Old Jan 25, 2013, 10:08 AM
kman24 is online now
Find More Posts by kman24
Addicted To Flying Foam
kman24's Avatar
United States, NE, Bennington
Joined Jan 2010
Fyi - Watch those bullet connectors on these ESC's when you build these planes. I have received these planes where the bullets weren't plugged in all the way. They may vibrate loose during shipping and handling which can expose the connectors. This applies to all planes from any vendor.
Kman
kman24 is online now Find More Posts by kman24
Old Jan 25, 2013, 10:13 AM
jonspot25 is offline
Find More Posts by jonspot25
jonspot25's Avatar
Joined Jan 2013
Thanks everyone for your help. lesson learnd. From now on If I do buy a plane from nitro it will only be a kit. Then I can stuff my own juice in it. I bet I end up with a better plane that way :-)
jonspot25 is offline Find More Posts by jonspot25
Old Jan 25, 2013, 11:43 AM
TripleW is online now
Find More Posts by TripleW
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
Here's a pic of the Pitts that had the Battery explode. Parts of the battery were 10-15 feet away. It sounded more like a loud Pop!!
TripleW is online now Find More Posts by TripleW
Old Jan 25, 2013, 12:16 PM
Dave Bee is offline
Find More Posts by Dave Bee
Dont be a gashole fly electric
Dave Bee's Avatar
Chaplin,Ct.
Joined Nov 2005
I replaced the speed control with a 60 amp from BP hobbies and added a castle BEC. The plane is excellent now, before the exchange the servos chattered and sometimes didnt even move when ask. Original motor and no more problems.
Dave Bee is offline Find More Posts by Dave Bee
Old Jan 25, 2013, 01:56 PM
d_toolman is offline
Find More Posts by d_toolman
d_toolman's Avatar
Florida,USA
Joined Feb 2011
That is repairable. Use some light weight Spackle compound and Zinssers BIN alcohol based primer and acrylic paint and you will never know it was damaged.
d_toolman is offline Find More Posts by d_toolman
Old Jan 25, 2013, 07:00 PM
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
Yup, I got it from a guy who didn't want to bother with it. He hit a tree also.
I'm gonna try one of these in it.
http://www.hobbyking.com/hobbyking/s...tor_800w_.html
Old Jan 25, 2013, 07:07 PM
d_toolman's Avatar
Florida,USA
Joined Feb 2011
I haven't run my watt meter on the stock motor but the one you picked out should do the trick. Let us know. You may have to us a larger battery because it looks like it draws a few more amps than the stock motor.
Old Jan 25, 2013, 11:16 PM
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
d t, Do you use the aerosol or the pint?
http://www.amazon.com/Zinsser-Primer...rds=bin+primer
Old Jan 26, 2013, 09:37 AM
mjdee14 is offline
Find More Posts by mjdee14
mjdee14's Avatar
Nashville TN, USA
Joined Jun 2004
Does anyone here fly out of Mobile AL? I may need to be there on a project for a few months and would love to be able to fly. I'm driving down from Nashville so should be able to fit a few planes in the car...(may have to leave clothes home) but I have priorities
I think I'll be working at the older downtown airport....Brookley aeroplex
Let me know if you allow visitors.....I am an AMA memeber.
Mike D
mjdee14 is offline Find More Posts by mjdee14
Old Jan 26, 2013, 09:47 AM
d_toolman's Avatar
Florida,USA
Joined Feb 2011
I use the brush on kind. http://www.amazon.com/Zinsser-Primer...rds=bin+primer I usually have a gallon or quart laying around in the shop. A lot of aerosol propellents melt foam so I do not use paint in aerosol cans unless it is Testors enamel like Model Master. When priming with Zinssers, I brush a couple of thin coats on and let it dry for an hour or two.... then I wet sand with 400 grit wet/dry sand paper to remove the brush strokes. Then I either use acrylic paint or Testors enamel paints and apply the paint with my airbrush.
Old Jan 26, 2013, 11:51 AM
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
I've used latex primer before. but it doesn't cover like I had hoped.
Thanks, Walter
Old Jan 26, 2013, 12:00 PM
d_toolman's Avatar
Florida,USA
Joined Feb 2011
Thanks, Walter
Latex primer is not good to use, it doesn't stick to foam. That is why I use Zinssers, it sticks to anything and anything sticks to it. The only Zinssers that works is the shellac based primer.
Old Jan 26, 2013, 02:19 PM
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
I painted my Dynam PBY with Latex. Sticking just fine.
Anyone put a wattmeter on the Pitts? I'm wondering if a 45 amp esc will work.
Old Jan 26, 2013, 05:46 PM
d_toolman's Avatar
Florida,USA
Joined Feb 2011
It was already painted before you applied the latex, wasn't it.
Old Jan 26, 2013, 05:50 PM
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
Good point, Yes it was.
W
Sold Eflite Pitts Model 12 Arfrm,BNF,PNP Any way navihawk Aircraft - Electric - Airplanes (FS/W) 6 Nov 14, 2011 06:35 PM
Found 4s 2200 mAh lipo for my Pitts Model 12 stwaller12 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Sep 15, 2011 05:54 AM
Build Log Peak Model 50cc Pitts Model 12 Biplane Electric Conversion maverickma Giant Electric Planes 228 Sep 09, 2011 08:23 AM
Sold E-Flite Pitts Model 12 15e Biplane milehigh club Aircraft - Electric - Airplanes (FS/W) 5 May 19, 2011 08:08 PM
Discussion Goldberg ARF Pitts P-12 (model 12) IronKnees Fuel Plane Talk 12 Jan 08, 2007 10:33 AM
