Old Nov 26, 2011, 10:11 PM
modelerchina is offline
Find More Posts by modelerchina
Canada, ON, Mississauga
Joined Apr 2006
big problem with proboat coast guard boat
I tried to install universal connector(in the green box), as the original connector is so binding.
when I play with the position of the motor rack, things happen.
One of the nut that stick behind the wooden box has fallen off - the red circled place. I cannot feel the thread at all, while the other three have proper nuts.
Do I have to take off the whole thing to put the nut back to place?
I saw the wooden structure are inter-locked and glued very tightly. It is gonna be a big job then. Or I have to open a whole to the bottom of fiber glass hull, which destroy my boat's structure.
modelerchina is offline Find More Posts by modelerchina
Old Nov 26, 2011, 10:15 PM
Umi_Ryuzuki is online now
Find More Posts by Umi_Ryuzuki
Sea Dragon-Lover
Umi_Ryuzuki's Avatar
PDX, OR
Joined Dec 2002
If you want to put a blind("T") nut underneath, and wood is tight to the hull, your options are limited.
Have you thought about using a threaded insert instead?
Aimee
Umi_Ryuzuki is online now Find More Posts by Umi_Ryuzuki
Old Nov 26, 2011, 10:41 PM
frankg is online now
Find More Posts by frankg
Joined Dec 2004
MODELERCHINA- First off looking at the pictures you posted it looks like the shafts were really binding since the end of the stuffing boxes look like they discolored from heating up. The easiest way to correct the aliment from the motor to the prop shaft is by using a double joint universal.
http://www.mackproductsrc.com/double_univ_.htm
frankg is online now Find More Posts by frankg
Old Nov 26, 2011, 11:52 PM
Apismelifera is offline
Find More Posts by Apismelifera
1/2 a bubble off
Apismelifera's Avatar
United States, NY, Schenectady
Joined Mar 2011
Looks like there was a tee nut there already, or similar, factory installed, and it fell out when the motor was removed. I think that is what is indicated by the red circle.
The problem is how to reinstall the nut without cutting the bottom of the boat to get to it.
Apismelifera is offline Find More Posts by Apismelifera
Old Nov 27, 2011, 12:24 AM
CaptCB is offline
Find More Posts by CaptCB
CaptCB's Avatar
United States, CA, Orange County
Joined Aug 2011
Blind nut repair
Install a threaded insert from the top. Oversize the hole to fit the insert. The flange nuts used for aircraft wood motor mounts, would work. Get the 2-56, or the 4-40 ones, and remove the 3 spikes. They are made by DU-BRO products. Any hobby store that has aircraft should have them. Install with a med CA glue. Be careful not to get glue in the threads. If you do, just run a tap through and it will be fine. I also, would get rid of the factory universals!!! The Dumas dogbone system, works great. CaptCB
CaptCB is offline Find More Posts by CaptCB
Old Nov 27, 2011, 08:39 AM
Joined Apr 2006
Thank for you guys input. My question is I cannot get to the bottom side of the wood piece to re-install the flange nut. in terms of threaded insert, can i screw it in from top-to-down? the wooden piece is about 2mm thick, does it enough to hold strong with some CA?
I thought about dremel a round hole besides it to allow finger in, but again it is tight and screeze.
if i open a hole from bottom, it is even more nasty, and what if the other 3 are fallen off?
or I gonna move the motor off from the original place, which require to re-build a new base and glue or screw new base to the existing one.
Old Nov 27, 2011, 08:47 AM
Joined Apr 2006
it may be hot, but the black you see on are mostly lubes that mess up from the prop shaft. i bought one step joint universal, in the green box. and then trouble happens.
