Old Jan 30, 2013, 07:08 PM
Spookeay is offline
Find More Posts by Spookeay
Always puts it on the numbers.
Spookeay's Avatar
United States, AL, Sylacauga
Joined Jul 2012
Hummmm you guys made me dust off the Pitts today. I've spent the last 2 or 3 months learning to fly Helicopters and had been ignoring my fixed wings.
Had to see if it still worked.
Taking the Pitts after 3 months on the shelf. (6 min 35 sec)
Spookeay is offline Find More Posts by Spookeay
Old Jan 30, 2013, 07:35 PM
Tatonka is offline
Find More Posts by Tatonka
Buffalos have wings
Tatonka's Avatar
Vancouver Washington
Joined Nov 2007
Nice flight in a nice area.....Liked the repaint and noticed you had gone to a three blade prop.....Good to see a lady pilot on here, breaks up the testosterone level.
Tatonka is offline Find More Posts by Tatonka
Old Jan 30, 2013, 08:02 PM
goldsworthy is offline
Find More Posts by goldsworthy
United States, AZ, Tucson
Joined Mar 2012
Originally Posted by d_toolman View Post
I use Turnigy MG-90s 13.4g metal gear servos and they work great. These are the same size as a 9g servo. The extra weight is for the metal gears. Best part is, they only cost $4.99 each from HobbyKing global warehouse or $5.09 from US warehouse. https://www.hobbyking.com/hobbyking/...arehouse_.html
WOW! Weight: 13.4g they are heavy buggers! I would use these-
DS65HB Digital High Speed Servo 6.5g/1.5kg/.07sec
Spec.
Model: Digital DS65HB
Type: Digital
Voltage: 4.8~6v
Speed @ 4.8V: 0.09sec
Speed @ 6V: 0.07sec
Torque @ 4.8V: 1.3kg/cm
Torque @ 6V: 1.5kg/cm
Gear type: Plastic
Weight: 6.5g
Storage temperature: -20~60C
Operating temperature: -10~50C http://www.hobbyking.com/hobbyking/s...dProduct=30706 or even this one- HKSCM12-5 Single Chip Digital Servo (5V)
Spec.
Torque: 1.5kg
Weight: 12g
Speed: 0.18 / 60deg
Voltage: 4.8v
Plug: JR
Features:
Alloy Heat Sink
Ballraced http://www.hobbyking.com/hobbyking/s...dProduct=19678 I bought 30 of each and have yet to find even 1 defect.
goldsworthy is offline Find More Posts by goldsworthy
Reply With Quote  (Disabled)
Old Jan 30, 2013, 08:23 PM
Sammy70 is offline
Find More Posts by Sammy70
JOHN 3:16 STILL APPLIES
Sammy70's Avatar
Central Ohio
Joined Feb 2008
I would use these- DS65HB Digital High Speed Servo 6.5g/1.5kg/.07sec
Those may be nice servos (the DS65HB), but they are way too wimpy for this plane in my opinion.
The super low torque (Torque @ 4.8V: 1.3kg/cm) and plastic gears would not be wise on this Peaks...
Sammy70 is offline Find More Posts by Sammy70
Old Jan 30, 2013, 09:55 PM
w4yn is offline
Find More Posts by w4yn
United States, NC, Charlotte
Joined Jan 2007
Kit availability
Has there ever been a bare bones kit offered IE no decals or electronics?? Tim
w4yn is offline Find More Posts by w4yn
Old Jan 30, 2013, 10:16 PM
d_toolman is offline
Find More Posts by d_toolman
d_toolman's Avatar
Florida,USA
Joined Feb 2011
Yes.. NitroPlanes sells the kit for $99.00. It is the yellow one and it does come with decals but they are not applied. I ordered both the ARF and the Kit at the same time. The ARF I put the Peaks decals on, The Kit I had Callie Graphics make the Pitts Python decals for 28 bucks. The also offer an unpainted ARF but it is 169 bucks.
d_toolman is offline Find More Posts by d_toolman
Old Jan 30, 2013, 10:25 PM
d_toolman's Avatar
Florida,USA
Joined Feb 2011
Spec.
Type: Digital
Voltage: 4.8~6v
Speed @ 6V: 0.07sec
Gear type: Plastic
Weight: 6.5g
Spec.
