Old Jan 04, 2013, 09:24 AM
buckaroo is offline
Find More Posts by buckaroo
Banzai Institute
buckaroo's Avatar
United States, NY, West Seneca
Joined Oct 2005
Matchpoint could you elaborate a little. Did you need longer shafts because the motor does not fit inside the tube, or was there other factors involved.
Dean
buckaroo is offline Find More Posts by buckaroo
Old Jan 04, 2013, 09:50 AM
erh7771 is online now
Find More Posts by erh7771
Joined Nov 2005
Dean
Instead of taking the ribs away from the SK motor you can also take away around .5mm from the inside of the can holder with a 5usd whole drill...I think I have the bit posted upthread.
The SK3 560kv motor HK sells can have the shaft changed with a 8mm steel shaft from MC-Master Car.... I bought around 4 motors worth of 8mm shaft....20usd just to make sure
Then you reinforce the mount and PU the blades..
Took me a couple of hours (I changed the shaft on an scorpion motor though) and well worth it.
The sound you see in all my 120mm vids is the fan with a slight unbalance at low to mid RPM so they can run quieter than what you hear in the vid...
75usd - SK3 motor
75usd - fan
90usd - 14s 120 esc
18lbs 12oz of thrust on 14s at 120 amp 250-ish usd for everything and some elbow grease = nice
erh7771 is online now Find More Posts by erh7771
Old Jan 05, 2013, 07:55 PM
matchpoint is offline
Find More Posts by matchpoint
Joined Oct 2012
I turned down the cooling fins on a lathe.
I bored out the motor housing slightly
I reinforced the motor mount with a carbon fiber sleeve.
I PU'd the blades.
I bought the 8mm turnigy shafts off hobbyking that are 103mm long, had a new snapring groove cut.
Press fit in new shaft. Shimmed accordingly.
Reinforced top of motor mount with more carbon.
I have three of these. Here is #1 before dynamic balance.
fan#2.wmv (0 min 25 sec)
matchpoint is offline Find More Posts by matchpoint
Old Jan 07, 2013, 09:39 PM
bubsmurray is offline
Find More Posts by bubsmurray
Joined Jan 2012
Sounds good. Nice mods ! I have fiddled a lot with mine and found th best upgrade to be a collect type blade holder instead of the grub screws onto the shaft. Check out scatsbob previous posts. Good to know the .sk3 motor works out. Let us know how it keeps up!
By the way, what is the ring around the shroud? Looks like a piece of wire ?
[QUOTE=matchpoint;23723805]I turned down the cooling fins on a lathe.
I PU'd the blades.
bubsmurray is offline Find More Posts by bubsmurray
Old Jan 08, 2013, 12:59 AM
Joined Oct 2012
They are rubberbands.
Old Feb 04, 2013, 04:55 AM
makser is offline
Find More Posts by makser
Spain, Vizcaya, Bilbao
Joined Nov 2005
i have two fans, and buy two 800-73 series motor (590)KV
expected amps at 12s and 14s( i know works fine with good ventilation)
makser is offline Find More Posts by makser
Old Feb 21, 2013, 12:33 PM
voxel is offline
Find More Posts by voxel
United States, FL, Altamonte Springs
Joined Jun 2012
With all this talk of using cheapo outrunners (i.e from Leadershobby)... anybody try to use the Eflite BL32 1010kv motor? I have one from a dead Scimitar... it appears to be the right size for this fan and might be okay in the 6s to 8s range.
voxel is offline Find More Posts by voxel
Old Feb 21, 2013, 08:49 PM
Joined Nov 2005
I'm going to be doing the same here soon for a Byron F16 but I'm going to use the HK 880kv motor on 6s....hopefully around 120 - 130 amps around 11lbs of thrust
I think a good 8s motor would be in the 740is...
Shoot, there was a 740kv scorpion on runryder a while ago, should've picked it up.
I'm thinking there are a lot of 50 - 55 + mm motors that can handle around 3000 watts easily and turns watts into RPMs
Is the eflight motor 50mm?
regards
Old Feb 22, 2013, 12:21 AM
voxel is offline
Joined Jun 2012
Gah. I thought it was, but I just measured the diamter. 40mm. I guess it fits a 90mm fan only?
Old Feb 22, 2013, 12:40 AM
Angel RC Design is offline
Find More Posts by Angel RC Design
Angel RC Design's Avatar
United States, NJ, Weehawken
Joined Apr 2011
Hello Every body
Has any one use a Byron with a 6in hurrican fan?
Angel RC Design is offline Find More Posts by Angel RC Design
Old Feb 22, 2013, 09:13 PM
Joined Nov 2005
Maybe some of three bigger can holders
Old Feb 27, 2013, 01:07 PM
Roger60 is offline
Find More Posts by Roger60
Amsterdam
Joined Mar 2002
Hello
Hello guys,
I have a fan like the cs 120 mm 12 blade.
I was wondering what the pu gleu does only expant?
Because it doesnt gleu steel.
Let me know
Roger60 is offline Find More Posts by Roger60
Old Feb 27, 2013, 01:08 PM
Joined Nov 2005
Originally Posted by Roger60 View Post
Hello guys,
Let me know
It'll expand into the keying of the blade base and not allow the blades to slip out via centrifugal force.....as easy
regards
Old Feb 27, 2013, 01:48 PM
Roger60 is offline
Amsterdam
Joined Mar 2002
Pu
regards
So if i get it wel the blades are gleued with no cg. g's and then have to hold them.
I think balanced blades , must hold them if u screw them thight.
Maybe i am wrong
Regards
Old Feb 27, 2013, 03:10 PM
Joined Nov 2005
Maybe i am wrong
Regards
Don't hold them, put them in the blade holder as before with the shaft adapter
It can be messy...grease the shaft adapter up
New Product Change Sun 12 blade 90mm Flip Flop Electric Ducted Fan Jet Talk 7289 Yesterday 01:24 AM
New Product Change Sun 120mm and new 10 blade 70mm fans Flip Flop Electric Ducted Fan Jet Talk 131 Apr 27, 2012 07:07 PM
For Sale Change Sun 120mm EDF yellowbird2800 Aircraft - Electric - Jets (FS/W) 5 Apr 14, 2012 08:03 PM
Sold Change Sun 120mm Flip Flop Aircraft - Electric - Jets (FS/W) 1 Oct 28, 2011 10:41 PM
Sold Change Sun 120mm Flip Flop Aircraft - Fuel - Jets (FS/W) 0 Oct 28, 2011 04:50 PM
