Old Nov 27, 2011, 11:58 PM
pafusion is offline
Find More Posts by pafusion
pafusion's Avatar
USA, UT, Midvale
Joined Dec 2009
Build Log
Peter Rake's Morane Saulnier Racer
The Morane Saulnier Monoplane is an example of the vintage aircraft of the decade between 1910 and 1920. It was built in various configurations including a single and two-seater and was adapted to wartime use. It was one of the aircraft to use wing warping instead of ailerons. Some versions had the fuselage completely covered while others showed the exposed wooden frame from the pilot back. Peter Rake asked for volunteers to prototype several of his recreations of our historical flying machines and I was glad to give it a try. I love the simplicity of the early designs combined with the engineering judgement and creativity of their builders. Using Peter's plans, I'll begin by using the materials I have on hand. I could have purchased laser cut parts from Manzanos and if I fail in my own attempts that is still an option. The photo shows the rough cut wing ribs and some layout on the balsa.
pafusion is offline Find More Posts by pafusion
Old Nov 28, 2011, 03:57 PM
pafusion is offline
pafusion's Avatar
USA, UT, Midvale
Joined Dec 2009
Since the wing ribs were hand traced and cut, I stack them together and sand the bundle to a uniform profile. Next I mark the spar slot and cut a pilot channel with the coping saw and then use an emery board to enlarge the slot and fit it to the wing spar. I've searched the web for pictures of this plane but haven't found much to give me a good idea of a finished color scheme and markings. I think I'd like to stay with French markings though it was marketed to Russia and other European countries. I would welcome a picture to try to emulate.
Old Nov 29, 2011, 02:47 AM
PETERRAKE is online now
Find More Posts by PETERRAKE
Norfolk, England
Joined Sep 2001
Not being a military version, my guess would be clear doped fabric, polished aluminium and painted u/c/pylon. I know the Russians used the type G but didn't think this particular version saw anything but racing use. The one reference I have seen to it (in Jane's 1912 or 1913) say it was doing the circuits.
This model, like several of my other designs, was inspired by a Walt Mooney plan and it came as quite a relief to finally discover a reference to the prototype that was instantly recognisable as the model I'd drawn up.
Whilst there's absolutely nothing wrong with tracing rib blanks and cutting spar slots 'in block' - the traditional approach, the printed patterns could be spray mounted to the balsa/ply to create a sort of printwood kit. Just enough spray mount to hold them, but allow the paper to be peeled off after cutting.
Pete
PETERRAKE is online now Find More Posts by PETERRAKE
Old Nov 29, 2011, 08:51 AM
portablevcb is offline
Find More Posts by portablevcb
Neophyte hacker
portablevcb's Avatar
Albuquerque, NM USA
Joined Sep 2003
Pete,
I do like the printwood kit method, but, I am a klutz when it comes to that. I use too much or the wrong adhesive, or let it stay too long, and I can never get all the paper off. Yes, it is my technique. If I did it correctly it would work great.
My solution is the plywood template. Usually out of 1/16ply. Then a sharp knife and I start cutting. I can usually get away with two templates per wing. If I need some aileron ribs I just make the full size ones first, then cut off the 'tail' of the template and cut the shorter ribs.
Here I am telling people how to avoid buying laser cut parts Oh well.
charlie
portablevcb is offline Find More Posts by portablevcb
Old Nov 29, 2011, 07:36 PM
DeadByDawn is offline
Find More Posts by DeadByDawn
Villain Extraordinaire
DeadByDawn's Avatar
Hell, Wisconsin
Joined Feb 2011
Have you settled on what version you're building? You mention some having an exposed rear fuselage, some being 2 seaters. Do you plan to incorperate the wing-warping? This should prove an interesting build & I'll certainly be following.
DeadByDawn is offline Find More Posts by DeadByDawn
Old Nov 30, 2011, 02:39 PM
pafusion is offline
pafusion's Avatar
USA, UT, Midvale
Joined Dec 2009
Since this is a proto build for Peter, I'm trying to stay as true to design as possible. As I understand the fuselage from the pilot back is open frame so unless Peter tells me otherwise, that is how I'll do it. Once it is completed and flown, I can consider changes. I like the white canvas motif or buff.
Old Nov 30, 2011, 06:27 PM
Norfolk, England
Joined Sep 2001
There is no open fuselage on this particular type. It's just a sinlge seat racer with a fully covered fuselage. Although wing warping should, in theory, be possible, at around 34" span the fuselage would be pretty restricted for space to fit fit the extra servo. The model was never intended to use it, but it's possible - in theory.
