Old Oct 03, 2012, 03:25 PM
fishdeth is offline
Find More Posts by fishdeth
Team Broke
fishdeth's Avatar
Orlando/ Winter Garden, FL
Joined Feb 2003
Originally Posted by w4yn View Post
What brand/size and rating did you order?
need a few for mine. Does the CG come out close with these packs?
Tim
http://www.hobbyking.com/hobbyking/s..._4S1P_45C.html
I just finished soldering the Deans plugs on and powered up the plane... HOLY CRAP... the power is ballistic.
TONS more ooomph than the 3 cell !
Now cycling them and hoping for some decent weather.
Still have to add the velcro battery strap in the battery bay and balance the plane.
Jim
fishdeth is offline Find More Posts by fishdeth
Old Oct 03, 2012, 03:37 PM
dth7 is offline
Find More Posts by dth7
Back in the hobby- ALL in!
dth7's Avatar
United States, NH, Greenland
Joined Feb 2012
Jim
I told you not to go with a 3S! Don't be too worried about CG, it's very forgiving. Book cg is good starting point. Have fun. How many cycles do u do for break in? I haven't been doing any and they seem to do fine. Only had 2 500 mAh 2 cells sky lipos go to crap for my twisted hobby Epp edge. I dropped a nice 3 s yesterday and for grins I smoked (safely outside!) the remaining 6v (1 cell shorted out). I have a new respect for discharging dead batts. Pretty good fire ball!
dth7 is offline Find More Posts by dth7
Old Oct 03, 2012, 03:44 PM
fishdeth is offline
Team Broke
fishdeth's Avatar
Joined Feb 2003
I will probably cycle twice each just for the heck of it.
Never really done it before either.
I usually just go easy on them for the first few cycles in the plane.
Old Oct 03, 2012, 03:58 PM
UniDaHero is offline
Find More Posts by UniDaHero
Joined Oct 2007
Jim
I went with the Turnigys because the wire is more flexible and I have problems with the Zippies after a while with the wires coming disconnected from the battery. The flex in the Turnigy wire helps with this. A little more in cost but worth it IMHO.
UniDaHero is offline Find More Posts by UniDaHero
Old Oct 03, 2012, 05:59 PM
krexken is offline
Find More Posts by krexken
smoke is my wattmeter
Longview, Tx
Joined May 2008
I had never heard of breaking a battery in until not too long ago. I really tortured a batch of Gens Ace 3s 2200 and 2600s in my amp sucking CZ Yak. Most of them still work good but I think it shortened the life considerably on some. Now I take it easy a few cycles also.
krexken is offline Find More Posts by krexken
Old Oct 03, 2012, 11:57 PM
mjdee14 is offline
Find More Posts by mjdee14
mjdee14's Avatar
Nashville TN, USA
Joined Jun 2004
Not only is it a good idea to cycle a few times...you shouldn't leave them fully charged for a long period of time.....I learned that the hard way and have 5 lipos.....3 x 2200 4s and 2 x 1600 3 s that don't give good power any more after only 10 months....nver been puffed or abused.....but I kept them fully charged and didn't use them for a while......from now on I'm charging the night before flying.....just ordered 2 more 2200 skylipos....we'll see if these last longer.
mjdee14 is offline Find More Posts by mjdee14
Old Oct 05, 2012, 09:32 PM
fishdeth is offline
Team Broke
fishdeth's Avatar
Joined Feb 2003
Maiden flight will be either Sat afternoon or Sun AM!
Old Oct 06, 2012, 10:54 AM
w4yn is offline
Find More Posts by w4yn
United States, NC, Charlotte
Joined Jan 2007
Maidened Today , went straight up after lifting off and stalled while trying to recover. I believe I gave it too much throttle on take off, had been flying T-28 and Albetros which are different planes altogether.
Both wings cracked but fixable I need to try slower lift off! Flew UM Beast later with out problems except a miss calculated turn around a tree, no damage just a slight unexpected landing!
I was using a 2200 Ma 3C pack in the short time it was in air, several wild moments, it seemed tail heavy but all happened too soon to have real feel for that.
