Espritmodel.com Heli Air
Old Mar 01, 2012, 04:28 PM
Fly More Crash Less
AZAerobat's Avatar
United States, AZ, Prescott
Joined Sep 2007
Originally Posted by lkagan View Post
This is off-topic, but does anyone know where I can find a list and description of maneuvers so I can at least sound like I know what I'm doing?
Thanks.
Larry
I learned them from Scott Stoop's book “The Pilot's Guide to Mastering Radio Control Flight” and from Bone Doc's 3D maneuver thread. Here is the link. http://www.rcgroups.com/forums/showthread.php?t=904349 They are both excellent resources if you are learning how to fly 3D. I know the moves but it does not mean I know how the fly all of them, I will get there eventually though.
AZAerobat is offline Find More Posts by AZAerobat
Old Mar 01, 2012, 05:43 PM
Luck is my skill
queadlunnrau's Avatar
On Earth
Joined Jun 2009
Thanks for linking http://www.rcgroups.com/forums/showthread.php?t=904349
This is awesome, saves from many google and youtube searches now.
queadlunnrau is offline Find More Posts by queadlunnrau
Old Mar 01, 2012, 05:51 PM
Fly More Crash Less
AZAerobat's Avatar
Joined Sep 2007
No problem. It is actually at the very top of the 3D Flying Forum. What I did was download all of the videos and keep them on my computer so when I am working on my moves in the sim I can click between the video and the sim.
Old Mar 01, 2012, 06:40 PM
United States, GA, Newnan
Joined Aug 2010
Gee, I admire the ways you guys work at it...seriously...
Most of the time I'm just jamming the sticks this way & that, and trying to watch what happens...and hoping it's good
poiyt is offline Find More Posts by poiyt
Old Mar 01, 2012, 08:05 PM
Help me pick up the pieces
United States, FL, Orlando
Joined Sep 2011
Hey guys as a piece of advice check your motor every flight by giving it a good tug. On my 2nd flight it appears the backplate the motor mount is attached to came loose because of lack of glue and when I throttled up the motor/prop started wobbling violently and ripped off the foam around the mount and plummeted to the ground. So basically I crashed now with no power system. the motor is beat up but might fly and I found most of the ripped off foam and I will try to make repairs and epoxy the whole front end back together. But obviously it won't fly like new. It looks like there was so very little glue on the back of the plate that when it came loose there was no way the foam was gonna hold it in. So please check yours cuz I'd hate for this to happen to any one else.
crockett828 is offline Find More Posts by crockett828
Old Mar 01, 2012, 09:12 PM
FlyWW1's Avatar
United States, VA, Winchester
Joined Nov 2010
Same thing happened to mine on the first flight Once I fixed it I epoxied some strong bass wood all around in front of the motor mount area to strengthen the foam. Hasn't come loose since.
FlyWW1 is offline Find More Posts by FlyWW1
Old Mar 01, 2012, 09:22 PM
FlyWW1's Avatar
Joined Nov 2010
I just tried to take my aileron servos out to upgrade them and it's not happening without ripping a hole in the wing Anybody had any luck changing theirs? I'm screwed if they strip
Old Mar 01, 2012, 11:10 PM
Fly More Crash Less
AZAerobat's Avatar
Joined Sep 2007
What kind of amps and watts is everyone getting stock? I think mine is terribly low. I am getting about 450 watts at 32-33 amps WOT. This seems low to me anyone else? I think I might change my prop before the maiden.
Old Mar 02, 2012, 06:43 AM
FlyWW1's Avatar
Joined Nov 2010
That does seem a little low. With a 20c 4s 2200 it gave me 39 amps and 582 watts.
Old Mar 02, 2012, 12:11 PM
Fly More Crash Less
AZAerobat's Avatar
Joined Sep 2007
That is what I thought. I am going to prop up when I get off work. I am going to slap an APC 14X7 on there and see what I can get out of her.
Old Mar 02, 2012, 01:15 PM
Luck is my skill
On Earth
Joined Jun 2009
Post the results when if you do, I don't have a watt meter, just string and a fishing scale for guessing thrust.
I was wondering about pushing more power as my lipos barely come down warm and the motor isn't hot at all
Old Mar 02, 2012, 01:19 PM
JGuilty13's Avatar
United States, MI, Royal Oak
Joined Nov 2005
I removed my cowl and motor this morning to get to the the plastic "back plate" so that I could remove it and add more epoxy and the darn thing wouldn't budge lol....I felt like I was going to tear the front off the plane!
I probably just weakened it just enough that it will now come loose during its flight. Stupid Darwin.
JGuilty13 is offline Find More Posts by JGuilty13
Old Mar 02, 2012, 02:24 PM
Fly More Crash Less
AZAerobat's Avatar
Joined Sep 2007
Will do. Work is getting in the way though.
Old Mar 02, 2012, 07:42 PM
Fly More Crash Less
AZAerobat's Avatar
Joined Sep 2007
Alright so I put an APC 14X7 on there and I am basically getting similar numbers. I am wondering if my ESC is a dud. My numbers are a tiny bit better but not by much. I am afraid to maiden this thing now. I might have to change the ESC. Anyone else got any ideas?
Old Mar 02, 2012, 07:51 PM
FlyWW1's Avatar
Joined Nov 2010
Have you checked your timing yet? Double check your throttle %. Check your battery. That's all I got sorry Does it feel strong when you throttle up? Maybe your meter is a little messed up or mine is
Has anybody else run the numbers yet?
Sold Eflite Pitts Model 12 Arfrm,BNF,PNP Any way navihawk Aircraft - Electric - Airplanes (FS/W) 6 Nov 14, 2011 06:35 PM
Wanted 4s 2200 mAh lipo for my Pitts Model 12 stwaller12 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Sep 15, 2011 05:54 AM
Build Log Peak Model 50cc Pitts Model 12 Biplane Electric Conversion maverickma Giant Electric Planes 228 Sep 09, 2011 08:23 AM
Sold E-Flite Pitts Model 12 15e Biplane milehigh club Aircraft - Electric - Airplanes (FS/W) 5 May 19, 2011 08:08 PM
Discussion Goldberg ARF Pitts P-12 (model 12) IronKnees Fuel Plane Talk 12 Jan 08, 2007 10:33 AM
