Old Feb 15, 2012, 07:00 PM
lkagan is offline
Find More Posts by lkagan
lkagan's Avatar
United States, FL, Boynton Beach
Joined Aug 2011
I took her out for a few more flights today. I noticed that during inverted flight, I did need to give it some elevator input. I also noticed that when that second cover comes off and is stuck between the fuselage and the upper wing, it will push the nose down slightly. That is what probably lead me to believe that inverted flight took no rudder input.
I was also a bit off on my earlier review when I said it needed 8 to 10 feet of runway to take off. It only needs about four. Also, I was a little more aggressive in flight so setting the timer at seven minutes is probably where you want to be for a 2200 mAh lipo. While I was at the field today, I had my Blade 450 3D helicopter which takes a 2200 mAh lipo 3 cell pack. Since I use the same connectors on both packs, I decided to plug it in and hold the plane to feel the amount of force generated. I'm pretty confident that you can fly this thing on the three cell. I may be brave enough to try that one day, but not today.
I set up my GoPro camera with the head strap and wore it on my head for an entire flight. I just forgot to hit the record button. . Oh well, maybe tomorrow.
The Zap foam safe CA held the vertical stabilizer rod mount on. It had come off from the heat in my car today.
Overall, loving this plane!
lkagan is offline Find More Posts by lkagan
Old Feb 15, 2012, 08:10 PM
queadlunnrau is offline
Find More Posts by queadlunnrau
Luck is my skill
queadlunnrau's Avatar
United States, WA, Seattle
Joined Jun 2009
Use some scotch double sided tape for the second cover. Got that from someone else here and works great for mine. Put the tape on the metal wing struts and press the foam on tight.
Also added my gyro to the ruder, its acting weird, I don't want to fry my servo not knowing the pulse and Hz so I ordered some other faster 17g servos.
Adding thin CA to all my strut mounts thanks to ur advice, don't want any of them coming off.
queadlunnrau is offline Find More Posts by queadlunnrau
Old Feb 15, 2012, 08:29 PM
Stevewil131 is offline
Find More Posts by Stevewil131
Joined Aug 2011
I maidened mine this evening. I can't say enough good things about the three new Dynam planes. They are all great and the best bang for your buck. The Peaks will take off in five feet and climb forever. The roll rate is not quite as fast as the Sbach but still pretty good. It seems that it will hover pretty good for someone with more talent than me. Landings are a breeze with this plane, it really slows down and floats in. Very pleased to say the least.
Stevewil131 is offline Find More Posts by Stevewil131
Old Feb 15, 2012, 08:50 PM
FlyWW1 is offline
Find More Posts by FlyWW1
FlyWW1's Avatar
United States, VA, Winchester
Joined Nov 2010
Would you guys stop posting how great this plane is Mine won't be here until Monday and it's killing me. I'm glad to here it floats well because all I've got is grass to land on.
FlyWW1 is offline Find More Posts by FlyWW1
Old Feb 15, 2012, 09:53 PM
MNadMan is offline
Find More Posts by MNadMan
Add Lightness
MNadMan's Avatar
Joined Dec 2011
Here is where Dynam must of sent all the Pitts 12 Pythons (yellow "Peaks") to: FRANCE
Pitts 12 Python Dynam RC by HLC.SHOP (17 min 17 sec)
http://www.hlcshop.fr/fr/511-new-pit...am-rc-pnp.html
Damn (or rather Dynam) that yellow Pitts 12 looks good!
MNadMan is offline Find More Posts by MNadMan
Old Feb 15, 2012, 10:09 PM
Wingbreaker is offline
Find More Posts by Wingbreaker
Video Juggernaut
Wingbreaker's Avatar
United States, FL, Satellite Beach
Joined Nov 2003
Anyone know where the Y connector for the ailerons is hidden? Before I go buy one id like to know if I missed ti somewhere.
Wingbreaker is offline Find More Posts by Wingbreaker
Old Feb 15, 2012, 11:09 PM
erkq is offline
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
Some have found it on the rudder and elevator leads so they can be reached.
erkq is offline Find More Posts by erkq
Old Feb 16, 2012, 01:14 AM
Video Juggernaut
Joined Nov 2003
Yup that there they be.
