Old Dec 06, 2011, 07:06 PM
corsair nut is offline
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
wow, cant wait to hear how it does....shroud looks kinda hoaky though....
get'r done!
corsair nut is offline Find More Posts by corsair nut
Old Dec 06, 2011, 07:10 PM
scatsob is offline
Find More Posts by scatsob
Bypass Ratio = Infinity
scatsob's Avatar
United States, NC, Jacksonville
Joined Apr 2006
Wow, thats awesome. So they should be showing up at x-flight pretty soon then?
scatsob is offline Find More Posts by scatsob
Old Dec 06, 2011, 07:14 PM
Arngeir Blakseth is offline
Find More Posts by Arngeir Blakseth
Senior Member
Arngeir Blakseth's Avatar
Molde, Norway
Joined Jan 2001
Neu 1917/1Y has a 590kV and will do 6kW+ without issues. Also available with a 8mm shaft and it has a 50mm diameter so it's a perfect fit really.
Arngeir Blakseth is offline Find More Posts by Arngeir Blakseth
Old Dec 06, 2011, 07:23 PM
turbonut is offline
Find More Posts by turbonut
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
Hummm...My f100 needs one of them!
Old Dec 06, 2011, 07:32 PM
Flip Flop is offline
Find More Posts by Flip Flop
Flip Flop's Avatar
United States, UT, Syracuse
Joined Oct 2009
Cool thanks, might be an option.
Where can you find them?
Flip Flop is offline Find More Posts by Flip Flop
Old Dec 06, 2011, 07:33 PM
Flip Flop's Avatar
Joined Oct 2009
I sent them a e-mail asking about the release date, but I think it's close cause this looks like a production model not a prototype.
Old Dec 06, 2011, 07:50 PM
Senior Member
Molde, Norway
Joined Jan 2001
Usually has to be ordered directly from Castlecreations, not many Neu dealers out there stocking these I'm afraid. I had to wait 7 weeks to get mine made and delivered.
Old Dec 07, 2011, 07:55 AM
erh7771 is online now
Find More Posts by erh7771
Joined Nov 2005
What do you think the pricing is going to be like?
erh7771 is online now Find More Posts by erh7771
Old Dec 07, 2011, 10:19 AM
SCALECRAFT is offline
Find More Posts by SCALECRAFT
Joined Apr 2004
I hope the cone spinner assembly has been machined to center on the shaft without the need of the blades.
What to I mean???
If one removes all the blades and assembles all the aluminum parts onto the adapter, they all align on center except the cone. It has no aluminum support/lockin/alignment . It relies on the plastic blades to "center" itself and to stay centered at the high rpm range.
The cone extends out and is one of the more important components of balance and wobble.
I have a retro fix for mine. I'll post it once it's done. Would work for many fan systems as well.
Steve
SCALECRAFT is offline Find More Posts by SCALECRAFT
Old Dec 07, 2011, 04:42 PM
Eddie P is offline
Find More Posts by Eddie P
Official Boat Bum
Eddie P's Avatar
United States, NV, Reno
Joined Mar 2000
Hey, what F-100 do you have that will take a 120mm fan???
Eddie P is offline Find More Posts by Eddie P
Old Dec 07, 2011, 05:40 PM
Flip Flop's Avatar
Joined Oct 2009
Here is the x-flight guys final test video of the fan with Scorpion 800kv motor on 12s hitting 8800 watts.
I have to give them props for putting this thing through the ringer for the last several months trying to get it right before they release it. Sounds like the batteries are sagging pretty bad though.
120mm.wmv (1 min 15 sec)
Old Dec 07, 2011, 06:46 PM
scatsob is offline
scatsob's Avatar
Joined Apr 2006
Hmmmmm....I'm a little confused. 8800 watts and it only hit 6.6kg? Couldnt really read the amp meter either. Sounded great though!
Old Dec 07, 2011, 07:06 PM
turbonut is offline
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
Yikes...over 200 amps...is that correct
Old Dec 07, 2011, 07:10 PM
turbonut is offline
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
Big
Hi Eddie..its a Usher F100
Old Dec 07, 2011, 07:19 PM
Joined Apr 2004
6.6 kg = 14.6lbs Not bad.
8800 watts 12s @ (4 volts per cell for around 2 seconds) no sag at all would = 183.3 amps according to internet calculators.
Realistically, volts would be less. So whats the amp draw??
Something doesn't make sense, or it's just too much for that motor.
Scott, we have fans, lets get some airframes together!!!!
Steve
New Product Change Sun 12 blade 90mm Flip Flop Electric Ducted Fan Jet Talk 7286 Sep 12, 2016 11:32 PM
New Product Change Sun 120mm and new 10 blade 70mm fans Flip Flop Electric Ducted Fan Jet Talk 131 Apr 27, 2012 07:07 PM
For Sale Change Sun 120mm EDF yellowbird2800 Aircraft - Electric - Jets (FS/W) 5 Apr 14, 2012 08:03 PM
Sold Change Sun 120mm Flip Flop Aircraft - Electric - Jets (FS/W) 1 Oct 28, 2011 10:41 PM
Sold Change Sun 120mm Flip Flop Aircraft - Fuel - Jets (FS/W) 0 Oct 28, 2011 04:50 PM
