
Yeah from what I've read and experienced, they are ok
Not sure how you reinforced motor mount, have any pictures??
Tim
http://www.rcgroups.com/forums/showp...postcount=1053
UniDaHero is offline Find More Posts by UniDaHero
Old Sep 07, 2012, 02:14 PM
RCAV8T0R is online now
Find More Posts by RCAV8T0R
Feeding the RC Addiction
RCAV8T0R's Avatar
United States, CA, San Diego
Joined Apr 2011
Minor Surgery...
Tim
Use a sharp #11 blade to cut around the perimeter of the servo(s) & then use needle-nose pliers & gently pull & wiggle the servo(s) out. If you take yor time it "should" come out without too much trouble or hardly any collateral damage. Works for me anyway...
RCAV8T0R is online now Find More Posts by RCAV8T0R
Old Sep 07, 2012, 02:30 PM
fishdeth is offline
Find More Posts by fishdeth
Team Broke
fishdeth's Avatar
Orlando/ Winter Garden, FL
Joined Feb 2003
I don't want to glue the receiver hatch on, just in case I want to get in there in the future so I got a bamboo skewer and cut off about a little more than an inch and glued it into the hatch at center top and pushed it rearward on the fuse to spear into the bulkhead.
To keep the front end secure, I used 2 straight pins with the plastic tips.
Then push in at an angle and then bury them just below flush.
They bite into the foam just behind the cabane.
You can get them back out to remove the hatch by using a needle nose.
fishdeth is offline Find More Posts by fishdeth
Old Sep 07, 2012, 06:54 PM
MNadMan is offline
Find More Posts by MNadMan
Add Lightness
MNadMan's Avatar
Joined Dec 2011
Originally Posted by fishdeth View Post
These are WAY too heavy for their function.
Will remake these from light ply and paint yellow.
I will also keep a running total of weight loss and report final weight before batteries.
interesting to see how light it ends up.
my pitts is stock, with pilot, etc. and added stickers, a bunch of gorilla glue on the motor mount & landing gear for reinforcement (not for damage) and with a 4s 1300mah 40c, it floaty floats across the sky in amazement to most everyone. so yours should be amazing. just make sure you use a light weight lipo too.
MNadMan is offline Find More Posts by MNadMan
Old Sep 07, 2012, 07:05 PM
fishdeth is offline
Team Broke
fishdeth's Avatar
Joined Feb 2003
I ran a razor blade along both sides of the front spar on the top wing (the only one I can figure out how to get out) and removed it by getting a screwdriver under one end.
It is about 3/32 wide and about 1/4 tall.
I had that CF tube in the picture and it is a little shorter, but it does go slightly past the interplane strut mounts so it will be fine.
Another easy significant weight loss !
Old Sep 07, 2012, 07:24 PM
fishdeth is offline
Team Broke
fishdeth's Avatar
Joined Feb 2003
Yea, who knows, maybe it will fly good on 3s1p 2200 packs that I have.
I haven't bought the 4 cell packs as of yet.
I can't wait to weigh it when all my mods are done.
I think someone here said stock was 1300 grams without the battery ???
Old Sep 08, 2012, 12:48 AM
queadlunnrau is online now
Find More Posts by queadlunnrau
Luck is my skill
queadlunnrau's Avatar
United States, WA, Seattle
Joined Jun 2009
Mine is 1267g dry with my mods. Heavier 17g servos, pilot removed, added cf rods, capacitor, etc... My 1800mAh 4s 65c lipos I use are a porky 223g so auw 1490g for me.
queadlunnrau is online now Find More Posts by queadlunnrau
Old Sep 08, 2012, 06:50 PM
fishdeth is offline
Team Broke
fishdeth's Avatar
Joined Feb 2003
Found a couple bargains today at the swap meet.Got the CA hinges I needed for a buck.
I split them in half and installed 29 of them and 1 tiny little Robarts pin style hinge on the bottom of the rudder in the little tab that slides into the end of the fuse.
Bought some real strong magnets and glued them in the hatch area.
Got some lite ply 1/16" to make my interplane strut out of.
Also cut 2 pieces and made that ply sammich on the elevator.
Got a new Hitec HS-81 for $5.00, didn't have arms, but I had a HD one.
Got that installed.
More tomorrow I'm sure !
Jim
Old Sep 08, 2012, 10:42 PM
the_walrus is offline
Find More Posts by the_walrus
United States, UT, Saratoga Springs
Joined Mar 2010
Got my red Peaks put together today. Epoxied the motor mount, put loc tite on all metal to metal fasteners, did the skewer mod for the rx hatch, cut a small vent between the faux cylinders for cooling and balanced the prop. Spinner is out of balance so I'll get a new one on there soon. Otherwise it went together nicely and I should be able to maiden in the coming week.
Justin
the_walrus is offline Find More Posts by the_walrus
Old Sep 08, 2012, 11:24 PM
THESANDMAN is offline
Find More Posts by THESANDMAN
THESANDMAN's Avatar
United States, NY, New York
Joined Oct 2010
Justin
good luck with the maiden . its a sweet flying bird .ive got aboout 5 flights on this one and im glad i got another one.
THESANDMAN is offline Find More Posts by THESANDMAN
Old Sep 09, 2012, 09:00 AM
w4yn is offline
Joined Jan 2007
Got that installed.
Jim
Your rear servos must have not been glued as well as mine!
The plastic mounts were glued tight to servos so they came out with the servos.
I need to re-glue them back in before installing my 81's.
Tim
Old Sep 09, 2012, 09:09 AM
fishdeth is offline
Team Broke
fishdeth's Avatar
Joined Feb 2003
Tim
I pulled the rudder servo out with not much resistance.
The plastic pieces were still firmly in the fuse.
The elevator servo was another story.
Grabbed the servo case with a pair of channel locks and really had to twist and pull.
One half of the plastic came with the servo and the other remained in the fuse.
I am only replacing the elevator servo for now.
So I will have a spare china servo for the rudder if it fails.
I am not a hard 3-Der so maybe I will get decent service from the rudder servo ?
Old Sep 09, 2012, 11:08 AM
SLK Count is offline
Find More Posts by SLK Count
Beast 60E Maniac
SLK Count's Avatar
Hamburg, Germany
Joined Feb 2010
hi all...
need flight time with 1800er and 2200er Turnigy lipo pack ? I read the flight performance for aerobatics is much better with 1800er- can you commit this ?
SLK Count is offline Find More Posts by SLK Count
Sold Eflite Pitts Model 12 Arfrm,BNF,PNP Any way navihawk Aircraft - Electric - Airplanes (FS/W) 6 Nov 14, 2011 06:35 PM
Found 4s 2200 mAh lipo for my Pitts Model 12 stwaller12 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Sep 15, 2011 05:54 AM
Build Log Peak Model 50cc Pitts Model 12 Biplane Electric Conversion maverickma Giant Electric Planes 228 Sep 09, 2011 08:23 AM
Sold E-Flite Pitts Model 12 15e Biplane milehigh club Aircraft - Electric - Airplanes (FS/W) 5 May 19, 2011 08:08 PM
Discussion Goldberg ARF Pitts P-12 (model 12) IronKnees Fuel Plane Talk 12 Jan 08, 2007 10:33 AM