I suppose the best way to describe the type is to say it's very similar to a type G or H. But, of course, you'd need to know what they look like before that means very much. A Pfalz E1 is, to all intents, a type G built by the 'opposition'. A sort of mid-wing MS type L. Somewhere on here are threads for the E1 and the type G, but the forward decking is slightly different on this one.
My understanding is that this particular type never saw anything other than service as a racer.
Pete
Old Nov 30, 2011, 06:33 PM
Norfolk, England
Joined Sep 2001
The H, which it most closely resembles.
Old Nov 30, 2011, 09:07 PM
pafusion is offline
pafusion's Avatar
USA, UT, Midvale
Joined Dec 2009
I can't get enough of this aircraft history. Don't know about you but I sometimes find myself thinking of earlier generations as intellectually backwards but 99% or more of the engineering principles I studied in school were developed many generations before I was born. We just try to come up with new ways of using them. I glued the wing frames today so I should have more pictures tomorrow. The advantage of CA over the balsa glue I grew up with is the speed of assembly but the disadvantage is I don't have as much time to think about the next assembly steps while waiting for the glue to dry. Charlie, I don't think you need worry about losing business for your kits. Any one who has built these the old way can appreciate how much more convenient the laser cut parts are. I'm only about half done with the framing and I'm sure I've spent at least 4 hours just cutting parts. Not an efficient use of time. One advantage to the old method of cutting parts is that I can close fit the parts to the stock sheet and not have as much waste. I don't need to allow for the kerf.
Old Dec 01, 2011, 05:19 PM
DeadByDawn's Avatar
Hell, Wisconsin
Joined Feb 2011
Love it! I'm a sucker for those wirey type. Peter, I built your 50" Ponnier, and it was a fun build and a great flyer. Details not exactly to scale, but with the very limited numbers of photographs to work from kinda gave me the liberty of being able to say 'Well, prove that it didn't look exactly like this." Anyhow, enough from me. Pafusion, she's looking nice; keep up the good work.
Old Dec 01, 2011, 07:32 PM
Norfolk, England
Joined Sep 2001
Nice looking Ponnier. No wing warping I take it - I think I can see fixed rear cables at the top pylon? To be honest, I couldn't see any difference between flying with rudder and using the warping. Turns were much the same in either case.
Are those Top-Flite wheels?
Pete
Old Dec 01, 2011, 09:44 PM
DeadByDawn's Avatar
Hell, Wisconsin
Joined Feb 2011
Yes sir, 2 cables are fixed at the pylon & 1 that runs thru for landing wires. You are correct : the wheels are top-flite, and they're a bit on the heavy side but I'll make the trade in a few extra ounces for the decent look. I did buy the spoke wheel kit that gets built on a jig...unfortunately this isn't one of my specialties and the end result was disasterous. All up a fun little plane.
Old Dec 03, 2011, 12:16 PM
pafusion is offline
pafusion's Avatar
USA, UT, Midvale
Joined Dec 2009
Progress photos of wings and control surfaces. Notice the uneven light under some of the wing ribs in the pinned photo. This showed that I didn't have some of the spar grooves cut deep enough. After adjustment and adhesive the results are shown in the next photo. I often leave the ends untrimmed until after gluing so I can get the curve more even. The block of foam insulation works well as the substrate for gluing parts. Sometimes the thin CA penetrates the wax paper and glues to the foam but it can usually be separated without too much trouble.
Old Dec 04, 2011, 04:29 PM
DeadByDawn's Avatar
Hell, Wisconsin
Joined Feb 2011
Is that a small dowel between the elevators? She's a lookin' good
Old Dec 04, 2011, 06:13 PM
1905Flyer3 is offline
Find More Posts by 1905Flyer3
1905Flyer3's Avatar
SC
Joined Jan 2007
Looking good! I usually place the wings bottom-to-bottom and sand them as a unit to get the wing tip curves to match. A really nice build so far...
Paul
1905Flyer3 is offline Find More Posts by 1905Flyer3
Build Log Peter Rake's Morane Saulnier AI - Upsized Pat Lynch Scale Kit/Scratch Built 354 Nov 18, 2015 06:06 AM
Build Log Peter Rake Morane Saulnier Type N prototype build sperry Scale Kit/Scratch Built 206 Oct 27, 2012 12:30 AM
Video Peter Rake Morane Saulnier AI portablevcb Electric Plane Talk 1 Aug 12, 2007 04:41 PM
Peter Rake Morane Saulnier Lloyd Lewins Scale Kit/Scratch Built 136 May 22, 2005 06:40 PM
Peter Rake Morane-Saulnier flying photos! Trizza Scale Kit/Scratch Built 15 May 17, 2003 12:11 PM
