Old Oct 29, 2012, 10:07 PM
TheMagician007 is offline
Find More Posts by TheMagician007
TheMagician007's Avatar
United States, CA, Carlsbad
Joined Apr 2012
How are you getting to the screws?
TheMagician007 is offline Find More Posts by TheMagician007
Old Oct 30, 2012, 12:08 AM
Tango_Romeo is offline
Find More Posts by Tango_Romeo
Tango_Romeo's Avatar
United States, TN, Nashville
Joined Mar 2012
Yep...
Originally Posted by mjdee14 View Post
Is that You Mr "T"?
...'tis I.
Tango_Romeo is offline Find More Posts by Tango_Romeo
Old Oct 30, 2012, 08:06 AM
mjdee14 is offline
Find More Posts by mjdee14
mjdee14's Avatar
Nashville TN, USA
Joined Jun 2004
You remove the motor and check the back 4 screws holding the X bracket.
mjdee14 is offline Find More Posts by mjdee14
Old Oct 30, 2012, 09:32 AM
dth7 is offline
Find More Posts by dth7
Back in the hobby- ALL in!
dth7's Avatar
United States, NH, Greenland
Joined Feb 2012
+1. I forgot to mention that too. I guess there were more mods than I thought! Just check the attachment list on the the thread and go from nose to tail. Shouldn't take more than 2 hours. Have fun with it, it is one of the if not the best foamie I've flown for all around flying for less than $200! Still can't believe it.
dth7 is offline Find More Posts by dth7
Old Oct 30, 2012, 09:33 AM
dth7 is offline
dth7's Avatar
Joined Feb 2012
Lock tight all metal to metal screws!
Old Oct 30, 2012, 04:05 PM
mjdee14 is offline
mjdee14's Avatar
Nashville TN, USA
Joined Jun 2004
Right on....learned that from Helis....I even loctighted all the cabane strut screws....PITA when you have to take it apart a few times....
Old Oct 30, 2012, 10:59 PM
Joined Apr 2012
The motor seems pretty hard to get to from the front...what am I missing? Have others been able to get to it??
Old Oct 30, 2012, 11:00 PM
the_walrus is offline
Find More Posts by the_walrus
United States, UT, Saratoga Springs
Joined Mar 2010
The cowl is magnetic with guides top and bottom. Just work it back and forth and it will come off.
the_walrus is offline Find More Posts by the_walrus
Old Oct 30, 2012, 11:19 PM
Joined Apr 2012
Ohh cool!! Thanks I had no idea it was magnetic....new the battery hatch was (obviously), but not the cowl.
Old Oct 31, 2012, 06:45 PM
dth7 is offline
dth7's Avatar
Joined Feb 2012
Found another tweak that I may have missed earlier. Falls under licktighting everything. The axles! They are Phillips screws from inboard with nuts inside the pants. They go through the wheel and thread into the outboard pant. Couldn't understand why I was nosing over landings til I checked to find one wheel binding. Landing with the "brakes" on will certainly nose it over! Tightened both and put some Welders on the screw head to prevent it from backing out again. Still very happy with it. It's stable enough in wind to even practice some IMAC!
Old Nov 01, 2012, 07:06 PM
fishdeth is offline
Find More Posts by fishdeth
Team Broke
fishdeth's Avatar
Orlando/ Winter Garden, FL
Joined Feb 2003
Haven't had the time to get out and fly mine much, work is REALLY slammed !
Was much better last time with the battery moved back some.
Gonna try it a little farther aft and see how close to neutral inverted I can get.
Jim
fishdeth is offline Find More Posts by fishdeth
Old Nov 02, 2012, 05:35 PM
jdm2ner is online now
Find More Posts by jdm2ner
flying is everything
jdm2ner's Avatar
United States, FL, Hollywood
Joined Oct 2010
well i bought mine today hopefully it gets here soon
jdm2ner is online now Find More Posts by jdm2ner
Old Nov 05, 2012, 01:17 PM
UniDaHero is offline
Find More Posts by UniDaHero
Joined Oct 2007
Originally Posted by 1111Mavrick View Post
On a comic side note, has anyone ever used this method before?
(Question) How do you know what motor to use?
How I decided on that motor,I took the KV rating multiplied it by the number of Lipo cells, divided by milliamps then took the prop size cut one blade off,measured the diameter and got the square root of the length of the field I'm flying at,glued the blade back on and divided it by pie R squared,got that Number and took a dump on it then used a temperature probe in the feces and if it was over 98 I went with a lower KV motor....
OMG This had me ROTFLMAO!!!! I am still freaking laughing as I type this! Too Funny!!
UniDaHero is offline Find More Posts by UniDaHero
Old Nov 05, 2012, 01:19 PM
Joined Oct 2007
...Note- take an hour or two to do the recommended mods (see attachments to thread for the pics)...
I have been using forums for years and NEVER knew about this!! Awesome. Thx
Old Nov 05, 2012, 02:27 PM
Joined Mar 2010
Tried the APC 14x7 prop on Sat. It's a nice improvement and pulls 44 amps per a previous post that I found on this thread.
The difference wasn't super huge but definately noticeable. A little more punch, more speed, better vertical and no issues at all with the stock ESC. Yep, the trusty Peaks just got a little more fun if you can believe that.
Justin
Sold Eflite Pitts Model 12 Arfrm,BNF,PNP Any way navihawk Aircraft - Electric - Airplanes (FS/W) 6 Nov 14, 2011 06:35 PM
Found 4s 2200 mAh lipo for my Pitts Model 12 stwaller12 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Sep 15, 2011 05:54 AM
Build Log Peak Model 50cc Pitts Model 12 Biplane Electric Conversion maverickma Giant Electric Planes 228 Sep 09, 2011 08:23 AM
Sold E-Flite Pitts Model 12 15e Biplane milehigh club Aircraft - Electric - Airplanes (FS/W) 5 May 19, 2011 08:08 PM
Discussion Goldberg ARF Pitts P-12 (model 12) IronKnees Fuel Plane Talk 12 Jan 08, 2007 10:33 AM
