View Poll Results: What forum should the build thread for the Horten VII in?
Leave it here in Giant Electric Planes. 26 72.22%
Move it to the new Nurflügel forum. 10 27.78%
Voters: 36. You may not vote on this poll
Old Nov 27, 2011, 12:47 AM
cpdude is offline
Find More Posts by cpdude
Designing something...
United States, CA, Cameron Park
Joined Jan 2004
2.4 Meter Horten VII
Well I'm well in to my 4.1 meter Horten IIIe build so I though I start doing some CAD work on a new project.
At this point the plan is to use E-Flite 25-46 100 degree rotating retracts for the main and two Exceed RC Rocket 3520-1050 KV motors running two 4S LiPo packs.
As I figure out more I'll make additional posts.
Here are some Horten VII links:
http://www.twitt.org/Farnborough_04.html#top
http://tanks45.tripod.com/Jets45/His...oVII/HoVII.htm
Here are some links to other Horten VII builds:
http://www.dfwt.nl/index.php?option=...mid=28&lang=en
http://www.modelbouwforum.nl/forums/...orten-vii.html
http://thermik-board.de/nurfluegel-f...ehig-t420.html
Here is a smaller kit that is currently available:
http://www.nurfluegel-modelltechnik....h7_mini_e.html
And here are some pictures...
cpdude is offline Find More Posts by cpdude
Old Nov 30, 2011, 11:11 AM
cpdude is offline
Joined Jan 2004
So is there any interest in this plane here? I guess I can post in the Flying Wings or Scale Electric Planes forums.
Brian
Old Nov 30, 2011, 11:59 AM
Ducky22 is offline
Find More Posts by Ducky22
Ducky22's Avatar
Canada, ON, Mississauga
Joined Apr 2011
I am very much interested in it. If you do plan on moving it to another branch, please let me know.
Thanks.
Ducky22 is offline Find More Posts by Ducky22
Old Nov 30, 2011, 01:09 PM
matthew73 is offline
Find More Posts by matthew73
matthew73's Avatar
Melbourne, Australia
Joined Oct 2008
Very interested. Keep us posted. Cheers.
matthew73 is offline Find More Posts by matthew73
Old Nov 30, 2011, 03:13 PM
cpdude is offline
Joined Jan 2004
More progress on the CAD design
I've managed to get some more work done on the CAD Design. The basic wing ribs with leading edge, joiner holes and spar slots are done. Getting the spar placement right was difficult. I ended up using to 1" X 36" aluminum joiner tubes--anything larger in diameter or longer just wouldn't fit!
Next up...
Drawing the ribs and bulkheads for the center section.
Drawing the rest of the sub-leading edge parts.
Drawing the shear webs.
Drawing the flap and elevon skins.
Please let me know if there are any questions.
Brian
Old Dec 01, 2011, 04:02 AM
wizard of odd is offline
Find More Posts by wizard of odd
wizard of odd's Avatar
Australia, VIC, Sale
Joined Apr 2011
It looks like a very interesting and ambitious project. Please keep posting.
Odd
wizard of odd is offline Find More Posts by wizard of odd
Old Dec 02, 2011, 05:09 AM
Peter V is offline
Find More Posts by Peter V
Peter V's Avatar
Joined Nov 2008
2.4 Horten VII
Hello Brian,
interested also.
do you know this site? http://www.modelbouwforum.nl/forums/...orten-vii.html
Apart from the building and flying, at the end, there are some pictures of the landinggear
greetings
Peter
Peter V is offline Find More Posts by Peter V
Old Dec 02, 2011, 07:06 AM
cpdude is offline
Joined Jan 2004
@Peter - This discussion is definitely a good candidate for the proposed Nurflügel forum. When that happens I'll probably move it there. Also, thanks for the link. I did know about the site. It was my second link under other Horten VII builds listed above.
Brian
Old Dec 02, 2011, 07:33 AM
ChuckA is offline
Find More Posts by ChuckA
Tennessee
Joined Sep 2003
I hope you keep posting on RC Groups. I was looking forward to the rest of this thread
ChuckA is offline Find More Posts by ChuckA
Old Dec 02, 2011, 07:50 AM
cpdude is offline
Joined Jan 2004
@Chuck - I still plan to post here on RCG just possibly under a new forum. Take a look here: http://www.rcgroups.com/forums/showthread.php?t=1547670 and vote if you'd like.
Brian
Old Dec 02, 2011, 09:26 AM
Knoll53 is offline
Find More Posts by Knoll53
less is more
Knoll53's Avatar
United States, CA, Marina
Joined Sep 2006
Originally Posted by cpdude View Post
I've managed to get some more work done on the CAD Design...Please let me know if there are any questions.
Brian
So I trust that you have incorporated the the twist into the model at this point. When laying out the spar caps, do you twist them along with the chord or leave them vertical?
Kent
Knoll53 is offline Find More Posts by Knoll53
Old Dec 02, 2011, 09:41 AM
birdofplay is online now
Find More Posts by birdofplay
Retired CAD guy
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
I am curious about the REAL aircraft's Props.
What is the purpose of those small multiblade "fans" ?
Vas ist
birdofplay is online now Find More Posts by birdofplay
Old Dec 02, 2011, 09:57 AM
cpdude is offline
Joined Jan 2004
Kent
Yes, the twist [via the Nurflügel program] has been incorporated into the model. I leave the spar caps vertical--no twist!
Brian
Old Dec 02, 2011, 10:02 AM
cpdude is offline
Joined Jan 2004
Vas ist
That's a very good question. There is some talk about them here. If I'm reading it correctly they seem to be used to "power" the movement of the propeller blades (i.e. setting the pitch of the blades). That makes sense to me.
Brian
Old Dec 02, 2011, 09:05 PM
cpdude is offline
Joined Jan 2004
Well, I managed to get some of the items listed in post #5 completed. I'm done with the sub-leading edge parts and the main shear webs. I've started the center section ribs and bulkheads, as well as, the control surface skins, but, I still have a bit of work to do on these.
I was slowed down a bit because things needed to be moved and/or resized a bit in the center section. I moved the main gear retracts a little further up into the center section because the wheels weren't going to retract fully inside the wing. This in turn meant I needed to reduce the size of the wing joiner tube from a full 1" to 7/8".
I also had clearance issues between the prop shafts and the front wing joiner tube. Reducing the side of the joiner tubes helped but in the end I had to make a slight change to the angle of the prop/prop shaft. I did this by moving the motors higher up by about 4-5mm while leaving the center of the propellers in the same position.
On a positive note. I did managed to complete the design of all main wing panel ribs including all of the lightening holes and alignment tabs.
I just need to remember that two steps forward and one step back is still forward progress.
I'll try to post more pictures later.
Brian
Build Log 4.1 meter (1/5 scale) Horten IIIe cpdude Scale Sailplanes 408 Mar 05, 2016 01:45 AM
Build Log 2 Meter Horten XII cpdude Flying Wings 350 Mar 04, 2013 08:46 AM
Build Log RJF Horten-Beluga 1/4 andrecillo76 Scale Sailplanes 51 Dec 26, 2011 11:18 AM
Wanted 2 meter 2.4 friendly slope glass ship. kilgoretrouts Aircraft - Sailplanes (FS/W) 0 Oct 06, 2011 02:11 PM
Sold ***Shark XL Strong 4.5 meter 2.4 safe RTF*** Just flyy Aircraft - Sailplanes (FS/W) 7 Sep 21, 2011 12:19 PM
