Old Aug 04, 2012, 05:43 PM
erh7771 is online now
Find More Posts by erh7771
Joined Nov 2005
Originally Posted by Knife Liddle View Post
Wow! That`s impressive. What motor?
Never mind, I see your other post says the Scorpion 4035-560. Even on 14s it would be a lot of power. The YEP 120 could do that for $90. Maybe 6kw + a little.
Yes, the FETs on the YEP 120 will go to 140amps but I don't know about the ESC's PC etching...that's what needs to be tested in the long run IMHO
erh7771 is online now Find More Posts by erh7771
Old Aug 05, 2012, 07:50 AM
lipoflyer is offline
Find More Posts by lipoflyer
lipoflyer's Avatar
Australia
Joined Nov 2010
Hi guys,
I plan on running this in the 90mm flyfly sabre. More then enough room. It I am looking for efficient thrust production for about the same thrust as the 90mm 12 blade
I am thinking Of running 1250kv on 6S. Your thoughts?
lipoflyer is offline Find More Posts by lipoflyer
Old Aug 05, 2012, 02:31 PM
PAPE is offline
Find More Posts by PAPE
Joined Jun 2012
I think just the weight penalty of the 120mm system, will overcome any increase in efficiency if any a all.
PAPE is offline Find More Posts by PAPE
Old Aug 05, 2012, 04:29 PM
Knife Liddle is online now
Find More Posts by Knife Liddle
Lee Liddle
Knife Liddle's Avatar
Carrollton, Tx
Joined Dec 2006
Originally Posted by lipoflyer View Post
Hi guys,
Yes, you would have more thrust, but for the same power level your efflux speed will be so much lower that I don`t think the performance will be there. What speed are you looking for on the top end?
Knife Liddle is online now Find More Posts by Knife Liddle
Old Aug 05, 2012, 11:22 PM
lipoflyer's Avatar
Australia
Joined Nov 2010
I am not going for Speed. Going for flight-time and sound. 100-120kph would be fine. The FlyFly f-86 Airframe kis quite dragy so i'm not interested in speed.
Old Aug 06, 2012, 12:58 PM
super kupfer is offline
Find More Posts by super kupfer
Anything that gives me a High
super kupfer's Avatar
Canada, BC, Richmond
Joined Jan 2010
Is anybody currently flying with this CS 120??? Im thinking about putting one in an Aeronaut Rafale , maybe as an hybrid fan (keep the rotor and replace the rest with something of better quality).
super kupfer is offline Find More Posts by super kupfer
Old Aug 08, 2012, 10:57 PM
bubsmurray is offline
Find More Posts by bubsmurray
Joined Jan 2012
Ive done the same. Kept the blades. Machined up a collet type adaptor. Modified the rclander ali housing, and made my own carbon fibre tube. Havent flown it yet but first run up went much better than my first attempts with the plastic housing. Wil post some pics soon.
bubsmurray is offline Find More Posts by bubsmurray
Old Aug 08, 2012, 11:12 PM
Joined Jan 2012
I am using the hobbyking delux 160 amp and what a dissapointment! It gets very hot even after 30 seconds of running at 115 amps. It even cuts to half throttle, I think it is a thermal protection. Using 12s. Anyone else have this experience with this esc?
I have used the hi-model ice 120 a few times before and it works really good. Wonder if anyone has tested there 180. Or do you think thr 120 will do. Any good reliable alternatives?
Old Aug 09, 2012, 08:23 AM
Joined Nov 2005
Originally Posted by bubsmurray View Post
...I have used the hi-model ice 120 a few times before and it works really good. Wonder if anyone has tested there 180. Or do you think thr 120 will do. Any good reliable alternatives?
I've gone past 120 amps on the hi-model or YEP (at HK) and it's runs really nice without airflow and will run even better with it.
Old Aug 09, 2012, 03:42 PM
db_sonic is offline
Find More Posts by db_sonic
Joined Feb 2010
That's good to hear. Thanks for the info on the YEP with 14s. Going to have to make a new battery harness for 14s instead of 12s : )
db_sonic is offline Find More Posts by db_sonic
Old Aug 09, 2012, 08:21 PM
Joined Jan 2010
Too bad they don't sell the rotor separate.
Old Aug 10, 2012, 11:22 AM
Joined Jan 2012
I was lucky. X-flight sent me 2 sets if blades after I broke one blade. All free of charge!
I would love to know how to contact changesun directly.
Old Aug 12, 2012, 10:14 PM
Joined Jan 2010
HK sells the 90mm rotor separately, how soon before they start selling the 120mm rotor???
Old Aug 21, 2012, 12:04 PM
Joined Jan 2012
What amps do you think are safe on the scorpion 560 motor. I hit around 114A on 12s pack and motor was warm. Wonder if 14s would be ok!
18lbs settled\14s\120amps\51 volts... ~ 6200 watts peak..I think the amps were lower I was looking at peak amps on the ET logger
That was settled thrust peak was almost 18lbs 10oz....on 3300mah 65c Nanos...
That's some decent thrust, that'll push around a good number of aircraft...
Old Aug 21, 2012, 12:21 PM
SteveC68 is offline
Find More Posts by SteveC68
Oh Yeah!
SteveC68's Avatar
League City, Texas
Joined Sep 2006
I wonder if the YEP can go higher with lower voltage. Say 10S. I know that HK derates their SS line of speed controllers if you run them at their max rated voltage.
SteveC68 is offline Find More Posts by SteveC68
New Product Change Sun 12 blade 90mm Flip Flop Electric Ducted Fan Jet Talk 7289 Sep 27, 2016 01:24 AM
New Product Change Sun 120mm and new 10 blade 70mm fans Flip Flop Electric Ducted Fan Jet Talk 131 Apr 27, 2012 07:07 PM
For Sale Change Sun 120mm EDF yellowbird2800 Aircraft - Electric - Jets (FS/W) 5 Apr 14, 2012 08:03 PM
Sold Change Sun 120mm Flip Flop Aircraft - Electric - Jets (FS/W) 1 Oct 28, 2011 10:41 PM
Sold Change Sun 120mm Flip Flop Aircraft - Fuel - Jets (FS/W) 0 Oct 28, 2011 04:50 PM