Old Nov 27, 2011, 08:59 AM
JOHN SCALE BOAT is offline
Find More Posts by JOHN SCALE BOAT
JOHN SCALE BOAT's Avatar
United States, PA, Slatington
Joined Feb 2007
A trick to reinstall the blind nut is run a piece of wire down through the hole and keep feeding it till the end reaches a open area where you can get to it. Then insert the blind nut on the wire and tie a knot at the end of the wire. Now pull the wire back through the hold till the nut is pulled back into the correct location. Now comes the tough part. Take a long screw that fits the blind nut and put a very light coat of grease on the threads. Now cut the wire and it should fall out of the threads and carefully thread the bolt in without pushing the nut out. Once the bolt is threaded in now apply CA while pulling the nut in the correct position. The grease will keep the CA from gluing the bolt to the blind nut and out of the threads. Good Luck.
JOHN SCALE BOAT is offline Find More Posts by JOHN SCALE BOAT
Old Nov 27, 2011, 12:11 PM
Sea Dragon-Lover
PDX, OR
Joined Dec 2002
Threaded inserts match the thread of your bolt on the inside, and
are slotted on the top and threaded on the outside so they can be
inserted from the top of a mounting location.
Old Nov 27, 2011, 03:01 PM
Joined Apr 2006
I see the point, ordered some this, my screw is M3, probably the #4 as per wiki about screw size. thank you all guys.
http://www.ebay.ca/itm/Du-Bro-Thread...ht_2137wt_1037
Old Nov 27, 2011, 03:06 PM
modelerman is offline
Find More Posts by modelerman
Ed Croughwell
modelerman's Avatar
New England
Joined Mar 2007
rivnut
Maybe these might help. If this link doesen't work, the try a google search for "rivnut"
http://www.google.com/imgres?hl=en&s...AYvqqRg&zoom=1
modelerman is offline Find More Posts by modelerman
Old Nov 28, 2011, 11:58 AM
Kmot is online now
Find More Posts by Kmot
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
Hi there modelerman. As an extensive user of those inserts, I would like to pass on a little experience.
If you have a set of calipers, measure the diameter of the barrel inside the threaded area. This is the part of the barrel that will be in contact with the edges of the hole. You do not want the hole to be as large as the barrel diameter. If it is, the insert will fit loose. You want the hole you drill to be slightly under sized to the diameter of the barrel. The packaging indicates what size drill bit to use but I have often found that recommended drill bit to be too large. I usually end up using a Number Drill as opposed to a Fractional Drill.
Once you have the hole drilled to the optimum size, start your insert to begin the cutting of the thread. Use a small square to be sure it is perpendicular to the wood plate. Then back it out slightly and apply a dab of epoxy glue. Screw the insert in the rest of the way until the top is just barely above the surface. Wipe away an epoxy with rubbing alcohol.
Another tip: Be sure to hold your screwdriver perfectly straight up and down when screwing in the insert. Any sideways pressure at all will snap off the brass tabs.
Hope this helps!
Kmot is online now Find More Posts by Kmot
Old Nov 29, 2011, 01:59 AM
CaptCB is offline
CaptCB's Avatar
Joined Aug 2011
Threaded Inserts
My way of installation is different, drill the hole slightly oversize, and then run a tap in. I the screw in the insert, and lock it in place with Thin, then MED., CA. I have never had any inserts fail yet, and I tighten my motor mounts, pretty good. CaptCB
Old Nov 29, 2011, 08:42 PM
Joined Apr 2006
excuse me for my english, what is " then run a tap in"
Old Nov 29, 2011, 09:36 PM
Sea Dragon-Lover
PDX, OR
Joined Dec 2002
Wanted Proboat or Midwest Coast Guard MLB ChanceJ Boats (FS/W) 17 Nov 24, 2011 09:47 PM
Sold midwest products 47' coast guard boat 48chebbie Boats (FS/W) 2 Nov 01, 2011 12:26 PM
Wanted Robbe mzb lehmar radio control coast guard patrol boat 6789boat Boats (FS/W) 1 Sep 13, 2011 08:41 AM
Sold Proboat Coast guard boat PKDURANGO Boats (FS/W) 1 Jul 25, 2011 06:54 PM
Discussion Props for proboat Coast Guard rescue hotrodder Dock Talk 0 May 18, 2011 05:15 PM
