Old Dec 04, 2011, 06:09 PM
Jim_Marconnet is offline
Find More Posts by Jim_Marconnet
Fly long and land softly
Jim_Marconnet's Avatar
Madison, Alabama USA
Joined Oct 2005
Thanks guys for your help and advice. I found the buddy codes on the two items I ordered today. I pasted them into one of the buddy codes sites. Now I wait!
Jim
Jim_Marconnet is offline Find More Posts by Jim_Marconnet
Old Dec 04, 2011, 06:29 PM
turboparker is online now
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
Originally Posted by jl449 View Post
I think I'm going to buy the G-force 2s and then buy the Eflite battery connector from rc-connectors . What I was planning to do is to cut the blance tap connector from the battery and use the center wire to connect to the beast connector. Then cut the jst connector and use the red and black wire and connect it to the beast connector. I think that would work. That would save a few bucks.
Seems like that would be more trouble than simply making your own 2s packs from bare cells.
Joel
turboparker is online now Find More Posts by turboparker
Old Dec 06, 2011, 10:33 PM
Joined Oct 2005
In another thread, I was suggested: http://www.rc-connectors.com/index.p...index&cPath=80
I like very much the way they make it easy to find what you want based on what plane or helicopter you have.
They seem to have about any connector or cable I can think of. But the prices for a connector or cable are not that much lower than the packs I ordered from HobbyKing. So I can use those packs for at least a little while after I get them before I scavenge their connectors, if necessary!
Jim
Old Dec 09, 2011, 03:08 PM
tjm5837 is offline
Find More Posts by tjm5837
tjm5837's Avatar
Joined Jul 2009
I would buy the G Force from value hobby and solder a jst connector onto the Beast. Problem solved! This way you have an appropriate balance connector already on your battery, so you can use a 3rd party charger.
tjm5837 is offline Find More Posts by tjm5837
Old Dec 09, 2011, 03:29 PM
Joined Jul 2009
That G-force 180 mAh pack is pig-heavy as compared to a home-brew Hyp 240 mAh 2s pack, and the advertized C-rating is too low. All cheap Chinese cells to-date have dramatically inflated C-ratings. The G-force pack will not provide anywhere near the power or longevity of the Hyperions. As is true for nearly everything in life - if it's cheap, there's a reason - and if the deal seems to good to be true, it nearly always is too good to be true. With LiPos, there is no free lunch. If they're cheap, it always means that they will not perform as advertised, and that they will have a short lifespan.
Using cheap Chinese packs in these high-performance, high-current applications is anologous to buying a Ferrari & then putting low-octane fuel in it.
Joel
Old Dec 09, 2011, 05:31 PM
tjm5837 is offline
tjm5837's Avatar
Joined Jul 2009
I use G-force batteries extensively in my fleet. They perform very well. They have also held up well. They provide plenty of power. I even use them in my carbon-z yak and they do fine even in mild 3d. For the price, I haven't found a better deal out there. They work fine in my helicopters too. I've held off getting any of these UMX birds just because I refuse to play battery/connector games with E-flite. Now that the g-force batteries are out I think they are worth a try. And your only out 3.50/battery! Just my 2 cents. No offense to anyone.
Old Dec 19, 2011, 06:44 PM
flying-llama is offline
Find More Posts by flying-llama
Sopwith Camel's Cousin
Between my tx and crashed aircraft
Joined Mar 2006
Hyperion gets into the UMX 2s battery arena
Just found out that Hyperion is now making 2s packs with the UMX connector (180mAh, 240mAh).
So far, I see them on sale at
aircraft-world.com (Japan):
http://aircraft-world.com/shopdispla...Ah+and+Smaller
HP-LG325-0180-2S-UMX US$9.95
HP-LG325-0240-2S-UMX US$9.95
and
www.hyperionaustralia.com.au
http://www.hyperionaustralia.com.au/?stg=878&sw=10
Either pack at (AU)$11.90
flying-llama is offline Find More Posts by flying-llama
Old Dec 19, 2011, 07:14 PM
racie34 is offline
Find More Posts by racie34
road wart
racie34's Avatar
United States, IN, Terre Haute
Joined Aug 2003
I agree...good batteries from them and they get here quick...I use a bunch of them on various planes
racie34 is offline Find More Posts by racie34
Old Jan 27, 2012, 10:45 AM
Elisecat is offline
Find More Posts by Elisecat
"Add Lightness"..Colin Chapman
Keystone State, USA
Joined Jun 2007
I ordered a few of the new Hyperion UMX packs from All-E-RC the other day and received them yesterday.
I proceeded to strip off the outer layer of packaging on the 2S 180mAh.
It added up to 1.4gm. That leaves the weight of the 2s Pack at 12.2gm.
Still not quite as svelt at RCBabbels or maybe your own home brew pack but this is good enuf for me.
I will try to take pics and post here later for reference for everyone. The
cells and wires, etc are very secure once the outer packaging is removed.
Dare I say they look as good as RCBabbels cells (which I do own BTW).
I couldn't find a better thread to post this. IF there is someone please direct me. Thanks
Elisecat is offline Find More Posts by Elisecat
Old Jan 27, 2012, 10:05 PM
fryfrog is offline
Find More Posts by fryfrog
United States, CA, Mountain View
Joined Sep 2010
FWIW, the Beast and mCP X connectors (3 and 2 pin, respectively) are just standard electrical connectors. I ordered a bunch from digikey for a few cents each. For the life of me though, I can't find the connectors in my pile of junk.
I'd intended to make a parallel charging cable... but hobbyking released a ~$1 for the 1s batteries and someone else has one for the 2s batteries for an overpriced ~$10. I should have made it myself, but I'm lazy.
I think I also posted the details of the connectors on here, so if you search for posts by me you might find it.
Found em:
1S charge socket: 455-1704-ND (MFG P/N B2B-PH-K-S(LF)(SN)
2S charge socket: 455-1705-ND (MFG P/N B3B-PH-K-S(LF)(SN)
I bet with that you can find the battery connector if you wanted.
fryfrog is offline Find More Posts by fryfrog
Old Jan 28, 2012, 05:35 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Best deal?
Well that really depends now does it not? I like high quality at great price so for me I build my own 2S UMX LiPolys using Hyperion cells from 120 to 240 mAh all of which cost $3.95 ea. from rcdude.com , allerc.com and several other sources.
I use slightly modified Thunder Power 2 or 3S balancing pigtails which can be obtained from Hobby King for $1.95 per pack of 5 which makes them $0.40 each. This means I have aprox. $8.50 plus a little of my time in each one.
Hobby King
PRODUCT ID: 101b-102a-2s
Female JST-XH <-> Male Thunderpower 2S 5cm (5pcs/bag)
All one has to do is trim the non used (empty) socket off and the width will match the E flite female connector.
Charles
Alert Best deals(FREE) is going on at Nitroplanes, Nitrorcx, Xheli, and Hobbypartz RaidenAlbert Hot Online Deals 9 Nov 27, 2011 11:17 PM
Alert Black Friday deals on Lipos???? stockman20 Batteries and Chargers 1 Nov 23, 2011 05:17 AM
For Sale The BOMB for 4G6! 3 New 2S Hyperion 25C 2Cell lipos for 4G6 4G3 4#6 & others blueindian Aircraft - Electric - Batteries & Chargers (FS/W) 0 May 10, 2011 06:30 PM
Help! Best Lipos for Parzone Planes? hcsk8ter Batteries and Chargers 3 May 01, 2011 08:33 AM
