Old Oct 01, 2012, 08:09 PM
dth7 is offline
Find More Posts by dth7
Back in the hobby- ALL in!
dth7's Avatar
United States, NH, Greenland
Joined Feb 2012
Originally Posted by fishdeth View Post
Still waiting for my batteries to arrive.
Tinted the canopy and glued it back on this evening.
Silly question (just curious since I'm too lazy to a actually do it). What do you use to tint the canopy and what glue do you use to put it back on with. Looks nice!
dth7 is offline Find More Posts by dth7
Old Oct 01, 2012, 08:20 PM
dth7 is offline
dth7's Avatar
Joined Feb 2012
That will be my last tweak.
Looks GREAT !
I'd say it would be awful to have done all that and then not like flying it but that won't happen. It's hard not to like it. Enjoy it.
Old Oct 01, 2012, 08:28 PM
fishdeth is offline
Find More Posts by fishdeth
Team Broke
fishdeth's Avatar
Orlando/ Winter Garden, FL
Joined Feb 2003
I just fogged it from a good distance with some Krylon black paint.
Masked off the yellow painted areas first and glued it back on with a thin film of the kit glue.
Oh.... I'm going CRAZY !
I have always been a HUGE fan of Biplanes and I am rally chompin at the bit !
Flew my little micro Beast the other night for a fix, but I know this one will be MUCH better !
fishdeth is offline Find More Posts by fishdeth
Old Oct 01, 2012, 08:42 PM
fishdeth is offline
Team Broke
fishdeth's Avatar
Joined Feb 2003
This was one of my favorites.
I created this from 2 Fliton "Jumping Jack" planes.
May she rest in pieces...
Jumpin' Jim Bipe (7 min 39 sec)
Old Oct 02, 2012, 06:16 AM
dth7 is offline
dth7's Avatar
Joined Feb 2012
V nice! Was that you flying? At beginning sounded like someone else was flying it for first time. Also was that one flight? 7+mins or a compilation? Lastly, what happened to it? Looked like a real keeper!
I just retread the first frame re: pilot! I was thinking that that pilot knows what a pop top is! I was waiting for one, he did just about everything else.
Old Oct 02, 2012, 09:09 AM
fishdeth is offline
Team Broke
fishdeth's Avatar
Joined Feb 2003
SSheesh... I WISH that was me flying !
He was at the time a Futaba sponsored pilot.
That original video was over 8 minutes.
I planted her one afternoon when an elevator servo failed... gravity sucks.
A lot of my friends at that time believe that my design was copied and marketed by Fliton.
They shortly after came out with their "Rogue" biplane which was strangely similar....?
Old Oct 02, 2012, 11:10 PM
TheMagician007 is offline
Find More Posts by TheMagician007
TheMagician007's Avatar
United States, CA, Carlsbad
Joined Apr 2012
Need help..what am I doing wrong....right when I throttle up, in the very beginning, the engine only semi engages...I keep throttling up and absolutely no problem. It happened a time while flying too. I only have 5 flights on the plane...
TheMagician007 is offline Find More Posts by TheMagician007
Old Oct 02, 2012, 11:21 PM
Jboy90277 is offline
Find More Posts by Jboy90277
United States, CA, Palos Verdes Peninsula
Joined Dec 2011
Try calibrating your throttle. Have the transmitter on and at full throttle. Connect your battery to your plane, and after a couple of beeps, lower the throttle to zero. You should get the regular startup tones after that, and your throttle will be calibrated.
Jboy90277 is offline Find More Posts by Jboy90277
Old Oct 02, 2012, 11:55 PM
Joined Apr 2012
Wow! Thanks Jboy I'll give that a try. Thanks for the quick reply
Old Oct 03, 2012, 12:51 AM
1111Mavrick is online now
Find More Posts by 1111Mavrick
1111Mavrick's Avatar
Canada, BC, Gibsons
Joined Apr 2011
Sounds like it could be the ESC timing.....
1111Mavrick is online now Find More Posts by 1111Mavrick
Old Oct 03, 2012, 08:37 AM
jl449 is offline
Find More Posts by jl449
Salinas, CA
Joined Dec 2007
Had similar issue on an other plane and it was due to not doing a throttle cali. As a matter of fact it was Dynam ESC.
jl449 is offline Find More Posts by jl449
Old Oct 03, 2012, 10:23 AM
fishdeth is offline
Team Broke
fishdeth's Avatar
Joined Feb 2003
Battery packs are HERE !!!
After work, I gotta solder Deans plugs on and then cycle a coupe times.
Old Oct 03, 2012, 10:30 AM
the_walrus is offline
Find More Posts by the_walrus
United States, UT, Saratoga Springs
Joined Mar 2010
Are you sure you don't feel a cold coming on? **cough cough** may need to leave work early.
the_walrus is offline Find More Posts by the_walrus
Old Oct 03, 2012, 11:30 AM
fishdeth is offline
Team Broke
fishdeth's Avatar
Joined Feb 2003
Yea... especially since I work at home.
We run an upholstery business from our garage.
TOO busy to play hooky tho, gotta make that airplane money !
Old Oct 03, 2012, 12:22 PM
w4yn is online now
Find More Posts by w4yn
United States, NC, Charlotte
Joined Jan 2007
What brand/size and rating did you order?
need a few for mine. Does the CG come out close with these packs?
Tim
w4yn is online now Find More Posts by w4yn
Sold Eflite Pitts Model 12 Arfrm,BNF,PNP Any way navihawk Aircraft - Electric - Airplanes (FS/W) 6 Nov 14, 2011 06:35 PM
Found 4s 2200 mAh lipo for my Pitts Model 12 stwaller12 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Sep 15, 2011 05:54 AM
Build Log Peak Model 50cc Pitts Model 12 Biplane Electric Conversion maverickma Giant Electric Planes 228 Sep 09, 2011 08:23 AM
Sold E-Flite Pitts Model 12 15e Biplane milehigh club Aircraft - Electric - Airplanes (FS/W) 5 May 19, 2011 08:08 PM
Discussion Goldberg ARF Pitts P-12 (model 12) IronKnees Fuel Plane Talk 12 Jan 08, 2007 10:33 AM
