Old Nov 28, 2011, 08:09 AM
Adventurer21 is offline
Find More Posts by Adventurer21
South Africa, GP, Midrand
Joined Mar 2011
KDS 450Q Questions
Hi All,
There doesn't seem to be a official 450Q thread yet.
I'm seriously looking at this bird and have some questions
1. Where's the one-way (auto) bearing? On the motor?
2. I want to go FBL. Which FBL head will fit?
craig
Adventurer21 is offline Find More Posts by Adventurer21
Old Nov 29, 2011, 06:44 AM
loneman is offline
Find More Posts by loneman
Joined May 2009
craig,
The bearing is inside the main gear mouont. If you want to upgrade the rotor head to FBL version, you can try their 450SD FBL. They are compatible.
loneman is offline Find More Posts by loneman
Old Nov 29, 2011, 06:48 AM
loneman is offline
Joined May 2009
I checked for several times on their website, but i have not found out some pictures of 450 heli FBL head. But the news shall be true. One of their pilots updates the rotor head.
Old Nov 29, 2011, 09:51 PM
legendaryflight is offline
Find More Posts by legendaryflight
Joined Nov 2011
Originally Posted by Adventurer21 View Post
Hi All,
craig
Hi,i just serached some detail of KDS.
The one-way bearing is on the Motor gear, you can check. Not on Motor or main gear, it's different with other type.
The FBL, i knew they have Ebar now, and the FBL head seems start producing now also. Let's looking forward to it
legendaryflight is offline Find More Posts by legendaryflight
Old Dec 01, 2011, 12:58 AM
virgule is offline
Find More Posts by virgule
Joined Nov 2011
Re:Adventurer21
Hi All,
Hi friend,
http://www.modelsandall.co.za/ may be helpful for you!
virgule is offline Find More Posts by virgule
Old Dec 02, 2011, 01:21 AM
KDS_Nicki is offline
Find More Posts by KDS_Nicki
Joined Dec 2011
Yes,Adventurer. The Q's one-way bearing is on the Motor gear, check~
About FBL,yes, it will Going public soon, approximately you can see in market next month. Well, or if your near shop fast order, i suppose you can get it before Xmas.
KDS_Nicki is offline Find More Posts by KDS_Nicki
Old Dec 02, 2011, 02:02 AM
Joined Mar 2011
I'm finding MyRCMart a bit slow right-now, so I went with a Chaos 450.
I'll get the KDS450Q later, once there's a FBL head for it. I really like the complete belt-drive.
I'm finding the KDS 450 line-up quite confusing at the moment. There seem to be several flavors of 450 Innova, the 450S and 450SV, the 450Q(belt), 450QS(belt tail).
Old Dec 02, 2011, 02:51 AM
Joined Mar 2011
Looking at the pictures posted by Nicki, I see that there are only two upper swash ball links are in use. Those links are both the swash driver and control links via a set of mixing arms. Looks to me like there will be significant torsional loads placed on both the link-arm bearings and the arm-pivot bearings. I wonder about the durability of this set-up.
Old Dec 04, 2011, 09:21 PM
Joined Dec 2011
Adventurer, Don't worry, it's already been deep tested.
There have a vedio from 3DX, flight by Pilot CD( international Class).
http://www.tudou.com/programs/view/L68YTH6OiJU/
You can check for it. oh``BTW: i really have some problem for upload the vedio directly, anybody can teach me how upload directly?
Old Dec 05, 2011, 01:25 AM
Joined Mar 2011
Yeah, but over how many flights? If he's done 300 - 500 flights without changing anything, then I'd be interested.
Old Dec 05, 2011, 01:56 AM
Joined Dec 2011
Until now, 200 flights already with no change anything.
Old Dec 08, 2011, 09:17 PM
Hot_Wheels is offline
Find More Posts by Hot_Wheels
United States, IL, Carol Stream
Joined Nov 2009
where can you buy these?
Hot_Wheels is offline Find More Posts by Hot_Wheels
Old Dec 09, 2011, 12:33 AM
Joined Mar 2011
What? The 450Q is available at MyRCMart. The FBL head is not yet released, i believe.
Old Dec 15, 2011, 04:54 AM
virgule is offline
Joined Nov 2011
KDS 450 FBL head
http://www.daddyhobby.com/forum/showthread.php?t=67088 The FBL head has been released!
Old Dec 16, 2011, 01:18 AM
Joined Dec 2011
yes,it's available for order now~ you all can contact your nearby shops and push them for stock if they don't have!! :-)
Discussion THE OFFICIAL KDS 450S 3D THREAD, questions/support TachyonDriver Mini Helis 273 Sep 04, 2014 02:55 AM
Discussion OFFICIAL KDS 450s /sv THREAD / HELP - DISCUSSION - GENERAL - #for all kds needs d1cky_kds Electric Heli Talk 20 Mar 27, 2014 08:28 AM
Discussion Do some to 450Q: A talent guy rcgirl99 Electric Heli Talk 0 Aug 27, 2011 02:18 AM
Discussion KDS 450 C and KDS K-7X radys Electric Heli Talk 4 May 19, 2011 10:24 AM
Discussion KDS 450S. Any good? Any info? keithbarr Electric Heli Talk 5 Jul 15, 2008 01:14 PM
