Odenton, MD
Joined Apr 2009
Check this thread here and you will see all the work that needs to be done to get the 6 axis to fly right. I tried it one time and it flew like crap so I just went to the 3 axis setting.
http://www.rcgroups.com/forums/showthread.php?t=1536760 As far as it being a good beginner heli?? I am kind of torn because I love my GCP and I think it is super easy to fly but I have been flying CP for about 2 years and single rotor FP helis for about 1 1/2 - 2 years. Tough for me to recomend a CP heli when your only experience is coax. Not saying it can't be done but would hate to see you get frustrated and quit. So if you are up for a REAL challenge I would say the GCP would be good for you. If you are the type that is easily frustrated do yourself a favor and get a solo pro or an msr. Fly that around a bit untill you learn all your orientations and such. I would definitely recomend the genius to you after a few months of flying any single rotor FP heli for a few months. The genius is super tough if you fly outside over grass and hit throttle hold before crashing. I dumped mine today no less than 50 times inverted in the grass today and no damage. Well the canopy got all busted but nothing some packing tape couldn't fix. Good luck on whichever path you choose. This is a very rewarding hobby and the new technology is just making it easier to learn. Happy flying!
![]() Quote:
![]() I thought that maybe starting with a 4-Channel Fixed Pitch heli would be the best learning route, but I was thinking that maybe I could get the best of all worlds with the Genius CP. I am definitely not one to quit or get frustrated, and I have a lot of patience when it comes to learning and mastering a given task. What do you think of the Walkera V120D02 vs. the Genius CP? Any benefit of one over the other? Is one easier to fly/learn on than the other? Seems like the Genius is the more versatile of the two, but I could be wrong. If I did choose to go down the Fixed Pitched route, what do you think of the Walkera CB100? It seems to meet your single rotor, fixed pitch criteria. Would either the Nine Eagle Solo Pro or the Blade mSR be better choices than the CB100? If so, if you could educate me as to why that would be a HUGE help. Sorry for all of the questions, I'm just trying to get as educated as possible before pulling the trigger on one. Thanks for your time and help!
Additionally, I really like the new Walkera DeVention 8 radio (which is offered as an option on the Genius CP), but I wouldn't be able to purchase it and use it with the CB100 AND the Genius CP. This means that I would have to purchase separate radios for a 4-Channel FP and the 6-Channel GCP. This might be a dumb question, but is there any way you can program the Devo 8 to work on a 4-Channel helicopter such as the CB100, Solo Pro or mSR? That is a phenomenal analogy. It actually reminds me of those marble labyrinth maze games, where you have to consistently change the angle of the board to get the marble to the end of the maze and in the hole. ![]() I'm glad you gave me the heads up on the V120D02, so I don't continue to belabor the point of specs and comparisons. LOL ![]() From the sounds of it, it sounds like I'm on the right path. The only question now is CP or FP. Let the research continue. I just don't want to invest in a FP, only to move on quickly to a CP. Can I learn all the same skills with the CP that I could with the FP without picking up any bad habits or less than stellar skills?I looked into sims, such as RealFlight, but all of the ones that come highly recommended on the forum don't work on a Mac. I don't own a PC, so that makes things a tad bit more difficult. The only one I found that works on a Mac is the RC Helicopter Simulator by AlphaMacSoftware (http://www.alphamacsoftware.com/). What is the best place to purchase helicopters, parts, etc.? I've heard a lot about Wow Hobbies, as well as XHeli. I know they don't carry Blade products, but I thought maybe you would know the "Go To" places in the RC Heli world. ![]() Thanks again for all of your help. Cheers!
United States, CA, San Mateo
Joined Oct 2011
Heres the thing, if you go with the genius cp rtf do not open the box charge it up and fly it right off the bat, you will crash crash crash crash. ![]() If you're patient and set up your radio correctly and set up your heli correctly before you fly it you will be rewarded with a succesful hover. Out the box its a handful there is no expo to much pitch to much travel that will bind and eventually strip your servo gears. Be alert that most these guys have some experiance with cp heli's and radio set up so they usually use their own settings rather the factory default settings before flying. Especially setting up a correct throttle cut/hold. Do yourself a favor and learn everything you can about setting up a Cp heli before you fly ![]() I'm sure Nytflyer (Leo) will be more then happy to go over radio and heli setup with you if not ill kick his butt ![]() ![]() Same goes for the mcpx Happy holidays Cheers Dave |
Odenton, MD
Joined Apr 2009
With the Genius......no mods required it flies great right out of the box bone stock!