Old Feb 16, 2012, 07:18 AM
FlyWW1 is offline
FlyWW1's Avatar
Joined Nov 2010
You can buy the Python here. It would cost us USA people close to $300 though.
http://www.nitrotek.co.uk/pitts-4ch-...ne-2-4ghz.html
Old Feb 16, 2012, 08:10 AM
lkagan is offline
lkagan's Avatar
Joined Aug 2011
Yeah, that was me. I just want something a little more flexible and easier to work with. I found that two pieces doesn't do a great job but a piece on all 4 sides works great. I'm still in the process of installing magnets. I put 4 small washers on the cover. Tonight I'll install the magnets on the fuse.
What's happening?
Old Feb 16, 2012, 08:25 AM
lkagan is offline
lkagan's Avatar
Joined Aug 2011
OK, we won't talk about how it gets everyone's attention at the field, or how it can go from 0 to vertical in 4 feet of runway. Or how it can fly at an amazingly slow speed for low fly-bys, or how beautiful it looks doing a knife-edge past all the pilots, or how it practically lands itself, or how it flies on a wire. We won't talk about any of that.
- Larry
Old Feb 16, 2012, 08:36 AM
FlyWW1 is offline
FlyWW1's Avatar
Joined Nov 2010
- Larry
Nice I can't wait! I'm getting ready to order some more batteries for it. I was wondering what kind of discharge rate you guys have been happy with? Also are the 2200's working out good weight and CG wise ?
Old Feb 16, 2012, 08:46 AM
JGuilty13 is offline
Find More Posts by JGuilty13
JGuilty13's Avatar
United States, MI, Rochester Hills
Joined Nov 2005
Got mine last night and man is this a good looking model!! The quality is wonderful and she seems to have tons of power of the stock motor. Ive attached a few pics of mine so far....shes not 100% built yet, I need to shorten the elevator push rod....anybody else notice that? The prop on this thing is huge (thats what my GF said and the landing gear seems very sturdy.
Assembling the model is very straight forward and I didn't have to use any glue which is awesome. Dynam provides you with an assortment of screws and it can get fairly confusing on exactly which ones are supposed to go where....so I just ended up digging into my secret stash and found what I needed lol.
The dummy radial engine would look great with a metallic paint job in there so that's what Ill do this weekend. One bit of advice to anyone about to build one of these....make sure you put the CF wing struts on properly or else you'll be unscrewing the itty bitty screws and bolts and probably lose one (I did). Ive attached a pic to show how they are supposed to go. One last thing to the guys who have built theirs already...did you need that small black plastic ring when installing the prop? I couldn't get my spinner to sit all the way, so I removed the ring (check pic) and everything fit fine. I am so pumped to fly this thing.
Jordan
JGuilty13 is offline Find More Posts by JGuilty13
lkagan is offline
lkagan's Avatar
Joined Aug 2011
I use these. They're relatively light weight. They come off the plane moderately warm which is just how you want it. I love the exceptionally high charge rate... 5C.
I line up the back-end of the pack (non-wired side) to the edge of the cowling. I marked the underside of the upper wing at 87mm from the leading edge which is between the 85-90mm recommended in the manual. I hold it up by my finger tips and It balances perfectly.
Did I mention it looks awesome just taxiing around the runway?
Larry
Old Feb 16, 2012, 08:51 AM
JGuilty13's Avatar
Joined Nov 2005
A few more...
Sold Eflite Pitts Model 12 Arfrm,BNF,PNP Any way navihawk Aircraft - Electric - Airplanes (FS/W) 6 Nov 14, 2011 06:35 PM
Found 4s 2200 mAh lipo for my Pitts Model 12 stwaller12 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Sep 15, 2011 05:54 AM
Build Log Peak Model 50cc Pitts Model 12 Biplane Electric Conversion maverickma Giant Electric Planes 228 Sep 09, 2011 08:23 AM
Sold E-Flite Pitts Model 12 15e Biplane milehigh club Aircraft - Electric - Airplanes (FS/W) 5 May 19, 2011 08:08 PM
Discussion Goldberg ARF Pitts P-12 (model 12) IronKnees Fuel Plane Talk 12 Jan 08, 2007 10:33 AM