Torque: 1.5kg
Weight: 12g
Speed: 0.18 / 60deg
Voltage: 4.8v
Plug: JR
Features:
Alloy Heat Sink
The metal gear ones from Hobby King that you say are HEAVY.... It makes no difference between 9 grams and 13 grams on this plane... your are only using 2 of them for the ailerons. They are strong and quick and I have never stripped a gear yet and for 5 bucks you can't beat them. They fit right in the servo cutouts perfectly because they are a 9 gram servo just changed out the gears to metal which is where the extra weight came from. There is no way you could tell a difference in the performance power of the plane using these metal gear servos verses smaller lighter,weaker, plastic gear servos. The difference in weight between the standard 9g servo and these metal gear servos, you are adding 0.01763698 ounces to the plane. I can't even tell the difference in how the plane performs during 3d using 1800mAh battery or using a 2200mAh battery and there is a huge difference in weight between these 2 batteries.
Old Jan 30, 2013, 10:32 PM
Spookeay is offline
Spookeay's Avatar
Joined Jul 2012
Mine was the kit and it was totally white. Unless that has changed, will come with decals.
Old Jan 30, 2013, 10:40 PM
d_toolman's Avatar
Florida,USA
Joined Feb 2011
Did it come from NitroPlanes? The kit from them was yellow when I purchased it and it is yellow right now on their web site. The white unpainted one has always been an ARF on their site. I never could understand why the unpainted one cost more than the red or yellow one. You can use mineral spirits to remove the paint if you let it soak long enough. Someone else was using rubbing alcohol to remove the paint.
Old Jan 30, 2013, 10:44 PM
Spookeay is offline
Spookeay's Avatar
Joined Jul 2012
Yes now that I think about it,,, it was a ARF Not kit.
Old Jan 30, 2013, 10:53 PM
d_toolman's Avatar
Florida,USA
Joined Feb 2011
Liked your paint job on the Pitts. That lake you have, I would have to fly my Dynam PBY off of that. The 3 blade prop and hub, did that come off
of the 1450mm FMS T-28?
Old Jan 30, 2013, 11:01 PM
Spookeay is offline
Spookeay's Avatar
Joined Jul 2012
I do, It's tight but does fine.
Old Jan 31, 2013, 04:04 AM
StarHopper44 is offline
Find More Posts by StarHopper44
Earthbound Skyhound
StarHopper44's Avatar
United States, NC, Richlands
Joined Jun 2011
My yellar'n came in last Friday - haven't had time to put 'er together yet between weather & swap meets & being too busy. *Whew* -- gotta lotta readin' to do here!
StarHopper44 is offline Find More Posts by StarHopper44
Old Jan 31, 2013, 07:31 AM
naryan is offline
Find More Posts by naryan
Rotor Addict
naryan's Avatar
United States, VA, Leesburg
Joined Dec 2008
Originally Posted by RCAV8T0R View Post
Exciting footage there for sure. I'm guessing the pucker factor went through the roof a few times based on some of the full up elevator stuff I saw...
Nah, just goofing around. I normally fly 3d helis where a crash costs $200-$400, the peaks is no stress.
Was that a hat cam you used? Seemed like this footage was taken from the pilot's perspective, not by someone else watching you fly...
Yeah, it's from a little key fob cam velcro'd to the bill of my hat. It's the "808 #11 Cam".
naryan is offline Find More Posts by naryan
Old Jan 31, 2013, 10:20 AM
RCAV8T0R is offline
Find More Posts by RCAV8T0R
Feeding the RC Addiction
RCAV8T0R's Avatar
United States, CA, San Diego
Joined Apr 2011
Exactly...
..since that's what this hobby is all about. It's what we like to call (much needed) "Therapy"......
Hey Mike,
Kinda figured that as some of those "maneuvers" looked very heli-like... Fun to watch those last second reactions about 3 feet off the deck.... Didn't know the Peaks had it in her... Since you like the Peaks should give the Dynam Devil 3D a try when you have a chance. Some of the heli pilots I know can really wring the daylights out of this lil' Bipe as well......
Thanks for posting the cam info, too...
RCAV8T0R is offline Find More Posts by RCAV8T0R
Sold Eflite Pitts Model 12 Arfrm,BNF,PNP Any way navihawk Aircraft - Electric - Airplanes (FS/W) 6 Nov 14, 2011 06:35 PM
Found 4s 2200 mAh lipo for my Pitts Model 12 stwaller12 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Sep 15, 2011 05:54 AM
Build Log Peak Model 50cc Pitts Model 12 Biplane Electric Conversion maverickma Giant Electric Planes 228 Sep 09, 2011 08:23 AM
Sold E-Flite Pitts Model 12 15e Biplane milehigh club Aircraft - Electric - Airplanes (FS/W) 5 May 19, 2011 08:08 PM
Discussion Goldberg ARF Pitts P-12 (model 12) IronKnees Fuel Plane Talk 12 Jan 08, 2007 10:33 AM
