Old Nov 28, 2011, 08:03 AM
daddyrabbit1954 is offline
Find More Posts by daddyrabbit1954
A posse ad esse
United States, FL, Tampa
Joined Feb 2011
Is There a Way to Calculate Keel Weight?
I recently acquired a model sailing yacht plan, but it's annotations are written in Russian. Shown on the plans is a keel weight cast from lead (I presume) but I am curious how to calculate the amount of actual weight that will be required for the keel. Is there a formula for this?
daddyrabbit1954 is offline Find More Posts by daddyrabbit1954
Old Nov 28, 2011, 08:56 AM
RodACarr is offline
Find More Posts by RodACarr
Joined Jun 2009
Keel Weight
From the drawings, the boat appears to be a model of an International Star class boat. One might look at that classes rules (find them on the web), then develop a ratio of model length/prototype length. Use that ratio cubed, (multiplied by itself 3 times) to find the ratio of volumes between the two. Then multiply the prototype keel weight by the ratio cubed to find the weight of the scaled model.
Check with the AMYA Star 45 class rules to see what they are using for a keel weight, and perform the same exercise. The result will be a different calculated weight for your model, but you'll at least have a couple points of reference.
Remember to use the same length units for all the calculations.
rodcarr@carrsails.com
RodACarr is offline Find More Posts by RodACarr
Old Nov 28, 2011, 09:46 AM
disabled is offline
Find More Posts by disabled
disabled's Avatar
Vienna/Austria
Joined Jan 2009
Hull length?
From the proportions I see I would say 90cm.
Maybe in the range of 2.5 to 3.0 kg therefore.
but thats just an estimate for now.
disabled is offline Find More Posts by disabled
Old Nov 28, 2011, 09:51 AM
A posse ad esse
Joined Feb 2011
Wow. I would have never guessed that much weight. In the past, have built many static scale model ships, but never an RC sailing ship. As a matter of fact, don't even know how to sail an RC ship. Maybe I should start with an RC proven design or a kit. At least then I could read the instructions/annotations.
Cheers
Craig
Old Nov 28, 2011, 11:23 AM
hiljoball is online now
Find More Posts by hiljoball
hiljoball's Avatar
Canada, BC, Strathcona
Joined Jul 2011
If you are interested in the look of the Star and want to build one, there is an excellent class already called the Star 45. There is a class web site
http://groups.yahoo.com/group/Star45/
Join the group.
Then you will find links to get the plans and also to get the frames already laser cut to assist the building process.
John
hiljoball is online now Find More Posts by hiljoball
Old Nov 28, 2011, 12:25 PM
KIWINB is offline
Find More Posts by KIWINB
Auckland New Zealand
Joined Sep 2010
The plan shows length 750mm beam 185mm mast height 980. with the short keel depth I would estimate the bulb weight to be about 2Kg. The plan is a similar size to a Victoria.
KIWINB is offline Find More Posts by KIWINB
Old Nov 28, 2011, 12:39 PM
martin richards is offline
Find More Posts by martin richards
Useful Idiot
Asturias, Spain
Joined Mar 2001
KIWINB, coming from NZ, I'd have expected you to suggest the Racing Sparrow http://www.racingsparrow.co.nz/ which is much better documented for a beginner as well as being quite nifty according to what I have heard.
martin richards is offline Find More Posts by martin richards
Old Nov 28, 2011, 01:03 PM
A posse ad esse
Joined Feb 2011
Now, that's what I need. Don't think I will have any trouble building a ship model, but something that takes me through the learning curve for RC sailing will be extremely helpful to begin with.
Are there any designs that incorporate a motor and screw to go along with sail? I promised a good friend I would build him a model ship as a gift to sail while he sits at the dock in his back yard on the river. There is tidal current as well as normal flow, so something with a motor may be more useful for him as I am not sure a sailing vessel would be appropriate on a river. I live at a lake, so a sailing vessel is fine for my own model.
Thanks to everyone who has replied. You have all given me very helpful information.
Craig
Old Nov 28, 2011, 02:29 PM
Useful Idiot
Asturias, Spain
Joined Mar 2001
http://www.cornwallmodelboats.co.uk/...pner_1175.html is afaik the only motor specifically made for model sailing boats. I'm not sure who handles Graupner products in the USA.
Old Dec 14, 2011, 08:49 AM
tricat is offline
Find More Posts by tricat
Joined Sep 2009
Hi daddyrabbit 1954 you want to find what you require for keel weight.I use this method for getting an idea.once the hull is waterproof I use plastic bottles all but one his full of water.the last bottle is to trim the hull to its water line in a test tank.when it is correct weigh the bottles of water in their containers. All this gives you is how much weight is left available to add to your hull,from this point weigh all that is applicable,radio batteries.mast sails and fittings etc., before you fit to the hull till the only thing left is the keel weight required.Don't forget that if you have to paint it that must be added by approximation.
Hope this helps and good luck Tricat
tricat is offline Find More Posts by tricat
Question Best way to add weight to correct CG? RedRanger Foamies (Scratchbuilt) 6 Oct 22, 2011 10:06 PM
Help! How to calculate weight/volume of a keel bulb? disabled Sailboats 28 Sep 05, 2011 04:35 AM
Discussion Which way to calculate CG Jab69 Foamies (Scratchbuilt) 3 May 29, 2011 08:05 AM
Discussion 1.2 mtr keel bulb weight sirmong Sailboats 4 Jul 15, 2008 10:13 AM
is there a way to calculate flight times SaMx Batteries and Chargers 3 Aug 29, 2005 01:16 PM
