Old Dec 07, 2011, 07:32 PM
Flip Flop is offline
Find More Posts by Flip Flop
Flip Flop's Avatar
United States, UT, Syracuse
Joined Oct 2009
Something is a little off in the video, but it does sound good.
I think I might try the HET 700-98-670.
Flip Flop is offline Find More Posts by Flip Flop
scatsob is offline
Find More Posts by scatsob
Bypass Ratio = Infinity
scatsob's Avatar
United States, NC, Jacksonville
Joined Apr 2006
Originally Posted by SCALECRAFT View Post
6.6 kg = 14.6lbs Not bad.
8800 watts 12s @ (4 volts per cell for around 2 seconds) no sag at all would = 183.3 amps according to internet calculators.
Realistically, volts would be less. So whats the amp draw??
Something doesn't make sense, or it's just too much for that motor.
Scott, we have fans, lets get some airframes together!!!!
Steve
6.6kg on 8800 watts is bad IMHO. On my crappy old Haoye 4.5" rotor I got 11 lbs on 3200 watts. This would only be 3.6lb more thrust on dang near thriple the power. Something is not right, however I am happy the rotor will hold together at these power levels.
scatsob is offline Find More Posts by scatsob
Old Dec 07, 2011, 07:38 PM
scatsob is offline
scatsob's Avatar
Joined Apr 2006
I think that is a good start. On 12s or 10s?
Old Dec 07, 2011, 07:52 PM
turbonut is offline
Find More Posts by turbonut
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
lower volts
I guess even if the cells do sorta good...your lookin at 200 amps for 8800 watts
Also that number is with no intake lip or tail pipe...so it will be diffrent..my guess is thrust will jump up a lot
Steve
Old Dec 07, 2011, 08:13 PM
corsair nut is online now
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
plus that kv is way too high...most of those watts are waste heat. a 600 kv would probably give same thrust at way less watts. lets judge the fan using a proper kv and inlet lip
corsair nut is online now Find More Posts by corsair nut
Old Dec 07, 2011, 08:25 PM
Flip Flop's Avatar
Joined Oct 2009
I'm hoping 12s, but will start with 10.
Old Dec 07, 2011, 08:28 PM
JimDrew is offline
Find More Posts by JimDrew
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
Yeah, that Kv is WAY too high. On 15S - 8300 watts (155A) we are getting 22 pounds of thrust with the Dynamax fan.
JimDrew is offline Find More Posts by JimDrew
Old Dec 07, 2011, 10:42 PM
SCALECRAFT is offline
Find More Posts by SCALECRAFT
Joined Apr 2004
Originally Posted by JimDrew View Post
Yeah, that Kv is WAY too high. On 15S/8300 (155A) watts we are getting 22 pounds of thrust with the Dynamax fan.
What kv?
SCALECRAFT is offline Find More Posts by SCALECRAFT
Old Dec 07, 2011, 11:49 PM
turbonut is offline
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
Scorpion
he said the test were with a 800KV motor!
What kv?
Old Dec 08, 2011, 08:13 AM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
What kv?
650Kv.
Old Dec 08, 2011, 08:56 AM
erh7771 is offline
Find More Posts by erh7771
Joined Nov 2005
The amp meter is off, has too be ...sounded great
erh7771 is offline Find More Posts by erh7771
Old Dec 12, 2011, 09:09 PM
scatsob is offline
scatsob's Avatar
Joined Apr 2006
How about a Scorpion 4035-400 on 16s? Itís got an 8mm shaft and is on sale. I wish I was not on such a tight budget and had all my money earmarked for other things or I would pick one up to store away for a future high-volt setup. You decide what motor you are going to use FF?
Old Dec 12, 2011, 10:32 PM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
Lee, how do you think the modded HK 600 motor would do on this fan?
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Dec 17, 2011, 07:48 PM
scatsob is offline
scatsob's Avatar
Joined Apr 2006
Any idea when X-Flight is going to release these FF? Since you got yours I figured they would go up on the site soon. I'm inpatient.
Old Dec 19, 2011, 07:57 AM
michel49 is offline
Find More Posts by michel49
Joined Jul 2011
Where I could purchase that CS 12 blades rotor ?
michel49 is offline Find More Posts by michel49
New Product Change Sun 12 blade 90mm Flip Flop Electric Ducted Fan Jet Talk 7243 Jul 18, 2016 07:09 PM
New Product Change Sun 120mm and new 10 blade 70mm fans Flip Flop Electric Ducted Fan Jet Talk 131 Apr 27, 2012 07:07 PM
For Sale Change Sun 120mm EDF yellowbird2800 Aircraft - Electric - Jets (FS/W) 5 Apr 14, 2012 08:03 PM
Sold Change Sun 120mm Flip Flop Aircraft - Electric - Jets (FS/W) 1 Oct 28, 2011 10:41 PM
Sold Change Sun 120mm Flip Flop Aircraft - Fuel - Jets (FS/W) 0 Oct 28, 2011 04:50 PM