![]() With the mcpx you have to at the VERY least do the grommet mod which is where you disconnect your servo links from the swash take the extra canopy grommets that come with the kit and put them over the swash balls. If you don't the heli will shake itself like it has parkinson's ![]() That is the only mod you have to do if you are new to CP and just learning to hover. Once you can fly and start trying tricks like flips and such you need to extend the boom by about 3/4" and get the new version 3 tailblade which is only sold with the whole tailboom kit so you have to pay 15 bucks to get a little plastic blade. Or you can get the KBDD tailblades for about 4 bucks for 2 but most guys say the V3 tailblade is better.My mcpx is brushless and I use the sr120 tail motor on it which has a bigger shaft than stock so I actually use a walkera tailblade on mine or the stock sr120 tailblade.
Joined Apr 2002
Odenton, MD
Joined Apr 2009
You could get the 2801 with your CB100 and then when ready for the G you could get the bind and fly for like $150 and use the 2801 for both helis. I wouldn't recomend this though as the Devo serious is walkera's new radios and although they are releasing the new helis right now for both systems I am pretty sure they are going to ditch the 2801 line pretty soon. I have a few walkera helis and most are fixed pitch. 4#3b, V100d01, and a 4#6s that I converted to flybarless. So I have to use my 2402 to fly the 4#6 and then I use the 2403 to fly my 4#3 and V100. I got my GCP with the Devo 6 and I absolutely love that transmitter. So I think if you got the GCP and wanted the devo 8 that would be an excellent choice. Another thing to realize is that walkera transmitters will only work on walkera helis/receivers they use there own 2.4ghz technology. Blade helis use there own technology called DSM2/X. Point is if you start with a FP you are pretty much gonna have to use the RTF transmitter so it really doesn't matter if you start with the MSR or the CB100 because once you upgrade to CP you will need another transmitter. I am not sure where you live but if you are in the US almost every local hobby shop(LHS) sells blade parts. This is a HUGE advantage in the fact that if you break something you can run out to the LHS and get spares when you need them and not be down for 3 or 4 days while you wait for parts. So with the MSR and mcpx if you break something you can likely take a 20 minute drive get your parts and be home and back flying within an hour. None of my LHS sell walkera parts at all. So that is a big disadvantage to me because when I break stuff it takes me a minimum of 3 days to get the parts to fix. Wow hobbies is actually my go to helicrack dealer I have been ordering from them from years and have had a few problems but they have always taken care of me I have never ordered from xheli but I have heard very good comments about them as well. And wow does sell blade helis and parts too BTW.And as Farmer(DAVE) said research research research. Especially if you are going to start with a CP heli. If you get the CB100 or MSR charge it up and start practicing these are going to be much faster then your coax but they still self stabalize so if you get into a pickle you can just let go of the cyclic and it will pretty much just self hover in place. I would suggest you go over to helifreak and watch finless bob's videos on CP setup. He also has videos specifically about the GCP and MCPX. You can find them here. http://www.helifreak.com/forumdisplay.php?f=60 I think you have to register to watch them but his videos are great and will help you kind of get an idea what you are getting yourself into with a CP heli. FP helis require MUCH less setup. Helifreak has great MCPX threads. I love RC groups but the mcpx threads here get kind of cumbersome to find information IMO. Helifreak is much more organized so it is easier to find what you are looking for over there on the mcpx and any other blade heli as well. Not really sure why but the walkera threads over there are pretty dead so RCG is where you want to be for that info. Lots of great guys over here with a TON of knowledge on walkera helis much much more than I have. Just take your time with your decision bud and let us know if you have any other questions ![]() Good luck and have fun! Leo |
Joined Oct 2011
![]() Genius cp requires no parts to fly just some time to set up which is a priceless learning experiance. It will fly out the box as is no problem But thats not the point. It will even do 3D out the box bone stock with out having to feather the collective worrying about tail blow out like the mcpx ![]() Here you go stock genius cp ![]() http://www.youtube.com/watch?feature...&v=cFyneIe6Siw Happy holidays Dave |
Odenton, MD
Joined Apr 2009
Walkera has really picked up their game with their newer models. |
Odenton, MD
Joined Apr 2009
| Thread Tools | |
| Mini-Review Walkera Genius CP Review - Pictures, Video, Brushless Mod, Genius VS mCPX | Tom Z | Micro Helis | 471 | Apr 26, 2013 05:05 PM |
| Discussion Walkera Genius CP issue resolved! | Tom Z | Micro Helis | 44 | Jan 03, 2012 10:56 PM |
| Question Best online merchant for a walkera brushless genius cp w/devo8 | RcHeli_Newb | Trader Talk | 1 | Nov 07, 2011 12:19 PM |
| Discussion Walkera Genius CP-the smallest 3d flybarless heli in the world! @ oomodel | oomodel.com | Hot Online Deals | 12 | Oct 16, 2011 08:52 PM |
| Discussion Setting Up Walkera 2603 for Genius CP Heli | BernieHeli | Electric Heli Talk | 4 | Oct 05, 2011 06:55 PM |