Tim
w4yn is offline Find More Posts by w4yn
Old Oct 06, 2012, 12:25 PM
krexken is offline
Longview, Tx
Joined May 2008
Bummer. Does sound like it may have been tailheavy with that 3s battery. Get her glued up and make sure it balances.
Old Oct 06, 2012, 04:13 PM
fishdeth is offline
Team Broke
fishdeth's Avatar
Joined Feb 2003
Got a new prop collet made by Hacker today and a new 1 3/4" yellow spinner.
Blast-off in the AM !
Jim
Old Oct 06, 2012, 07:11 PM
Sammy70 is offline
Find More Posts by Sammy70
PSALM 14:1
Sammy70's Avatar
Central Ohio
Joined Feb 2008
Jim
Best of luck Jim! I envy you as mine is still in the box!
Sammy70 is offline Find More Posts by Sammy70
Old Oct 06, 2012, 07:13 PM
w4yn is offline
Joined Jan 2007
Are you all balancing by the "book" IE Dynams recommended CG?
Also 4 cell or 3?
Tim
Old Oct 06, 2012, 09:11 PM
RCAV8T0R is offline
Find More Posts by RCAV8T0R
Feeding the RC Addiction
RCAV8T0R's Avatar
United States, CA, San Diego
Joined Apr 2011
Gotta Go Bigger...
Tim
...with your batteries. Not enough prop speed with 3S to keep her flying properly. Nowhere in the manual does it say this ship can be flown on 3S. At the same time it also doesn't say you can't use 3S packs but (usually) the specs are the best starting point. This was also confirmed with the Peaks 42 flight review done by NP.
Big Bird (read heavy) needs more power & rpm's provided by the 4S packs. She'll lift off nicely with just a little over 1/2 throttle. Been flying 4S 2200 25C - 30C packs with excellent results & she has the proper power to get out of (& in) trouble.
It's plenty nose heavy (stable) at the factory mark & it's the best place to start. With the (4S) 2200 packs the front edge of the battery is about even or inline with the back edge of the front foam bulkhead with the hatch off.
For my Dynam Bipe, the CG is behind factory spec since I've been moving mine back to get more of a neutral flight attitude when inverted so I can lay off the elevator to keep her level.
Get a 4S 2200 pack before you try flying her again. You'll have much more potential for a successful flight by doing so...
RCAV8T0R is offline Find More Posts by RCAV8T0R
Old Oct 06, 2012, 09:50 PM
w4yn is offline
Joined Jan 2007
Thanks for info, I thought 3s was OK, seems at one time 3c was listed as being needed to complete on website, I ordered 3c's with plane. Could have read it wrong on requirements though, I did not double check with manual just assumed 3c was right size.
I do have some 4C in mail for the big Waco so will be sure and use them on next try.
Tim
Old Oct 06, 2012, 10:02 PM
THESANDMAN is offline
Find More Posts by THESANDMAN
THESANDMAN's Avatar
United States, NY, New York
Joined Oct 2010
Tim
the motor is rated for 4cell with that prop,sounds like you didnt have enough power on the 3 cell espicially a 2200 mine is stock and run it a recomended size 4 cell , the plane goes straight up in less than 2 feet ,
THESANDMAN is offline Find More Posts by THESANDMAN
Sold Eflite Pitts Model 12 Arfrm,BNF,PNP Any way navihawk Aircraft - Electric - Airplanes (FS/W) 6 Nov 14, 2011 06:35 PM
Found 4s 2200 mAh lipo for my Pitts Model 12 stwaller12 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Sep 15, 2011 05:54 AM
Build Log Peak Model 50cc Pitts Model 12 Biplane Electric Conversion maverickma Giant Electric Planes 228 Sep 09, 2011 08:23 AM
Sold E-Flite Pitts Model 12 15e Biplane milehigh club Aircraft - Electric - Airplanes (FS/W) 5 May 19, 2011 08:08 PM
Discussion Goldberg ARF Pitts P-12 (model 12) IronKnees Fuel Plane Talk 12 Jan 08, 2007 10:33 AM
